tri_joel
Joined: 03 Jul 2007 Posts: 646 Location: Northern Virginia
Link Posted: Wed Jan 30, 2013 12:40 am Post subject: Digital antenna |
I've been paying an arm and leg for FiOs for six years now, only so my Bride can watch HGTV. Everything else we watch is broadcast. I've been researching OTA antennas for some time now and have yet to find one without a list of reception quality complaints. Does anyone here have a good recommendation?
My next problem will be a receiver for my Marquee. I see old receivers on eBay, some with VGA out. That in itself presents a problem, I removed my RGBHV cables and installed HDMI when I bought an HDFury. I could go back, but I'm not too excited about that idea. I am actually thinking about adding an HTPC just for this reason, then I could also use it as a DVR. I know zero about HTPC, I tried to read Craig's thread but it is written in a language I do not understand.
All advice and ideas welcome.
Thank you,
Joel
_________________ www.vawinesnob.com
jeffslife
Link Posted: Wed Jan 30, 2013 12:51 am Post subject: |
If an OTA is having reception problems it is more than likely due to installation or location. Look around and see what kind of antennae people around you are (or were ) using. A pre amp ant. is a plus. There is NO DIFFERENCE between a digital and an analog antennae. Just like back in the day when they would advertise a COLOR antennae.
wallace123456
Link Posted: Wed Jan 30, 2013 2:41 am Post subject: |
Check out this site. They have some cool looking stuff, but I have not purchased yet.
http://www.solidsignal.com/
Like you, I would like to get a local OTA signal for local HD channels.
wallace
Link Posted: Wed Jan 30, 2013 3:31 am Post subject: |
What stations are you trying to pull in (UHF, high VHF or low VHF)? It makes a difference. How far are you away from the towers? Is the antenna inside or out? Start by going to antennaweb and plugging in your address. That will give the channels and distance/direction. From there you can start to get an idea of what you need to do.
http://www.antennaweb.org/Address.aspx
For a good review of a lot of antennas, go to hdtvexpert.
http://www.hdtvexpert.com/
If you have UHF, then the Gray-Hoverman DIY antenna might be suitable.
http://www.digitalhome.ca/ota/superantenna/index.htm
Link Posted: Wed Jan 30, 2013 4:27 am Post subject: |
wallace123456 wrote: | Check out this site. They have some cool looking stuff, but I have not purchased yet.
wallace |
I buy all my Dish network and Antennas from them. Great people to work with and ask questions.
Id give them a call.
I have to say old style huge antennas work great for HD. get the motor too so you can turn the antenna to catch different locations.
jeffslife
Link Posted: Wed Jan 30, 2013 4:40 am Post subject: |
If you want to make your own, Check out the AUSSIES them boys know how to make an antennae.
Link Posted: Wed Jan 30, 2013 4:44 am Post subject: |
Spanky Ham wrote: | Start by going to antennaweb and plugging in your address. That will give the channels and distance/direction. From there you can start to get an idea of what you need to do.
http://www.antennaweb.org/Address.aspx |
Good info in your post, Spanky... One note, though. I used to use AntennaWeb, but then I found (or somebody on AVS mentioned) TV Fool and I LOVE it. The report is much, much more detailed and informative than AntennaWeb. I still use AntennaWeb for simplicity, but TV Fool is awesome.
http://www.tvfool.com/index.php?option=com_wrapper&Itemid=29
Anther enthusiastic recommendation for Solid Signal. Been buying satellite and OTA stuff from them for years, and they've always been really good.
Link Posted: Wed Jan 30, 2013 5:11 am Post subject: Re: Digital antenna |
tri_joel wrote: | My next problem will be a receiver for my Marquee. I see old receivers on eBay, some with VGA out. That in itself presents a problem, I removed my RGBHV cables and installed HDMI when I bought an HDFury. I could go back, but I'm not too excited about that idea. I am actually thinking about adding an HTPC just for this reason, then I could also use it as a DVR. |
Oh, and Joel... If all you want is an OTA receiver with HDMI, those are certainly available.
http://www.amazon.com/Channel-Master-CM-7001-Antenna-Clear/dp/B0066O1DI2
There are also others. Of course, you're between a third and half of the way to a decent HTPC with a tuner card or USB stick for DVR/time-shift/archiving capability.
Just depends on how much money you want to spend, and/or how important simplicity is.
Personally, I can barely stand to watch live TV any more, so for me, it's essentially DVR or nothing.
It wouldn't take much of a PC just for OTA DVR functionality... You can probably by a nice refurb/off-lease computer from a local reseller for $100-125 with Windows 7 on it. Add a used HDMI video card for $40-50, and an OTA tuner card/stick for another $50-50, and for $225-250, you could have OTA DVR.
Just a thought.
Link Posted: Wed Jan 30, 2013 12:49 pm Post subject: |
ecrabb wrote: | One note, though. I used to use AntennaWeb, but then I found (or somebody on AVS mentioned) TV Fool and I LOVE it. The report is much, much more detailed and informative than AntennaWeb. I still use AntennaWeb for simplicity, but TV Fool is awesome. |
AntennaWeb says that with a good-sized 30'AGL antenna I could reach 10 stations. 4 are Spanish, 2 are religious, 3 are unidentified. So with an antenna I could get 1 known station I might watch, and it's Fox. With 0'AGL it said I could only get one marginal signal.
TV Fool says I can get 4 stations with a set-top, 10 more with antenna mount, 15 more with roof mount. Quite a different result. Who to believe?
Link Posted: Wed Jan 30, 2013 2:53 pm Post subject: Re: Digital antenna |
ecrabb wrote: | Spanky Ham wrote: | Start by going to antennaweb and plugging in your address. That will give the channels and distance/direction. From there you can start to get an idea of what you need to do.
SC |
Just checked out TVfool and it is pretty good. I guess it isn't that big of a deal for me since I am 3 miles from the towers.
ecrabb wrote: | tri_joel wrote: | My next problem will be a receiver for my Marquee. I see old receivers on eBay, some with VGA out. That in itself presents a problem, I removed my RGBHV cables and installed HDMI when I bought an HDFury. I could go back, but I'm not too excited about that idea. I am actually thinking about adding an HTPC just for this reason, then I could also use it as a DVR. |
Just a thought.
SC |
If a set top box doesn't have any issues, then I would go that route over a HTPC. I can't say how many times I have had issues with my HTPC. The last time was with the series finale of Fringe, when I couldn't get the device to sync. I gave up and threw the Wonder against the wall (yes, I know I have anger issues ). If you are watching movies, then it is probably fine but OTA could be frustrating. Also, you can't just turn the pj on and start watching TV. You have to plan five to ten minutes ahead of time for boot, start program, make sure there are no issues, etc.
Link Posted: Wed Jan 30, 2013 2:55 pm Post subject: |
jeffslife wrote: | If you want to make your own, Check out the AUSSIES them boys know how to make an antennae. |
If you want to go DIY, then I can give more info. I designed and built my own Yagi, because I had a low VHF station (Fox) that I was having trouble pulling in. For the time and expense, it is probably easier just to buy an antenna.
jeffslife
Link Posted: Wed Jan 30, 2013 4:51 pm Post subject: |
The Aussies make antennaes that are built into the rafters of your house that pick up stations from over a hundred miles away, It is amazing. Imagine an antennae that is as big as your roof made from a spool of copper wire and stand offs.
Link Posted: Wed Jan 30, 2013 6:25 pm Post subject: |
Also keep in mind that digital reception is nothing like analog. I mean this in that the signal will be received, and perfectly so, or not at all. There will not be a gradation of signal as seen in the form of something on the screen.
jeffslife
Link Posted: Wed Jan 30, 2013 6:35 pm Post subject: |
That is not exactly accurate. There are still different degrees of signal strength. There is a threshold where the picture degrades but a strong signal is still preferable.
tri_joel
jeffslife
Link Posted: Wed Jan 30, 2013 10:07 pm Post subject: |
I never liked the omnidirectional myself but depending on your location relevant to the towers you are trying to access it could be fine for you.
Link Posted: Thu Jan 31, 2013 1:15 am Post subject: |
jeffslife wrote: | The Aussies make antennaes that are built into the rafters of your house that pick up stations from over a hundred miles away, It is amazing. Imagine an antennae that is as big as your roof made from a spool of copper wire and stand offs. |
They must be using rhombic antennas. Wouldn't it be funny if I had a hand in starting that? I mentioned rhombic antennas to one of the Aussies seven or eight years ago when I was building my antenna. He lived out in the middle of nowhere and I told him that this may be his best bet. I think we talked about it a little bit, but I wasn't going to build one so he was on his own.
http://www.tpub.com/neets/book10/42o.htm
Joel,
What about the Channel Master or Tivo? I know the CM is more expensive, but it probably has better support. Tivo is cheap upfront, but they get you with the $15 subscription fee. That said, I really liked Tivo when I had it on my Directv box.
tri_joel
Link Posted: Thu Jan 31, 2013 1:27 am Post subject: |
Thanks Jeff. I don't really feel like experimenting, but I think it will receive the channels I want. I didn't want to share my home address otherwise I would have posted a screen shot from antenna web.org. My zip is 22101, McLean VA if you have any interest in looking it and letting me know what you think.
Steve- I'm with you on the live TV vs. DVR. The only live TV we watch anymore are the Nationals and Yankee baseball games, Redskin football (someday they will be worth watching the entire season), and I watch a lot of college football. We will stream MLB through Apple TV, Redskins will come over antenna, and college football will unfortunately suffer. Most TV programs we watch we can get through Hulu or Netflix. So in a nutshell, a DVR would be convenient to record football games, so I have been searching eBay for oldish Direct TV DVRs with OTA tuners. I have not discounted the DVR I linked to above, I'm just concerned about the negative reviews.
Another option I have, but have put little thought into, is I have a laptop with HDMI and Windows Media Center. I could just install one of those USB tuner thingies and use it as a tuner and DVR.
jeffslife
Link Posted: Thu Jan 31, 2013 4:15 pm Post subject: |
I would need to see your house, Do you live near a lake? Up on a hill ? Down in a valley. Are you surrounded by tall buildings ? There are a lot of factors to consider. Proximity to the towers not being the least. If you dont live by a lake and have a reasonably clear line of sight within 25 miles of the towers you should have no problems at all. Attic installs work well in most cases and the install is easy,also you have less of a chance of lightning strikes. There are many things to consider but it aint rocket science.
