robroy90
Link Posted: Sat Oct 27, 2012 8:13 pm Post subject: MUX FHD Question |
Greetings!
I am trying to use the MUX FHD with my Tivo recorder, and I am getting a pink color cast to the output when it is routed through the MUX. If I take it out of the chain, the output returns to its normal clear, correct state. I have power-cycled all the devices and I have swapped out cables, etc.
Is there a setting on the MUX or the Tivo I need to change?
Thanks, please advise.
-Rob
Link Posted: Sat Oct 27, 2012 8:45 pm Post subject: |
On the remote with the MUX there are buttons labeled A B C D. these will change the color space for the output. try each one till the color is correct.
A is HDMI RGB
B is HDMI YCbCr444
C is YCbCr442
D is DVI RGB
MODE button should be the pass through
Try that one first as it will no do any conversion if your not sure which output your Tivo does.
I attached the data sheet for your unit.
Download |
Filename: |
VF01_v01.pdf |
391.58 KB |
Downloaded: |
740 Time(s) |
robroy90
Link Posted: Mon Oct 29, 2012 7:15 pm Post subject: |
Thank you. I am trying the settings. What is the easiest way to put it in bypass mode?
Seraphic: I can't respond to your PM because I don't have enough posts yet. My unit is white folded over a grey band for the ports.
Does that make a difference for some reason?
Seraphic
Link Posted: Mon Oct 29, 2012 8:42 pm Post subject: |
robroy90 wrote: | Thank you. I am trying the settings. What is the easiest way to put it in bypass mode?
Does that make a difference for some reason? |
No problem, I was just wondering what your unit looked like.
Mine looks the same as your unit.
It was just that our units look nothing like the one shown in the VF01_v01.pdf.
So I was wondering if we had the older MUX-FHD or the new VF01?
Or maybe they are the same unit? I don't know...
Seraphic
Link Posted: Mon Oct 29, 2012 8:51 pm Post subject: |
Nashou66 wrote: | Those controls I think worked for the unit before the VF01 as well. I have the previous data sheet for that with out the picture
of the unit. They are the same so I posted the latest version.
Athanasios |
So I have the older Mux-FHD? I just ordered my unit a few days ago and it already arrived.
But when I opened the box I found it to look nothing like the one seen in the VF01_v01.pdf which gave me a bad feeling.
If you look at the newer datasheet, there are additional HDMI audio features. Like bit-streaming the newest DTS/Dolby.
Link Posted: Mon Oct 29, 2012 9:00 pm Post subject: |
Seraphic wrote: | Nashou66 wrote: | Those controls I think worked for the unit before the VF01 as well. I have the previous data sheet for that with out the picture
Athanasios |
But when I opened the box I found it to look nothing like the one seen in the VF01_v01.pdf.
If you look at the newer datasheet, there are additional HDMI audio features. |
there are at least 4 or 5 versions of the MUX-HD. I thinkt he VF01 and the MUX you have are one in the same.
Best way to find out is by the PCB version. Not sure if its marked on the case or not.
I'll upload the MUX FULLHD data sheet as well incase.
Download |
Filename: |
Mux FHD v101.pdf |
736.09 KB |
Downloaded: |
624 Time(s) |
Seraphic
Link Posted: Mon Oct 29, 2012 9:10 pm Post subject: |
Nashou66 wrote: | I think the VF01 and the MUX you have are one in the same. |
But then why does the it look different then the one shown in the VF01_v01.pdf?
Link Posted: Mon Oct 29, 2012 9:18 pm Post subject: |
After looking at the Data sheets they are different. the latest VF01 has a few more HDMI audio formats I think and added a way to manualy select input color spaces beside the auto detect. Also I am not sure if the VF01 is not for sale yet . It is not on the Moome web site from what i can see. I have been in contact with moome about some issues with my Blend set up he sent me the latest data sheet. So I think I jumped the gun and let out some info before the product is ready.
When searching for the PDF i selected the one in my first post.
I am not sure when the VF01 will be released or if he will add a buy button for it on his site.
Sorry for the confusion.
Seraphic
Link Posted: Mon Oct 29, 2012 9:27 pm Post subject: |
He also sent me the latest data sheet and said the Mux-FHD is now called VF01.
The manual they sent me in the e-mail for my order was mux_fhd_v10.pdf which looks to be the same as Mux FHD v101.pdf
So I think I have the older unit here...
Link Posted: Mon Oct 29, 2012 9:32 pm Post subject: |
Seraphic wrote: | He also sent me the latest data sheet and said the Mux-FHD is now called VF01.
The manual they sent me in the e-mail for my order was mux_fhd_v10.pdf which looks to be the same as Mux FHD v101.pdf |
Hmm, not sure then which unit you have . I guess you can try to use the buttons on the remote as listed in the VF01 data sheet that are not used int he previous MUX and see if they do anything. If they do then you have the new VF01.
Id try the Input buttons listed in the VF01 that change the color space to see if the image changes colors from having the wrong color space selected.
Seraphic
Link Posted: Mon Oct 29, 2012 9:51 pm Post subject: |
Nashou66 wrote: | Hmm, not sure then which unit you have . I guess you can try to use the buttons on the remote as listed in the VF01 data sheet that are not used int he previous MUX and see if they do anything. If they do then you have the new VF01.
Nashou |
Nashou66, I just tried as you suggested and found that on the remote button number: 5, 6, 7, 8, and 9 work.
In addition, the Return and Reset buttons seem to be working as well.
Do you have a Mux-FHD? If you hit any of the keys I listed above your remote, does the unit respond?
Maybe robroy90 could also try.
Seraphic
Link Posted: Mon Oct 29, 2012 10:03 pm Post subject: |
I was able to clear up what version I have.
Thanks for the help.
jacob374 Guest
Link Posted: Fri Oct 11, 2013 10:35 am Post subject: |
I can't respond to your PM because I don't have enough posts yet. My unit is white folded over a grey band for the ports....?
