3D through Barco
bobnes
PostLink    Posted: Sun Oct 21, 2012 9:29 pm    Post subject: 3D through Barco Reply with quote
Is it possible to run 3D signals through a Barcodata 801s?
Regards
Bobnes
TV/Projector: JVC NX9 & Sony G90 – Lumagen Radiance Pro 4446
PostLink    Posted: Sun Oct 21, 2012 10:44 pm    Post subject: Reply with quote
I'm sure it is, but you may not be happy with the resolution and/or brightness.
I did setup an NEC1350 and was surprised by how bright it was.
bobnes
PostLink    Posted: Mon Oct 22, 2012 8:04 am    Post subject: Reply with quote
So, you mean I loose a lot of brightness if I buy a Moome 3D card? What about ghosting in slow green phosphoric tubes Question
Bobnes
bobnes
PostLink    Posted: Fri Feb 01, 2013 10:27 am    Post subject: Reply with quote
Or if I buy a 3D Fury 4 box with transmitter and glasses, will it work? Anybody tried a Fury4 and a CRT with a good 3D result?
Rolls-Royce
PostLink    Posted: Fri Feb 01, 2013 10:42 pm    Post subject: Reply with quote
Your brightness loss will come from the glasses, not from the 3D itself. When deciding between the Moome 3D card and the Fury 4, you should be looking at the 3D output resolutions and scanrates each supports as well as those your projector supports.
....Royce....
bobnes
PostLink    Posted: Sat Feb 02, 2013 12:53 am    Post subject: Reply with quote
Hi, I am using a BarcoData 801s, the scanrate is enough to support HD. I m just curious if anyone had sucsess using Fury4 or any other 3D cards on Barco PJ's and what results? Read on the forum here about Barco 909 and momebox, green picture etc. If the 909 canīt do it who can?
Rolls-Royce
PostLink    Posted: Sat Feb 02, 2013 6:41 pm    Post subject: Reply with quote
According to the tables here, your PJ will do 720p or 1080i. So you'd have to use a 720p60 (or 720p120 if your projector supports it) 3D mode. This is what I meant by looking at the resolutions/scanrates supported by the converters AND those supported by your Barco.
....Royce....
tanwn
PostLink    Posted: Sat May 04, 2013 10:32 am    Post subject: Reply with quote
I have a barco cinemax aka 909 and it works with hdfury4 3d. Running at 1080p72 flicker free
bobnes
PostLink    Posted: Sun May 05, 2013 10:01 am    Post subject: Reply with quote
Ok, you have the 909, its the best PJ and it can also do 4K. Congratulation!
PostLink    Posted: Sun May 05, 2013 11:38 am    Post subject: Reply with quote
Can do 4k?
bobnes
PostLink    Posted: Mon May 06, 2013 6:19 am    Post subject: Reply with quote
Yes, the 909 series can deliver a very high resolution because of the scanrate.
PostLink    Posted: Mon May 06, 2013 6:53 am    Post subject: Reply with quote
Interesting.. Anyone care to show a 4K 1:1 testpattern screenshot.?
Well or at least a 1080P 72hz 1:1 testpattern screenshot.
PostLink    Posted: Mon May 06, 2013 11:46 pm    Post subject: Reply with quote
You wont get 1:1 at 4k with just one projector even with a 909... Maybe a 912, if you can find one...
PostLink    Posted: Tue May 07, 2013 9:29 am    Post subject: Reply with quote
I never seen or owned a 909, so ill not argue agains any claim, but it would be interesting finding a CRT that will handle the bandwidth, and fully resolve those HD formats.
So ill let the ones with a 909 prove it.. Wink
PostLink    Posted: Tue May 07, 2013 10:51 am    Post subject: Reply with quote
A 912 is a 909 with 12 inch tubes, and i doubt even it will do 4k 1:1... Not even sure if itll do 3200x2560 1:1, but itll display it apparently....
PostLink    Posted: Tue May 07, 2013 11:21 am    Post subject: Reply with quote
I would think there is more to it than the tubes. Im not sure it would help with 3x 32" tubes.
PostLink    Posted: Tue May 07, 2013 11:28 am    Post subject: Reply with quote
Shocked
PostLink    Posted: Tue May 07, 2013 12:40 pm    Post subject: Reply with quote
Twelve inch tubes, not 32 inch. It is ( or was ) said to be sharper and considerably brighter than the standard 909. It has all the same features and boards as a 909, so bandwidth is the same at 180MHz.
3200x2560 is the factory listed maximum resolution. Id like to see it though.
