Fan Mod Sony 1271
Andy_34
TV/Projector: Sony VPH 1271QM
PostLink    Posted: Sun Jul 15, 2012 7:55 am    Post subject: Fan Mod Sony 1271 Reply with quote
Hi Guys,
iīm changing the fans in the Power Supply. Iīm replacing the original ones against Papst Fan.
Since the Papst Fans donīt have the Sensor wire (yellow wire) i think i have to put the yellow wire in the plug on 12V DC, so the projector thinks the fan is still running. Is that correct?
2nd question: To do the fan mod i pulled the power supply out of the projector. Before i put it back in, can i hook the power supply to the ac outlet and get it started with the remote controll to see if the fans are working?
Greets,
Andy
fuchs
PostLink    Posted: Mon Jul 16, 2012 9:33 am    Post subject: Re: Fan Mod Sony 1271 Reply with quote
I don't think so, unfortunately. These yellow wires usually carry a pulse signal that gives information on the RPM of the fan. It's really different than "just" a +12VDC.
If the PJ logic monitors the yellow wire of that fan (and most PJs do) it will shut down immediately with some error code because the fan is not turning.
I don't think so either. You'd probably have to force it on with some sort of control jumper wire.
Also, I'm not convinced that it is a good idea to turn on that power supply without any load.
onkel fuchs' cheapskate cinema
NEC plain 9PG
Andy_34
PostLink    Posted: Tue Jul 17, 2012 7:39 pm    Post subject: Getting error code 01 Reply with quote
Hi Guys,
here is an update:
i put the original fans back in the power supply. But unfortunaly i get the error Code 01 (Fan stop) after 1-2 seconds after starting up. I can see that all fans are working.
i cut the yellow wire and wired it directly with the black one (only for the fans in the power supply).
Still i get the error code 01
The other fans are still the original ones. i didnīt even disconnect the plugs.
Iīve got the Dealers manual, but i need a liitle help to find out where to look.
Maybe therīs a way i can disconnect the whole fan protect circuit.
Greets,
Andy
barclay66
TV/Projector: Marquee 9500 Ultra (finally bolted to the ceiling)
PostLink    Posted: Tue Jul 17, 2012 8:08 pm    Post subject: Reply with quote
You should have left the yellow wire where it was. As stated before it carries a pulse signal coming from the fan(s). The circuit responsible for detecting the presence of the pulses is quite important. Major damage may occur if the projector is being used without proper cooling and the circuit is intended to prevent that if for example the fans get stuck with dust.
You should instead look for fans with three wire connector. Fans from beQuiet usually have them and I have found them to be well designed and affordable at the same time.
If You still want to go the risky way You will need a pulse generating circuit (e.g. Built around a NE555) in order to simulate the pulses from the fans. I wouldn't try to disable the sensing circuit...
barclay66
View user's photo album (45 photos)
Andy_34
PostLink    Posted: Wed Jul 18, 2012 2:03 pm    Post subject: Reply with quote
Hi Guys,
hereīs an update:
i put the original fans back in the power supply. I also wired the original connectors back on the wires. Even the yellow one.
After switching the power back on, all fans are working till the projector switches off after 2 sec and i get the error code 01.
What now??
Greets,
Andy
TV/Projector: JVC RS45
PostLink    Posted: Wed Jul 18, 2012 2:28 pm    Post subject: Reply with quote
Are you sure all fans are spinning? I don't recall how many fans are in a 1271, but there are a number of them. There are the fans in the PSU, then there are a couple of fans up on the main board... Can't remember if there are others.
Just to be clear, was the projector working before you started the fan replacement project?
barclay66
PostLink    Posted: Wed Jul 18, 2012 2:51 pm    Post subject: Reply with quote
Good point!
If it was working before and if the Power Supply fans were the only ones being touched then I'd have two possible scenarios:
- The pulse generators on the fans were damaged by connecting them to the black wire (if that was done on the fan side). In this case only a replacement of the fans with similar ones (same voltage and same pulse rate per RPM) will help.
- At least one of the pulse sensing circuits on the Power Supply was damaged by connecting its input to the black wire (if that was done on the Power Supply side). In this case the F-Prot signal is triggered and the control logic decides shutting down the PJ as a safety measure. Replacement or repair of the Power Supply (M2 board) would be necessary. Possible defective parts could be the transistors Q259/Q260 (2SC2785) and the diodes D285/D286 (1SS119).
barclay66
PostLink    Posted: Wed Jul 18, 2012 3:03 pm    Post subject: Reply with quote
Good point!
barclay66
I would like to point out that we don't discuss CRT projector component level repair here without Curts approval.... Very Happy
macgyver566@gmail.com
Andy_34
PostLink    Posted: Wed Jul 18, 2012 6:13 pm    Post subject: Reply with quote
Hi Guys,
the projector worked fine before the fan mod. And iīm sure that all 5 80mm and the 1 40mm fan are spinning if i switch the projector on.
Is there an easy way to disconnect the fan protection circuit? Iīm fully aware of what can happen.
In german forums they say, if you connect the yellow wire with the black wire, the fan protection is disabled. But they say you have to do it for every fan.
Greets,
Andy
fuchs
PostLink    Posted: Thu Jul 19, 2012 8:00 am    Post subject: Reply with quote
well... do what you have to do...
i'd first try to make some sort of 3-wire extension cord and wire the fans to an ordinary PC.
Most PCs have a BIOS-setup that lets you monitor hardware (temperature, RPMs, etc).
Then check if all fans actually output a pulse when turned on.
If they all do, you could have blown the protection circuit.
Anyway, maybe check the service manual for "hidden fans", you may have forgotten you had Smile
NEC plain 9PG
rosenbush
PostLink    Posted: Fri Jul 20, 2012 3:27 am    Post subject: No Pulse Reply with quote
There is no pulse on the yellow wire.
Just make shure you bridge the yellow one with the black one at the board side (not at the fan side)
If you use a regular fan (made for PC) and if you use the connector that comes with it you may need to realocate the 12 volts wire, you can compare it with the fan you just remove.[/s]
Andy_34
PostLink    Posted: Mon Jul 30, 2012 7:27 pm    Post subject: Problem soved Reply with quote
Hi Guys,
first i want to tell you, that i solved the problem.
But i really donīt know how. But first things first.
First i bought one of the proverīs sony 1271. Tested it, and it worked just fine.
So i started to change some components.
First the power supply - no luck
2. the L Board - no luck
3. the Y Board - no luck
then i wanna to change the E and the DC board. As i removed these boards from provers crt i realised that his 40mm fan has only 2 wires. A red and a black one. My 40mm fan has 3 wires. Red, black and yellow. So i switched the fans and my 1271 suddenly worked fine. I rechanged to my fan and disconnected the yellow wire and it worked fine.
And before i started to install my sony under the ceiling i did not change anything and it worked fine for about 5 years.
But i have to say, i disconnected and removed a lot of parts to lighten the beast to install it under the ceiling.
Can it be, that the yellow wire from my 40mm fan was not really connected in the plug?
Greets,
Andy
