nec 9 power problems
Goto page 1, 2, 3  Next
lawbob
PostLink    Posted: Tue Jun 26, 2012 8:46 pm    Post subject: nec 9 power problems Reply with quote
hi there have a problem with my nec 9 projector stand by light will only stay on for seconds and then goes out. we thought it was a power supply board problem but have the supply board checked and i am told there is nothing wrong there are no error codes showing any one with an idea thanks robert[/list]
PostLink    Posted: Wed Jun 27, 2012 5:35 am    Post subject: Reply with quote
So you're saying that the whole back light that illuminates the buttons in the standby mode go out after a few seconds. I'd virtually guarantee that the power supply is bad. It's a very complex supply that can't really be tested as a standalone item. Ideally you'll swap it out with a working unit to make sure it's bad.
lawbob
PostLink    Posted: Wed Jun 27, 2012 8:31 am    Post subject: Reply with quote
hi there thanks for the quick reply i cant find a working nec to allow me to do what you suggest. do you have a power supply for that model available the part number is 79642151 and m rps/1201g.if you have please advise me the cost including shipping thanks again robert
PostLink    Posted: Wed Jun 27, 2012 1:20 pm    Post subject: Reply with quote
I do, the problem is that it's a 110 volt supply only. Do you have a stepdown transformer to convert from 220 to 110 volts?
PostLink    Posted: Wed Jun 27, 2012 2:22 pm    Post subject: Reply with quote
Hey curt, isn't there a jumper for voltage selection inside the PG power supplies?
NEC 6PG xtra
PostLink    Posted: Wed Jun 27, 2012 2:29 pm    Post subject: Reply with quote
No, not that I know of. I think there are some mods that can be done, but I've never done them. I believe that the AC input board is also differently laid out between the two sets. But Lawbob, if you want to take your LVPS out, pop off the top cover and take some pictures, if the main PC board is the same between the 110 and 220 volt versions, then I could most likely send you just that board rather than the whole set.
PostLink    Posted: Wed Jun 27, 2012 2:32 pm    Post subject: Reply with quote
Yes, there is a jumper inside, and some other components should be changed, the picture is for PG plus, but I think it is basically the same as plain PG.
PG plus
 Filesize:  36.5 KB
 Viewed:  1087 Time(s)
NEC 6PG xtra
PostLink    Posted: Wed Jun 27, 2012 2:38 pm    Post subject: Reply with quote
I have PG xtra which is very different, but if you don't mind I attached the corresponding page from the PG+ SM, I circled the jumper which should be altered.
 Filename:  PGP_ps2.jpg
 Filesize:  190.73 KB
 Downloaded:  55 Time(s)
NEC 6PG xtra
PostLink    Posted: Wed Jun 27, 2012 2:44 pm    Post subject: Reply with quote
Good finds, I don't think I have either of those on file here. Thanks!
lawbob
PostLink    Posted: Wed Jun 27, 2012 7:38 pm    Post subject: Reply with quote
hi curt transformer to change from 220 to 110 they are readily available in scotland so that is not a problem.i have spoken to mr alan head who advises me on all this and has told me to ask if you happened to have c/drive for the same projector.if you can let me no the cost including shippment. i would also like to thank giaky for his input thanks very much robert
PostLink    Posted: Thu Jun 28, 2012 7:26 am    Post subject: Reply with quote
LawBob, they may be available, but make sure they can do around 1.5kVA.
lawbob
PostLink    Posted: Thu Jun 28, 2012 9:44 am    Post subject: Reply with quote
thanks for that will check it out robert
lawbob
PostLink    Posted: Thu Jun 28, 2012 12:36 pm    Post subject: Reply with quote
have just checked transformer screwfix can supply 3k/5k-1.5 kva continuous that should do the job thanks casethecorvetteman for bringing this to our attention robert
lawbob
PostLink    Posted: Fri Jun 29, 2012 8:14 am    Post subject: Reply with quote
hi curt could you please give me a total cost for the power supply and the c drive including shipment to scotland so i can arrange payment thanks robert
PostLink    Posted: Fri Jun 29, 2012 9:58 am    Post subject: Reply with quote
Dont buy one yet cause you may be able to get Curt to flick it over to 240 volt before he sends it.
PostLink    Posted: Fri Jun 29, 2012 1:30 pm    Post subject: Reply with quote
Sure, let me test them this weekend.
lawbob
PostLink    Posted: Fri Jun 29, 2012 1:50 pm    Post subject: Reply with quote
thanks casethecorvetman will not buy till i hear curt has also said he will check this weekend that would be good thanks to both of you robert
PostLink    Posted: Sat Jun 30, 2012 7:46 am    Post subject: Reply with quote
I have a 240 volt one here if Curt doesnt have a suitable one, its from a 9 PG Plain.
lawbob
PostLink    Posted: Mon Jul 02, 2012 8:00 am    Post subject: Reply with quote
hi casethecorvtteman thats good to know if curt cant help me out i will be in touch thanks robert
PostLink    Posted: Mon Jul 02, 2012 8:11 am    Post subject: Reply with quote
No worries mate, let me know if you need it, although im a last resort, cause i only have one spare for 3 9PGs Wink
Page 1 of 3
