| Author |
jeffslife
TV/Projector: Sony G90 with moome board V2 ,Marque green C element, Professionally calibrated by CRAIG ROUNDS
Link Posted: Fri Jun 22, 2012 4:59 pm Post subject: How to mount factory bracket |
I am going to (with some luck) hang my G90 this weekend. I am using the factory bracket attached to unistrut, it should work out well and help to keep the pj from being any lower than absolutely necessary. I would like to be able to use the slots that are available on the mount to turn the pj slightly to adjust for squareness to the screen but I can see no possible way to do so. A friend of mine is a mechanical engineer and is coming over later to offer his expertise, I thought I would check with you guys. Thanks in advance.
Jeff
| Back to top |
jeffslife
Link Posted: Sat Jun 23, 2012 1:01 am Post subject: |
Well we see no reasonable way to accomplish this.
| Back to top |
Joined: 09 Nov 2008 Posts: 1965 Location: QLD, Australia
Link Posted: Sat Jun 23, 2012 5:43 am Post subject: |
Use longer bolts.
| Back to top |
AFryia
Joined: 09 Mar 2006 Posts: 740 Location: S.E. Michigan
Link Posted: Sat Jun 23, 2012 2:41 pm Post subject: |
Should be easy. I'll try and find some pic of my setup if I can get closeups of the strut.
Do you have any pictures of what you are trying to do?
| Back to top |
AFryia
Link Posted: Sat Jun 23, 2012 2:54 pm Post subject: |
Don't Know if this helps.
Here is my recessed tray. The 4 bolts slide up and down the unistrut. The bolts are slightly smaller than the mount holes. That allows some left/right twist.
I have a knock-off factory mount. Hard too see here but it works fine.
| Back to top |
dturco
Joined: 06 Feb 2009 Posts: 3746 Location: Eastern Shore Maryland
Link Posted: Sat Jun 23, 2012 3:33 pm Post subject: |
Another variation of the Uni-strut
As you can see the Eye-Bolts can be any length, for instance 4" on the Uni-strut side and 4" on the machine side, giving you about 7" of adjustment up and down. The sliding nature of the Uni-strut gives you forward and aft movement and some minor left to right Yaw. There is no reason you can't make this work, using the uni-strut and a factory mount.
http://www.hulu.com/firefly
| Back to top |
Link Posted: Sun Jun 24, 2012 12:50 am Post subject: |
Here's how i did mine, different projectors, but still. Miles of adjustments.
| Back to top |
TV/Projector: Barco BG808s 9
Link Posted: Mon Jun 25, 2012 9:20 am Post subject: |
Now thats a shed with the right gear. I bet there is a beer fridge in there somewhere.
| Back to top |
Link Posted: Mon Jun 25, 2012 9:44 am Post subject: |
Yeah mate, but i gave up drinking
There has been some more work done since those pics. Has part of a ceiling now and a 6.5kW reverse cycle split air con...
| Back to top |
Link Posted: Mon Jun 25, 2012 10:16 am Post subject: |
| CasetheCorvetteman wrote: | Yeah mate, but i gave up drinking
There has been some more work done since those pics. Has part of a ceiling now and a 6.5kW reverse cycle split air con... |
Sounds like a home away from home. Just the place to settle down and watch a movie or two.
| Back to top |
dvh99
Link Posted: Mon Jun 25, 2012 10:46 am Post subject: |
i want those luigi mario and yoshi figures!
| Back to top |
Link Posted: Mon Jun 25, 2012 12:51 pm Post subject: |
| km987654 wrote: | | Sounds like a home away from home. Just the place to settle down and watch a movie or two. |
Well in point of fact, that is my home!! Im just too tired to get in and finish it all off!! I got abit sick of working so hard so i slowed down abit.
| dvh99 wrote: | | i want those luigi mario and yoshi figures! |
Yeah i got them with a big heap of retro gaming stuff i bought. Thought they look alright sitting up there with the Nintendo stuff...
| Back to top |
jeffslife
Link Posted: Tue Jun 26, 2012 1:26 am Post subject: |
Its up ! I have movement in 4 axis. Its a little lower than I would prefer but I am happy.
| Back to top |
Phoenixed
Link Posted: Tue Jun 26, 2012 4:45 am Post subject: |
Case's gaming paradise.
_________________ Sony G90
| Back to top |
dturco
Link Posted: Tue Jun 26, 2012 1:08 pm Post subject: |
| jeffslife wrote: | | Its up ! I have movement in 4 axis. Its a little lower than I would prefer but I am happy. |
Can you elucidate, Jeff?
| Back to top |
jeffslife
Link Posted: Tue Jun 26, 2012 1:50 pm Post subject: |
I used the basic unistrut method and mounted the factory bracket to it. I used short bolts and keep the unistrut pretty close. It will move front to back,side to side and the bracket gives me up and down and a little movement to keep it square to the screen. It hangs a few inches lower than the G70 but you can still see the whole screen from the back row so not really a problem. My friend tom built an ingenious hoist using a boat winch that worked perfectly. All in All very happy. Tonight I will plug it in, Gotta find my manual to figure out how to change it to the ceiling setting. It is set on FLOOR right now, not sure why it is obvious it was ceiling mounted. Maybe they changed it to look at menus or something after they took it down.
| Back to top |
Link Posted: Tue Jun 26, 2012 1:53 pm Post subject: |
| Phoenixed wrote: | | Case's gaming paradise. |
Exactly how i always wanted it mate
| Back to top |
barclay66
TV/Projector: Marquee 9500 Ultra (finally bolted to the ceiling)
| Back to top |
jeffslife
Link Posted: Tue Jun 26, 2012 3:36 pm Post subject: |
Thank you very much.
jeff
| Back to top |
jeffslife
Link Posted: Tue Jun 26, 2012 5:29 pm Post subject: |
I cant seem to get the image from being upside down. The small dipswitch ( v switch )moves fine and is in the correct position for ceiling monted front PJ. The swith that moves left to right ( h switch ) doesnt seem to move. If it is moving a switch under there I cant tell it. It only moves about 1/32 of an inch and doesnt seem to trip anything. Also what is "C"
The image is right side up but the letters are backward. I cant seem to change the H SWITCH.
Is there any other changes that need to be made besides those two switches ?
| Back to top |
