AFryia
Link Posted: Wed Mar 22, 2017 10:56 pm Post subject: Wanted Phono Pre-Amp |
I would like to move my Technics SL-Q200 turntable from my budget receiver to my better Pre/Amp speaker setup. But my pre-amp doesn't have a phono input.
The turntable is not audiophile grade; but it is decent.
Have any recommendations on a reasonably priced phono pre-amp?
Link Posted: Wed Mar 22, 2017 11:25 pm Post subject: |
regardless of the box and price, they are all going to be a pretty darn simple op amp circuit with the RIAA equalization curve. Pyle makes one at the lower end, but there's a pile (pun intended) of other brands that are more expensive as well. Unless you want audiophile grade, I'd suspect that the low end Pyle will sound the same as $100-200 units.
AFryia
Link Posted: Fri Mar 24, 2017 9:01 pm Post subject: |
Curt Palme wrote: | Pyle makes one at the lower end, but there's a pile (pun intended) of other brands that are more expensive as well. Unless you want audiophile grade, I'd suspect that the low end Pyle will sound the same as $100-200 units. |
I think I'm looking for a little better S/N and distortion.
I was looking at Schiit Audio, seriously ...and Pluto to name a few.
I'm looking at best in class for ~75-150$
Link Posted: Fri Mar 24, 2017 9:29 pm Post subject: |
But that's my point, it's a simple op amp circuit, and I'll bet that the chips between the two are the same.
nettwerkjohn
Joined: 08 Mar 2006 Posts: 915 Location: Blenheim, Marlborough, New Zealand
Link Posted: Sun Apr 02, 2017 5:31 am Post subject: |
The Cambridge audio unit sounds fair
