| Author |
Link Posted: Wed Apr 25, 2012 7:27 pm Post subject: Sleek Vidikron Vision lid cheeper! REDUCED!!! |
Guys
A curvaceous Pinanfarina lid fits eight inch Marquees, fits nine inch with some modifications; flat black, needs touchup, or paint any color you like. Pictures sent to your e.mail on request.
Make offer.
Tim at E-Tech
ehometech @ earthlink.net
| Description: |
| Filesize: |
108.32 KB |
| Viewed: |
643 Time(s) |
| Back to top |
| Back to top |
Jeremy112
Joined: 28 Sep 2006 Posts: 1505 Location: Fond du Lac, WI
Link Posted: Sat May 12, 2012 5:41 pm Post subject: |
That is sexy
_________________ If it ain't broke, and you try fixing it without success, don't come crying to me!
| Back to top |
jbmeyer13
Link Posted: Mon May 14, 2012 2:52 pm Post subject: |
Hey Tim,
How would someone mod that to fit a 9" machine? I ask because fiberglass has the tendency to shatter relatively easily.
_________________ Projector: 9500LC- Dragan's HD Mods, ETECH PS Mods, Moome 1.3, HD10F's & a V1 case!
| Back to top |
Link Posted: Mon May 14, 2012 3:01 pm Post subject: |
| jbmeyer13 wrote: | Hey Tim,
How would someone mod that to fit a 9" machine? I ask because fiberglass has the tendency to shatter relatively easily. |
The lens openings would need to be cut bigger like a big oval, since nine inch lenses are slightly higher off the deck and slightly farther apart.
| Back to top |
jbmeyer13
Link Posted: Mon May 14, 2012 3:32 pm Post subject: |
What I meant, was how do you cut (what tools) so that you don't destroy the thing?
| Back to top |
Link Posted: Mon May 14, 2012 5:45 pm Post subject: |
I have not modified one, a Corvette shop could handle it.
| Back to top |
J Kildare
Link Posted: Mon May 14, 2012 7:38 pm Post subject: |
I used a unibit ( a 7/8 tapered drill bit ). I drilled a couple of holes and then used a saber saw with a fine blade, it's tricky unless you can find a long blade as I had to cut some from the front and some from the back. The length of the blade prevents you from cutting it all from one side. I made mine a vision one from a vision two. It was a lot of work as the holes are somewhat oval and no way I could think of to measure off anything. It turned out great but like I said, a lot of work. Next time I would cut out a neat oval and get some plastic car door trim for the rough cut.
| Back to top |
