Joined: 09 Nov 2008 Posts: 1956 Location: QLD, Australia
Link Posted: Fri Apr 20, 2012 12:08 pm Post subject: Why cant i select certain refresh rates with NEC internal? |
Ive been trying a few things cause i got some nVIDIA glasses today, which work flawlessly when i connect with RGB-HV, but if i connect with HDMI the way i was, im limited to the refresh rates i can select, which for some reason is getting less and less every time i try something...
What is the go here? Why is this so contrained?? What can i do to fix this? Creating a custom res doesnt work either.
Up til today, i could select ( and regularly used ) 1920x1080i @60Hz, which Windows called 30Hz... Now i can select 25Hz and thats it...
Why is this all so difficult?
Does anyone have a custom EDID i can put into Windows so this will just WORK like it should?
The projector is a Runco DTV991. I want to be able to use it with the nVIDIA glasses and see no reason why such a capable projector cant be made to work the way it should, it works with RGB-HV, why not with HDMI through the MOOME?
This is clearly not the MOOME card that is the issue here, but i think the EDID it reports to Windows is an issue of sorts.
