Convince me to go CIH! (and what size screen?)
PostLink    Posted: Mon Nov 14, 2011 9:01 pm    Post subject: Reply with quote
I agree that an AT screen with 3 identical speakers across the front is the best. It really anchors the sound in a way that I've never heard before.
We're just starting on the design phase of the entire basement and it may be a bit tighter than I thought so until that's done I'm not sure I want to lose that space. The extra 4 feet of depth means I need about 23-24 feet of depth to support an AT screen in my setup with 2 rows of seating.
The other big issue for me is that I already own fairly expensive speakers with a horizontal center (Paradigm Signature S8 left/right with a C5 center). They don't sell the S8 separately so I'd have to either (a) replace all my speakers with something completely different or (b) buy a new set of S8's (MSRP is $8K) and sell one. That would cost me many thousands of dollars as selling a used C5 probably gets you have of the original cost.
I suppose another option would be to juse use them as is with an AT screen and raise the center up to match tweeter heights with the left and rights.
That said, I'm not even sure how you'd use the left/right S8 speakers with an AT screen as they'fe very tall. They're just over 4 feet high. Putting the tweeter around mid-height on the screen would mean that some of the bottom drivers would not be behind the perforated screen anymore. They're bass drivers so I'm not sure if that would matter too much (?). You could use something like GOM material below the screen to allow these drivers to project sound out but you'd still have the bottom of the screen frame plus other fra framing material to hold everything up.
The S8's look like this:
Picture of the speakers around my screen at the old house is here: http://www.curtpalme.com/forum/album_pic.php?pic_id=690
With the extend of the basement built that is planned at this point at this point in time I'm mostly thinking of sticking with what I have for the moment in terms of screen and audio and just getting a different projector (like the RS45). In a few years I may re-assess and end up reframing part of the front wall or something if there's room.
My head's been reeling with all the possible changes. I feel like I'm juggling a million things. The HT is only one part of the basement too! Wink
Keep the ideas coming however!
PostLink    Posted: Tue Nov 15, 2011 2:45 am    Post subject: Reply with quote
Kal maybe there is someone else that needs a single S8? You could put an add here or over on AVS, Audiogon/Videogon or any home theater forum to go in 50/50 with you .
PostLink    Posted: Tue Nov 15, 2011 3:40 am    Post subject: Reply with quote
Always possible, but again, it would still cost me thousands of dollars plus the cost of the AT screen (and so on).
That said, you never know. Once the whole basement layout starts to solidify I'll have better idea of what's even possible.
benareeno
PostLink    Posted: Tue Nov 15, 2011 4:49 am    Post subject: Reply with quote
Kal,
please don't interpret this as me trying to antagonize...but do you really feel you are getting your money's worth with those speakers in a HT environment? My 3 B&W 602's are nothing crazy...but man they sound good...really, really good. And not likely because they are B&W 602's...but moreso because of the config. I've only heard a few systems that I thought sounded notably better. Any system with a horizontal center just doesn't sound good...it could be debated until the other debater gets 3 identicals...why not buy 2 more of your center channel speaker? That would give you 3 identical up front in an MTM and you could use multiple subs and really make that room sing...I mean, really!
I have 5 602's in my little basement...the sound is so freaking sweet...especially a vocal coming right out of the actors mouth.
And don't be surprised to find a single for sale...seems to happen more than we think. I waited patiently for the right single 602 to come up for sale, and sure enough...it did!
and...why do you need 4 more feet? I think I built my wall out 18 inches and that offered me plenty of real estate to make it happen.
I also think your speakers would sound fine behind a screen...just align the framing material between the 2 bass drivers.
PostLink    Posted: Tue Nov 15, 2011 1:36 pm    Post subject: Reply with quote
I was happy with the previous setup in my limited space and walls/bar with reflection points. Perfectly 100% optimized? I'd say no. I listened to a bunch of speakers including the Paradigm Studio 100's which is a line below the Signature. Just wasn't as good. I was quite surprised at the difference actually.
I prefer vertical setups like the left/right. 3 identical is indeed the best. I never thought we'd move houses and we never had the room to do AT at the old house so I bought this sort of setup (vertical left/right, horizontal center) figuring that's what I'd use forever in the same room.
I wouldn't get 3 centers across as I find center the weakest. I'd replace the center with another left/right vertically oriented speaker if I was going to go AT.
I may still go AT, but likely not at first. Maybe a few years down the road. Again, reason being that we need to put the money into the basement build first.
If I had nothing and was starting over from scratch in this new basement I'd likely go AT from the start and use more built in identical speakers all around, not in-room. I wouldn't care about finish or looks of the speaker. Possibly Triad or something? Who knows. I think right now it makes sense to just keep using the ones I have and see how it works out for now. I know it won't be ideal. The amount of money I'll save by reusing instead of selling and going a different direction will pay for the basement bar. Wink
The S8 speakers are 20.5" deep. Give them another 6+ inches between the front and the screen and then at least another 6-12 inches in the back and you're up to 35-40 inches. So maybe 3 feet would be ok, but then there's the framing too.
benareeno
PostLink    Posted: Tue Nov 15, 2011 7:49 pm    Post subject: Reply with quote
I was suggesting that because you would then orient the center speakers vertically...they will sound better vertically. And many believe a MTM vertical config is best for theater. Is the center speaker an MTM design?
I bought the screen material for 80 bucks, shipped...I built a wall for about 20 bucks out of 2x3...stapled the screen to the studs and voila...i'm rocking an AT screen for a small outlay of cash. I could put casing around the screen at some point to give it a finished look, but the overall investment is not large.
PostLink    Posted: Tue Nov 15, 2011 8:00 pm    Post subject: Reply with quote
This the center speaker:
It's 81 lbs and curved on the sides and top so putting it vertically would be challenging (though nothing's impossible).
I have it on the optional stand (sand filled, bolted to the speaker, spiked feet to the floor):
benareeno
PostLink    Posted: Tue Nov 15, 2011 8:32 pm    Post subject: Reply with quote
I see your point...those things are massive!
And they probably wouldn't fetch much on the used market...or would they?
there is a huge amount of buzz in the DIY speaker community about compression drivers (horn tweeters) and controlled directivity. I almost went that route...but figured I just wouldn't have the time to build them. But I have no doubt that they would sound great...and very dynamic and clean (for movies). I bought a pair of JBL 8350 surrounds with horn tweeters, and indeed...they play loud and clean(no distortion). But...I decided on 5 identicals.
Right now I am operating with no sub...but yet, I have bass sources high and low, and front to back...I just don't get that last octave. But the room is so small that I don't think the wavelength of the last octave would be all that audible anyhow.
PostLink    Posted: Tue Nov 15, 2011 8:42 pm    Post subject: Reply with quote
I don't think so. Not what they're worth, or anywhere near what I paid. I'd probably take a huge loss. Of course, I'd try and do the same with the matching S8 I'd buy since mine are all "version 1" and the new ones you'd buy today are "version 3". There have been subtle changes over the years.
It's not supposed to be. You're supposed to feel it in your gut. Wink
greg_mitch
PostLink    Posted: Wed Nov 16, 2011 7:46 pm    Post subject: Reply with quote
I can second the CDs and controlled directivity...
Very, very nice.
My HT Build Thread - Oak Knoll Cinema
RVonse
PostLink    Posted: Mon Nov 21, 2011 2:21 am    Post subject: Reply with quote
Kal,
Why are you picking the JVC projector over something with more contrast and brightness like a used 3 chip 720p DLP? Another words something with much more light horsepower that could probably be had for the same price? I ask this because I have been getting the CIH ich myself but I am very concerned I could be satisfied a JVC or any other of the Sony DILA's are bright enough to do this right. Even though I am used to seeing darkness with a crt setup.
benareeno
PostLink    Posted: Mon Nov 21, 2011 8:24 am    Post subject: Reply with quote
rvonse....I think you're onto something here. And I totally agree.
PostLink    Posted: Mon Nov 21, 2011 1:48 pm    Post subject: Reply with quote
RVonse wrote:
Kal,
I prefer contrast ratio over light output.
benareeno
PostLink    Posted: Mon Nov 21, 2011 7:34 pm    Post subject: Reply with quote
No jvc can do natural and accurate color like a high end dlp...and ansi contrast can't be beat.
On off and overall blackest black might not quite be there...but that just doesn't tell the tale of what an overall great image is. It is high contrast and accurate primary colors....and something like this has it...big time.
Having watched a dlp for brighter content...it is simply better than a crt. And when I switch back to crt, the brighter scenes tend to look washed out.
http://www.projectorreviews.com/runco/lightstyle_ls5/index.php
PostLink    Posted: Mon Nov 21, 2011 7:49 pm    Post subject: Reply with quote
Good point. I was talking on/off contrast, not ANSI (interscene on/off contrast).
I've seen a lot of digitals over the years but it's been quite some time since I've seen a properly set up recent digital in a nice environment (last one was a first gen JVC DILA - RS1 or RS2 I think). At the time the other digitals I saw (DLP, LCD) just weren't there yet.
I'll certainly have to do more research (and viewing!) before I bite the bullet.
Once I get closer I'll have to start hitting up some local HT guys to see what they have installed... Unless things have changed in Ottawa, none of these stores have anything worth writing home about (which mostly speaks for projector setup, not the equipment).
WTS
PostLink    Posted: Tue Nov 22, 2011 3:31 am    Post subject: Reply with quote
If I could find a DLP where I didn't see rainbows I would be tempted to buy it, unfortunately I have only seen one so far and that was the Runco Q750i and they don't come cheap. Even the LS5 I could see rainbows on and they are a $7K unit. I will say those two Runcos sure had a lot of pop to the pq and very clean looking, I wasn't bothered by the so called lack of deep blacks. I watched -The 5th Elemant and Dark Knight and they both looked great, I had no complaints.
Walter
RVonse
PostLink    Posted: Tue Nov 22, 2011 9:53 pm    Post subject: Reply with quote
I'll be very interested in your opinion especially since I know we share a very similar background (starting off with the Barco 800 long ago).
As for myself, I have not seen very many digitals at all yet so I certainly do not know anything yet. But what I can say for sure from my own experience with an experimental 808 stack, is that gamma really brings contrast to the table. A picture like that is what really turns me on. And obviously people like overclocker and in particular Art Sonnoborn must think like I do or they would not have solved a big screen issue by invested in stacks and ending with a 3 chip DLP.
Its just too bad there isn't an easy way to compare digitals. Do you happen to know of anywhere they have a digital projector list like you made up for crt?
RVonse
PostLink    Posted: Tue Nov 22, 2011 9:57 pm    Post subject: Reply with quote
macgyver655 wrote:
And I think it was you that brought up the 3 chip vs JCV discussion.
No it was me.
I did not mean to start a cat fight either. Just wanting to learn more about this because I know I am ignorant especially with the digitals that I used to pretty much shun.
But I will shut up now.
PostLink    Posted: Tue Nov 22, 2011 10:07 pm    Post subject: Reply with quote
I don't. I'm not sure it would be 100% possible either given the different strengths/weaknesses of the different digital technologies (DLP vs LCD vs LED vs LCOS). One person's likes may be different than anothers.
The CRT list also has a bunch of caveats to it but it's somewhat easier to make since CRTs all stem from the same base technology that shares common traits and display qualities that the manfacturers then build upon to varying degrees.
Even with CRT you can get arguments where nobody's right or wrong: Some brands will add (say) tinted c-elements or glycol to get more accurate primary colours at the expense of light output while others will go for light output first. Nobody's right.
dropzone7
PostLink    Posted: Wed Nov 23, 2011 2:05 pm    Post subject: Reply with quote
Kal, have you considered anamorphic lenses at all? Do you think you would start off zooming or get a lens right away?
"Coffee is for Closers."
Page 8 of 9
