| Author |
Joined: 12 Jan 2007 Posts: 12854 Location: West Seneca NY
Link Posted: Fri Mar 20, 2009 1:19 pm Post subject: |
| waterlily wrote: | Hi Nashou,
Did you ever find if the outer lens you removed is the same across the different HD10s ?
I have a scratched outer lens on one of the HD10s and was curious if the outer lens could be interchanged between the different HD10 flavors  |
No I have not gone further with this. At some point i probably will after i get my theater up and running, I am putting the 9 inch set up on the back burner for now and am just going with my bran new 8 inch Pj's.
| Back to top |
waterlily
Link Posted: Sat Mar 21, 2009 12:42 am Post subject: |
Enjoy them, they look like awesome units by all you posted!!!
I am trying to find something to have the proper leverage on those two notches on the lens edges.
I have a spare lens so I am going to give it a go.
I will post what I find.
Thanks for replying
| Back to top |
WESTW
Link Posted: Tue Apr 07, 2009 8:24 pm Post subject: |
I have a Sony 1272. I see there is a set of Pt-43 color corrected lens on ebay. Would I gain anything by switching out mine for these?
Bill
| Back to top |
Joined: 06 Mar 2006 Posts: 12342 Location: Ottawa, Canada
Link Posted: Wed Apr 08, 2009 12:36 am Post subject: |
| WESTW wrote: | | I have a Sony 1272. I see there is a set of Pt-43 color corrected lens on ebay. Would I gain anything by switching out mine for these? |
All CRT projector lenses are "colour corrected". What people look for are "Colour filtered" red and green lenses: ones that have a red or green tint when you look through them.
Your 1272 has tinted glycol in front of the red/green tubes so you get the same affect. Don't change a thing.
Read this for more info: http://www.curtpalme.com/Tinting_Glycol1.shtm
| Back to top |
Kiev Savoie
Link Posted: Fri Apr 10, 2009 8:10 pm Post subject: |
VPHL-10 HACC - PT43 :
VPHL-10 HACC - PT65 :
HD8 - A :
HD8 - B :
HD8 - M :
HD 145 :
HD 18 : equipent les Sony G70
this appears to be the gamut of 8" (non-LC?) lenses.
here is a picture of the pt-43's that were spoken of. they indeed are color corrected only. how do they rank versus HD-8.s for optical quality? versus HD-145's? again never mind color filtering, how well do they project a clear image? I assume they must not be to great since no one is mentioning them. seems like HD-145's and HD-10's are well respected though.
| Description: |
| Filesize: |
28.28 KB |
| Viewed: |
5715 Time(s) |
| Back to top |
kschmit2
Joined: 09 Mar 2006 Posts: 1141 Location: Heidelberg, Germany
Link Posted: Sat Apr 11, 2009 6:31 am Post subject: |
HD-10 are 9" LC lenses, HD-18 are 8" LC lenses
| Back to top |
Kiev Savoie
Link Posted: Sat Apr 11, 2009 2:48 pm Post subject: |
oh right, thanks
| Back to top |
Decibel
Joined: 31 May 2007 Posts: 501 Location: Roma - Italia
| Back to top |
Link Posted: Thu May 14, 2009 4:51 am Post subject: |
Has anyone else used this formula to clean lenses ?
Guy Kuo
Dry air blown across the lens. If that isn't enough, William Phelps described his cleaning solution....
1 drop dishwashing detergent (not soap!)
(or Kodak Photoflo if you have it)
1/3 cup 99% Isopropyl alcohol
1 2/3 cup distilled water
It works very well indeed and does not harm the lens coatings. It's dirt cheap to make to boot. Cheap enough to use on your car windows. You won't believe what using an optical cleaner on a car window will achieve. Windex is residue city by comparison and should NOT be used on your projection lenses for fear of the ammonia dissolving the anti-reflection coating.
Don't get overzealous about cleaning. Every time you clean the lens, you will create some minor scratches. In other words, clean when cleaning does more good than harm.
The above solution can be misted on and wiped off with a soft lint-free cleaning cloth. Use each portion of the cloth only one pass. Start at the center and work outword. You will need to lightly buff until dry or else there will be visible residue.
Another cleaning product I very much like is Formula MC-1. I was turned onto this by Steve Smith. It leaves absolutely the cleanest lens surface I have ever seen. Use as a last step. Just a few drops do the job. The lens will appear to fog over as this dries. Buff the "fog" off and the lens will be cleaner than it ever has.
In either case, never never grind dirt back into the lens. Remove as much dust as possible with dry, compressed air. Very very lightly dust with a CLEAN soft brush. It is so easy to scratch the lens with a slightly soiled brush. Don't wipe a dirty lens while it is dry. Use a cleaning solution to loosen and lift the debris onto a clean soft lens cloth.
Be enthusiastic in throwing out multiple cleaning cloths. You're trying to preserve the lens, not the cloths.
__________________
Guy Kuo
Director - Imaging Science Foundation Research Lab
Video Test Design - Ovation Multimedia / Home of OpticONE Colorimeter, AVIA and Avia PRO
Tom.W is online now Report Post Edit/Delete Message
| Back to top |
| Back to top |
Decibel
| Back to top |
AnalogRocks Moderator
Joined: 08 Mar 2006 Posts: 20968 Location: Toronto, Ontario, Canada
Link Posted: Tue May 19, 2009 3:59 pm Post subject: |
| Tom.W wrote: | Has anyone else used this formula to clean lenses ?
Guy Kuo
__________________
Guy Kuo
Tom.W is online now Report Post Edit/Delete Message |
I've used it. It does a nice job it's just trickey not to leave residue behind. I sugest the final wipe be done with Kodak lens tisues. It takes alot of them.
| Back to top |
jcarson
Joined: 28 May 2009 Posts: 25 Location: Melbourne Australia
Link Posted: Fri May 29, 2009 12:12 am Post subject: |
I'm new to the whole CRT PJ scene but I've just bought a Sony 1272QM. I'm so new I haven't even set it up yet, all I've done is buy stuff! here's my issue:
Installed in the 1272 are HD8-M lenses, the coating looks pretty scratched/worn, I've got 3 orignal HD8's (the all glass/aluminium ones). Before I bolt this thing to the ceiling am I better off keeping the scratched HD-8M's or swapping them for the clean original HD8's?
_________________ Sony 1272QM, Sony G70, DVDO VP30, Moome HDMI 1.3
| Back to top |
| Back to top |
jcarson
Link Posted: Fri May 29, 2009 9:02 am Post subject: |
Good idea - i wondered if it was possible to work on these PJ's upside down. Is it worth even swapping lenses though? Are scratched HD8-M's better than the all glass HD8 originals?
| Back to top |
RobertMfromLI
Joined: 29 Jun 2009 Posts: 114 Location: West Islip, NY
Link Posted: Mon Jun 29, 2009 3:18 am Post subject: Barco Graphics 500? |
Hey all,
I have a Barco Graphics 500 with Noritar 14X lenses. I've tried the Lens Program but find no reference to this model or a similar one using those lenses. A while back, I found specs on this model (cant seem to find them anymore) that showed it's throw distance, max screen size, etc - but the listings were not for the version equipped with these lenses.
Does anyone have any information about this combination? Or an older version of the Lens Program that includes the Graphics 500 and Noritar 14X lenses?
And one last question... will these lenses work on a Barco Graphics 800? I am guessing no as the CRTs are different sizes than the ones in the 500 - but figured I would ask just in case.
Robert
| Back to top |
virusc
Link Posted: Thu Jul 02, 2009 2:19 pm Post subject: |
I have some noritar 14x aswell and tried them on a 500. they are made only for very small screens and were often found in the 400/600 rear barco projection monitors aswell as some earlier projectors. I have the specs somewhere but can't find it right now. I remember 3-5' foot screen max on them. I would set up on table and turn lense focus to middle to test throw distance. Because of the small screen I remember the toe of the lenses causing focusing problems along with straining the convergence on the bd500. Also the schiemflug gave me problems with the smaller screen size. The best noritar lenses were the 27x in my opinion. You cannot use these lenses with a 800 unless you make/buy adaptors. 800 is made for hd-8 lenses
| Back to top |
RobertMfromLI
Link Posted: Thu Jul 02, 2009 11:32 pm Post subject: |
| virusc wrote: | | I have some noritar 14x aswell and tried them on a 500. they are made only for very small screens and were often found in the 400/600 rear barco projection monitors aswell as some earlier projectors. I have the specs somewhere but can't find it right now. I remember 3-5' foot screen max on them. I would set up on table and turn lense focus to middle to test throw distance. Because of the small screen I remember the toe of the lenses causing focusing problems along with straining the convergence on the bd500. Also the schiemflug gave me problems with the smaller screen size. The best noritar lenses were the 27x in my opinion. You cannot use these lenses with a 800 unless you make/buy adaptors. 800 is made for hd-8 lenses |
Hi virusc,
Seems we are running into different scenarios... maybe because mine are mounted onto a different projector (BG500). I've done 13'-18' screens with ease (and clarity, etc) - set it at 13' simply because I was out of wall space. At the larger sizes, it was projecting onto my room door (left corner) and ceilings. Was clear enough to use the BG500/Noritar combination as a computer monitor with default text sizes being crisp and readable.
When we fired it up last week (or was it early this week? All a blur lately), we tried it on a 6' screen. Was a pain, and we gave up on it (especially since the 6' screen was just for testing).
I am wondering if the spacers that came installed with the lenses are part of the difference?
And yeah, the BG800 I just picked up last night has the HD8 lenses.... and the original(?) cheapo flimsy "plastic" covers...
Best,
Robert
_________________ Kirk's 5 Year Mission continues at Star Trek New Voyages: Phase 2
| Back to top |
jkruger
Joined: 24 Oct 2007 Posts: 2434 Location: Carlsbad, CA
Link Posted: Fri Aug 07, 2009 2:48 pm Post subject: |
I see some Delta IV lenses on ebay. What are they for?
| Back to top |
| Back to top |
