I am trying to make My VIP theater set to work with my PS3,it is working for 2d contents but when i change to 3d contents no picture black screen,even i follow all instructions like change HDMI output to automatic and change BD 1080 24 HZ TO OFF ,any thing else i have to do it in my ps3 to make it play 3d movies or 3d games, i was able to play side by side 3d movies from my ps3 on my lcd screen when the vip set wasn't connected, but when connect and press p1 button no screen at all, i am using firmware 3.55 which know to play 3d contents, my vip theatre working well with my dreambox HD receiver.
Link Posted: Mon Jul 11, 2011 11:48 am Post subject: Re: help VIP Theater with PS3 ?
I'd like to know your installation configuration.
Are you connected like this? PS3>VIP>Display Device
Or, are you going through a AVR or HDMI switcher first? What kind of display?
Either way, outline your connection schematic with the right arrows like I did above.
Also, if you have short HDMI cables available, connect as illustrated above and use this guys
instruction:
"Works every time for me! PS3 needs the latest firmware to output Bluray 3D. Then you have to run the auto config. Don't do it manually. You know you did it right when it says you have a 3D display and to set the screen size which is for 3D game playing. Set your audio up the way you want it too output. You should not have to use the mode button and especially not if you have Directv. Everything is auto switched. I am running my PS3 through a DVDO Duo and it works great."
Avoid firmware 3.65 for now and try either 3.61 or 3.66, but do the aforementioned first before changing firmware.
Link Posted: Mon Jul 11, 2011 5:21 pm Post subject: Re: help VIP Theater with PS3 ?
instruction:
Thank you i could make it work only for movies as follow:
i connect PS3> VIP> display Device
but i changed HDMI not to automatic but to custom and i removed click on 1080p and it works with all AVCHD movies on my external HDD connected to PS3,but rthe problem now for games when i start 3d games like stardust hd it start but the 3d led light in the vip is off, and when i press p1 button the screen become blurred.
Link Posted: Tue Jul 12, 2011 11:30 am Post subject:
Thank you now every thing work movies and games i changed HDMI output to automatic but i switch BD 1080 24 HZ to automatic not to off as they mentioned in the manual and every thing work good with me.
Link Posted: Tue Jul 12, 2011 1:24 pm Post subject:
