sk3467
Link Posted: Fri Jun 17, 2011 7:40 pm Post subject: Moome EXT V3 and Oppo BDP-93 |
Hello,
This is my first post. I am mulling over the awful truth about DHCP via HDMI, and it is killing me!
Does anyone know if the Moome EXT V3 will work with the Oppo BDP-93? HDMI Out to the Moome, YPrPb out from the Moome? I won't be playing 3D material.
Also, it appears the Moome EXT V3 uses a VGA to YPrPb adapter. Does this come with the EXT V3?
Thank you,
Scott
sk3467
Link Posted: Fri Jun 17, 2011 7:46 pm Post subject: |
Forgot to add this would be used for 1080P only... (hopefully).
Ron W
Link Posted: Sat Jun 18, 2011 7:04 pm Post subject: Re: Moome EXT V3 and Oppo BDP-93 |
sk3467 wrote: | Hello,
Thank you,
Scott |
No problem with the Oppo 98 working with the V3, however, unless things have changed, the Moome products don`t include the adapters. No problem for 1080p either but where the limitation will occur is in the display in that the majority of them won`t accept a 1080p signal over component, only 1080i. Unfortunately, 1080p is generally restricted to HDMI connections.
