royuk
Link Posted: Sat May 21, 2011 8:06 am Post subject: using with a CRT projector |
I wish to have 3D running on my Barco 1209s CRT pj. At present 2D is perfect without the use of a scaler/video processor like a Lumagen. Connection is with a HDfury 3. So without wishing to spend several thousand pounds to have 3D and the need for a Lumagen how does 3D-Theatre compare on CRT vs digital projector. And without a video processor can i still use the various 720/1080p resolutions?
This could be what i'm looking for, a cheap and simple plug and play way to 3D
roy
Link Posted: Sat May 21, 2011 1:17 pm Post subject: |
I don't have my 3D-Theatre yet (it's on the way) so I can't comment. From what I hear at 60Hz it looks exactly like what commercial IMAX 3D (film) theatres look like: A little bit of flicker but normal. 120Hz doesn't have flicker.
If your Barco 1209 (you didn't mention if its a data or graphics) can do 720p/120 then run it at 120Hz. That requires 91Khz scanrate which higher end 8" and 9" CRT projectors will handle without any problems.
Quote: | And without a video processor can i still use the various 720/1080p resolutions? |
I don't understand this question. The 3D-Theatre output is 720p/60 or 720p/120 when a 3D signal is passed through. If you're watching 2D content it just gets passed through without being changed at all so any resolution in the world is possible.
royuk
Link Posted: Sun May 22, 2011 9:25 am Post subject: |
It's a 9 inch graphics projector.
I took another look at your reply to 'pitou' regarding 'down conversion to 720p' and understand it now. I was looking at the various 3D 720/1080 inputs and taking this as the output resolution to the pj. But infact all you can get of use in reality is 720/60 or 720/120 as ouput from the 3D theatre device. Thats enough for 3D now as i understand it, especially without the extra expense and hassle for anything more.
When you get your 3D theatre device can you please let us know, in my case especially regarding use with a CRT.
thanks, roy
Brian Hampton
Link Posted: Sun May 22, 2011 10:17 pm Post subject: |
So excited to hear you will be trying these products with CRT FP.
Makes me wish I still had the G70,... I can only imagine how amazing it would have been to view it with 3D content.
Can't wait to hear from members who get the chance to try it out.
-Brian
HighDefMike
Link Posted: Tue Jun 21, 2011 3:51 am Post subject: |
kal wrote: | I don't have my 3D-Theatre yet (it's on the way) so I can't comment.....Kal |
kal, have you received yours yet? I'm also interested in hearing how it looks/works with CRT projectors.
Rolf Hult
Joined: 08 Mar 2006 Posts: 84 Location: Sandnes, Norway
Link Posted: Tue Jun 21, 2011 4:22 am Post subject: |
I'm also waiting for my 3d-theater for use with my M8500 (P43 and HD144..+mome hdmi).
The Canadian postal are in strike, but should be solved "any day soon"
_________________ Rolf Hult
My HT
Link Posted: Tue Jun 21, 2011 2:03 pm Post subject: |
HighDefMike wrote: | kal wrote: | I don't have my 3D-Theatre yet (it's on the way) so I can't comment.....Kal |
kal, have you received yours yet? I'm also interested in hearing how it looks/works with CRT projectors. |
I got mine now and need to spend some time getting it hooked up. I had some of the cables I needed packed away unfortunately because we're moving... I've now got them back so hope to test it out in the next day or two.
I did try it quickly on a 30" 60Hz LCD computer monitor I have and it had some issues so I'm trying to figure out what the problem is and I seem to be the only one with the problem.
SgtVideo
Link Posted: Tue Jun 21, 2011 3:49 pm Post subject: |
kal wrote: | HighDefMike wrote: | kal wrote: | I don't have my 3D-Theatre yet (it's on the way) so I can't comment.....Kal |
Kal |
The computer monitors and their graphics modes introduce a new set of variables that create problems for the VIP product that would not be present on traditional display devices. This doesn't mean it isn't possible but the user may have more difficulty in accomplishing it.
One guy was upset his PC LCD wouldn't work with his Displayer in 120hz mode. After reviewing the timings for his particular model of monitor it was only capable of 120hz in Analog mode. His digital mode was limited to 85 hz which worked at the 60hz setting. So 120hz has to be right kind of 120hz or no go.
Best thing one can hope to do is take the monitor manual and see which resolution and timing combinations get passed via DVI and HDMI.
G'day
Barry
Joined: 01 Feb 2007 Posts: 186 Location: Los Gatos , Ca.
Link Posted: Fri Jul 08, 2011 12:05 am Post subject: 1209 Graphics PJ with LumagenHDP |
This 3D-VIP looks like the perfect tool to add 3D to my system. (cheaply) Just to be sure I know the 1209 will handle the 120Hz fine, but I suspect I will path the signal: iMac home theater computer > VIP > LumagenHDP (reconvert to 1080P cuz that is where it is set) > 1209.
Any reason to suspect a conflict? I can drop back to 720P on the Lumagen if necessary. I run the audio directly from the iMac but given that there is only one frame delay that should not mess the sync up. Take out teh VIP and that is how I run Blu Ray over DVI/HDMI cable now. Look doable?
_________________ Addicted to buying cool used expensive toys...(especially CRT projectors) Barco 1209, 1208 and Elektra Espresso Maxi2 most recent additions.....
Barry
Link Posted: Fri Jul 08, 2011 12:54 am Post subject: |
Thanks Kal, I think I can live with that.....BTW, in terms of content, I just talked to Netflix and tehy will be adding 3D to the line up this mid-Summer ....now I will have to re-rent and rip a whole bunch of movies all over again...
wildchild22
Link Posted: Fri Jul 08, 2011 1:14 am Post subject: |
keep in mind 1080p 3d is only 1080p@23.976 left and right so=1080p@47.952
That is what the radiance tell me anyways from my 3d bluray player.
EricL
Link Posted: Tue Aug 23, 2011 2:52 pm Post subject: |
I was looking at the 3d theater, and the install manual says it supports
720p60 Frame packing, Side-by-Side, Top-and-Bottom
720p50 Frame packing, Side-by-Side, Top-and-Bottom
720p24 Frame packing, Side-by-Side, Top-and-Bottom
720p25 Frame packing, Side-by-Side, Top-and-Bottom
720p30 Frame packing, Side-by-Side, Top-and-Bottom
1080i60 Side-by-Side
1080i50 Side-by-Side
1080p24 Frame packing, Side-by-Side, Top-and-Bottom
1080p25 Frame packing, Side-by-Side, Top-and-Bottom
1080p30 Frame packing, Side-by-Side, Top-and-Bottom
Is that incorrect?
dvh99
Link Posted: Tue Aug 23, 2011 3:39 pm Post subject: |
kal, have you used the 3d theatre and if so how is the quality of this device and what resolution are you running.
cheers
dennis
Link Posted: Tue Aug 23, 2011 4:21 pm Post subject: |
Hi Dennis,
Thanks for the reminder. I just finished setting up my "temporary" home theater in the unfinished basement of the new house (we just moved in a few weeks ago) and haven't had a chance to try it yet. I'll dig it out and see.
Running 720p/120Hz requires a CRT projector that has a max horiz scanrate of at least 90-91Khz which means a reasonably good graphics grade projector. See here: http://www.curtpalme.com/PJSpecs.shtm
My Zenith 1200 scans to a maximum of 75Khz horizontal scan rate so I'm forced to use 720p/60Hz which means in bright scenes the flicker will be noticeable to most people and may prove annoying to some people. How much this annoys you depends on how sensitive someone is to flicker. I probably won't like it myself but that's just me. (I'm going by the fact that when 48Hz refresh was all the rage about 6-8 years ago I didn't like it because of flicker).
If your projector can do 720p/120Hz then each eye gets 60Hz which means there shouldn't be issues. I know Rolf Hult loves it on his higher end Marquee. See: http://www.curtpalme.com/forum/viewtopic.php?t=27189
Rolls-Royce
Link Posted: Wed Aug 24, 2011 6:59 am Post subject: |
EricL wrote: | I was looking at the 3d theater, and the install manual says it supports
Is that incorrect? |
Eric, those are the resolutions it accepts as input. It only outputs 720p/60 or 720p/120.
EricL
Link Posted: Wed Aug 24, 2011 11:13 am Post subject: |
Rolls-Royce wrote: | EricL wrote: | I was looking at the 3d theater, and the install manual says it supports
Eric, those are the resolutions it accepts as input. It only outputs 720p/60 or 720p/120. |
Hate to say it, but that makes,even less sense. This box does scaling and frame rate conversions at that price? Going from 1080p/25 to 720p/60 isn't exactly a light task for a sub $500 piece of equipment
EricL
Link Posted: Wed Aug 24, 2011 12:58 pm Post subject: |
just to be clear, I typed that earlier response from my phone and it wasn't complete. My issue/question is why if they can do frame rate and resolution conversions like that would they clip themselves off from the european market entirely by not outputting the PAL 720p/50 and 720p/100 as well? It doesn't quite make sense. Not arguing that it lacks the capability, but it doesn't make sense, and i'd think that taking 720p/25 or 50 input and outputting it at 720p/50 or 100 would be childs play.
