Rolls-Royce
Link Posted: Thu May 19, 2011 12:34 am Post subject: Would the 3D Theatre box work with the Moome FullHD V2? |
After reading a bit about the 3D Theatre product today, it appears that the box essentially takes 3d-formatted input from a variety of sources and outputs it in formats that virtually any HD display can accept. Since it has a VESA port for glasses emitters, and its video is compatible with older HD sets, I'm thinking/hoping that I wouldn't need to swap my Moome FullHD V2 for the newer V3 in order to use the Theatre with my existing CRT and LCD HD displays. Am I on track here?
Link Posted: Thu May 19, 2011 1:01 am Post subject: Re: Would the 3D Theatre box work with the Moome FullHD V2? |
Rolls-Royce wrote: | After reading a bit about the 3D Theatre product today, it appears that the box essentially takes 3d-formatted input from a variety of sources and outputs it in formats that virtually any HD display can accept. Since it has a VESA port for glasses emitters, and its video is compatible with older HD sets, I'm thinking/hoping that I wouldn't need to swap my Moome FullHD V2 for the newer V3 in order to use the Theatre with my existing CRT and LCD HD displays. Am I on track here? |
You're 100% on track.
Rolls-Royce
Link Posted: Thu May 19, 2011 1:07 am Post subject: |
I was hoping so. Thanks, Kal!
Ron W
Link Posted: Thu May 19, 2011 9:37 pm Post subject: Re: Would the 3D Theatre box work with the Moome FullHD V2? |
kal wrote: | Rolls-Royce wrote: | After reading a bit about the 3D Theatre product today, it appears that the box essentially takes 3d-formatted input from a variety of sources and outputs it in formats that virtually any HD display can accept. Since it has a VESA port for glasses emitters, and its video is compatible with older HD sets, I'm thinking/hoping that I wouldn't need to swap my Moome FullHD V2 for the newer V3 in order to use the Theatre with my existing CRT and LCD HD displays. Am I on track here? |
Kal |
One further question re: AVR/Pre-Pros and the 3D Theater box. If one was using an AVR/Pre-Pro as the usual A/V switcher, in order to pass the signal through properly, would the user need one of the newer 3D compatible units?
Link Posted: Thu May 19, 2011 9:41 pm Post subject: Re: Would the 3D Theatre box work with the Moome FullHD V2? |
Ron W wrote: | kal wrote: | Rolls-Royce wrote: | After reading a bit about the 3D Theatre product today, it appears that the box essentially takes 3d-formatted input from a variety of sources and outputs it in formats that virtually any HD display can accept. Since it has a VESA port for glasses emitters, and its video is compatible with older HD sets, I'm thinking/hoping that I wouldn't need to swap my Moome FullHD V2 for the newer V3 in order to use the Theatre with my existing CRT and LCD HD displays. Am I on track here? |
Kal |
One further question re: AVR/Pre-Pros and the 3D Theater box. If one was using an AVR/Pre-Pro as the usual A/V switcher, in order to pass the signal through properly, would the user need one of the newer 3D compatible units? |
No. There will be exceptions (because of the horrible mess we call HDMI) but generally speaking even HDMI 1.0 devices can be used.
I updated the 3D-Theatre FAQ with a ton of questions like this. Give it a read - it's about 1/2 way down the 3D-Theatre page here: http://www.curtpalme.com/3DTheatre.shtm
Like always, I update the contents as the information gets refined to (a hopefully somewhat) clear picture for everyone.
