Link Posted: Wed Apr 27, 2011 4:47 pm Post subject: Hey Powerstrip has an orbit function |
http://forums.entechtaiwan.com/index.php?topic=1019.0
Beginning with Build 430, PowerStrip includes a hardware "orbiting" function that can help prevent screen burn-in. To enable this function:
1. PowerStrip menu > Options > Hotkey manager
2. Scroll thru list of functions and select "Toggle burn-in protection"
3. Assign the hotkey of your choice to this function
By default the function will move the screen 1 line every minute. If you have a graphics card that supports pixel based horizontal adjustment, the screen will also be moved 1 pixel horizontally, for a circular clockwise effect: 12:00, 1:30, 3:00, 4:30, 6:00, etc.
Now to configure the orbiter beyond the defaults:
1. Close PowerStrip if its running
2. Use Notepad to open the pstrip.ini file in your PowerStrip folder
3. Add the following lines:
[Global Options]
FlipIcons=0 ; reverse sorts desktop icons if set to 1 (Build 464 onwards)
AutoOrbit=1 ; enables the orbit automatically when PS starts
OrbitSpeed=60 ; number of seconds between screen movements
OrbitVertically=1 ; number of lines to move vertically
OrbitHorizontally=n ; number of pixels to move horizontally - defaults to 1 for Radeon, Parhelia, Kyro, and 0 (disable) for NVidia, SiS, et al., simply because the minimum for these latter GPUs is 8 pixels
4. Save back to disk
5. Restart PowerStrip
[/list]
Again: this runs in a separate idle priority thread so there should be zero impact on performance, and because the screen adjustments are between PowerStrip and the GPU directly, it should not interfere with other Windows or display driver functions (like screen savers).
Rik Wang
Administrator
EnTech Forums
holdenkicks
Link Posted: Tue Jun 07, 2011 10:59 pm Post subject: |
thats great, thanks for the heads up
_________________ Barco Graphics 808s, ceiling mounted front projection,
VideoGrabber
Link Posted: Tue Aug 07, 2012 11:21 am Post subject: |
simply because the minimum for these latter GPUs is 8 pixels |
I wonder if you set the range higher than 1, what path it would follow? E.g., v=h=4. Does it step each by 1, and traverse a clockwise circular motion? Or walk across then down, and back up again? Does it even matter?
For those GPUs constrained to 8x multiples, I could still see some usefulness to an auto-h orbit of -8,0,+8 that changed once per day of use.
_________________ - Tim
