calibrating cms
satish chatim
PostLink    Posted: Wed Apr 06, 2011 4:19 pm    Post subject: calibrating cms Reply with quote
As suggested in GREY SCALE FOR DUMMIES under topic COLOUR MANAGEMENT SYSTEM using EYE ONE DISPLAY LITE sensor with the 100% white window the contrast was set for a light output of 40ft lambert.The corresponding Y value was 147.Using 100% red window the colour was supposed to be adjusted to get Y value which should be 21% of above Y value of 147 ie 31.47.But this could not be achieved even by increasing the colour to its maximum value.The television that i was calibrating was a 26" samsung lcd.Will be grateful if you tell me where i am going wrong.The patterns were from AVS HD 720 colour hcfr window pattern.Thank you.
ChrisWiggles
Opinionated SOB
PostLink    Posted: Thu Apr 07, 2011 1:11 am    Post subject: Re: calibrating cms Reply with quote
The % target is really a bad idea. The % depends on accurate chromaticity, otherwise you have to recalculate your % target.
Recommend you stick to using colorbars properly which is reliable and accurate.
I don't recommend setting user color 'saturation' using this % method unless you know what you are doing and you have an accurate meter to verify accurate display chromaticity which your meter is not.
