| Author |
m2b
Link Posted: Thu Feb 03, 2011 3:21 am Post subject: Radiance Mini3D + Moome EXT-V3 = distortion... any ideas? |
Hi everyone! I hope this question is in the right forum.
I’ve been wanting to put a video processor in my system for some time and finally pulled the trigger on a Lumagen Radiance Mini3D a few days ago. It arrived today, but unfortunately I’ve been having problems feeding its output into my Moome EXT- FullHD V3.
With the Radiance in the video path, the image smoothly alternates between looking normal and being distorted by vertical waves. About every two seconds the image "scrunches up" into a wavy mess and then goes back to normal. It’s hard to describe, but hopefully this image I put together in photoshop will demonstrate:
I’m using two displays: a Sony GDM-FW900 CRT monitor and an Infocus SP4805 DLP projector. The digital input on the Infocus died years ago, so I’ve been using the Moome to convert HDMI to VGA. The Moome’s output is fed into a powered Monoprice VGA splitter that sends the signal to both displays. I tried connecting the Radiance/ Moome combo to each display directly, no change.
I’ve been using a PS3 outputting 1080p60 as a source going into the Radiance for most of my testing, but also swapped it out with an Oppo 980H outputting 480p and it didn’t make a difference. I also tried different HDMI/ VGA cables to no avail. Switching the Radiance output to 720p60 also didn’t affect anything.
My best guess as to the source of the distortion is AC line interference, but what’s so frustrating is that the picture is perfect if I take the Radiance out of the chain! Removing/ switching power strips, changing outlets, and even moving all my gear to a different circuit didn’t help.
Now, as I do not have any displays in the house with built-in HDMI or DVI, I haven’t been able to test the Radiance without the Moome in front of it. I’m going to try to see if I can test the Radiance on my neighbors’ HDMI equipped TV tomorrow.
The only other thing I can think of would be to plug everything into an AC line conditioner to see if that fixes it, but before I shell out the cash for one I thought I’d see if anyone here had any suggestions.
Thanks in advance for your input!
-Zack
| Back to top |
Joined: 25 Aug 2008 Posts: 2460 Location: Chicago USA & Berlin Germany
Link Posted: Thu Feb 03, 2011 7:13 am Post subject: |
UPDATED with GOOD news:
Just got this from Jim.
| Lumagen wrote: |
Lumagen has a hardware modification fix with more details to come. You can email support@lumagen.com for more information. Note that this only affects the RadianceMini with serial numbers ending 2000 to 2036 and only users with a CRT projector/display. |
So now everyone will be happy
Old post...
Unfortunately I think what you are seeing is jitter and this is actually becoming a known issue with the MINI and the Moome EXT. The MINI works fine with every other display device, and the Moome EXT seems to work well with most other sources. The two just don't like each other.
If this is the issue I suspect, I can say that both Moome and Lumagen are working on a fix for this issue. The MINI is the only product from the Radiance line that has this issue with the Moome EXT. The XD, XS, and XE are all fine, though they can sometimes have jitter with certain output timings. Usually tweaking the timings on the other units by a few Hz will eliminate the issue.
I have not gotten to work with the MINI yet, but I really want to test it with a Moome Sony or Marquee IFB, a Moome NEC IFB, and an HDFury version one and version three. I want to see which transcoders may or may not exhibit this issue with the MINI.
Some things you can try are the following:
1) Make sure "GENLOCK" is disabled for testing.
2) Attempt to tweak the output timings a little or a lot.
Have you tried other output modes like 1080p 72Hz or 800x1920 72Hz, or 1080p with extra Htotal pixels such as 2220? Try these and see if the issue changes at all. Don't forget that custom timings require that the clock be recalculated. You can download my clock calculator here: http://www.cir-engineering.com/bin/clock_calc.xls
Also, the worst combination for jitter timing conflicts is 1080p 60Hz input with 1080p 60Hz output. Try using 1080i input with 1080p 60Hz output. Also try 1080p 24Hz input with 1080p 60Hz or 72Hz output.
I am sorry to hear of your troubles, but I am glad you posted images that are so clear. They really illustrate the issue well.
I will alert Lumagen to this thread as well.
craigr[
_________________ *NEW JETI Specbos 1211 Spectroradiometer
Last edited by CIR Engineering on Fri Feb 04, 2011 3:12 pm; edited 1 time in total
| Back to top |
Joined: 12 Jan 2007 Posts: 12849 Location: West Seneca NY
Link Posted: Thu Feb 03, 2011 6:20 pm Post subject: |
Hmm, i had similar issues when trying to marry my Lumagen XS to my Tv-one scalers. at first i thought it was timing issues due to marquees needing a longer than 1us sync timing. I then made sure Genlock was on and those squigglies went away.
Not sure if this is anything similar but the images above were similar.
| Back to top |
Link Posted: Thu Feb 03, 2011 6:33 pm Post subject: |
| Nashou66 wrote: | Hmm, i had similar issues when trying to marry my Lumagen XS to my Tv-one scalers. at first i thought it was timing issues due to marquees needing a longer than 1us sync timing. I then made sure Genlock was on and those squigglies went away.
Athanasios |
Tom,
There is an issue in the Marquee machines that can cause a similar looking distortion. Like you said, it can occur on a Marquee if they sync timing is wrong. You could have been seeing that, or you could have been seeing Radiance jitter because I often find this distortion on XS and XE units as well. But on the XS and XE machines I can eliminate the jitter with custom timings so that the FPGA clocks don't resonate with the video signal anymore...
| Back to top |
Link Posted: Thu Feb 03, 2011 6:47 pm Post subject: Re: Radiance Mini3D + Moome EXT-V3 = distortion... any ideas |
| Lumagen wrote: |
Old post...
| m2b wrote: |
With the Radiance in the video path, the image smoothly alternates between looking normal and being distorted by vertical waves. About every two seconds the image "scrunches up" into a wavy mess and then goes back to normal. It’s hard to describe... |
Zach,
I just got off the phone with Jim at Lumagen and we discussed the issue again at length. Jim is planning to look into the Mini today to see if he can work a solution on the hardware level through adding more filtration.
...what happens is that different parts of the circuit use the same clock rates, and these actually will resonate at a given frequency. It happens that these clocks run at the same speed as the clock required for 1080p 60Hz with default timings. Since the timings are the same, they resonate off one another causing the jitter to become visible in an analog circuit.
This will also effect 720p because it is half the frequency of 1080p. In harmonics, even multiples (whole number multiples) will also resonate because even multiples are additional orders of resonance to the primary resonance frequency. So 720p multiplied by two, is equal to 1080p multiplied by one, which is also a resonance frequency. This is why you see it on 720p and 1080p with default timings...
Best regards,
Last edited by CIR Engineering on Fri Feb 04, 2011 3:16 pm; edited 1 time in total
| Back to top |
Link Posted: Thu Feb 03, 2011 6:59 pm Post subject: |
I just updated the above post so please read it again if you already have... it has more details now.
...and I am giving away some of my trade secrets... sigh
| Back to top |
dturco
Joined: 06 Feb 2009 Posts: 3749 Location: Eastern Shore Maryland
Link Posted: Thu Feb 03, 2011 7:19 pm Post subject: |
Cool Craig, I printed out that timings page in case you have a change of heart, or come to your senses?
http://www.hulu.com/firefly
| Back to top |
Link Posted: Thu Feb 03, 2011 7:38 pm Post subject: |
| dturco wrote: | | Cool Craig, I printed out that timings page in case you have a change of heart, or come to your senses? |
Yeah... I know...
I do like to keep some things in house, but this is just too important.
| Back to top |
wildchild22
Link Posted: Thu Feb 03, 2011 8:20 pm Post subject: |
If this works I maybe ordering a mini. Too bad I didn't know this before the deadline expired.
| Back to top |
m2b
Link Posted: Thu Feb 03, 2011 8:36 pm Post subject: |
Craig,
I can't thank you enough for your detailed replies! I've been doing more testing per your suggestions and here are my results.
I have confirmed that Genlock is disabled. I tried turning it to "Auto" and it had no effect (but thanks, Athanasios, for the suggestion!). I've left Genlock disabled for the rest of my testing.
I tried every available input resolution from the PS3 going into the Radiance (480p, 720p, 1080i, 1080p60, 1080p24), with the Radiance outputting 1080p60, no change. I also tried every available preset output resolution available on the Radiance with the PS3 feeding it 1080p60. The distortion is there at all output resolutions to some degree, although the size and severity of the waves varies. 540p60 has the least amount of distortion, although it is still there if I look closely.
Next I tried the custom timings you posted, and neither made a visible difference on my setup.
I appreciate very much your thorough and informative responses, thank you again!
-Zack
| Back to top |
Link Posted: Thu Feb 03, 2011 8:49 pm Post subject: |
| m2b wrote: | Craig,
I can't thank you enough for your detailed replies! I've been doing more testing per your suggestions and here are my results...
...I appreciate very much your thorough and informative responses, thank you again!
-Zack |
You are welcome, but darn I wish that had worked. Jim did not think that the custom timings would improve the situation on the MINI due to a difference in the clock between it and the XD, XE, and XS. As I said, Jim is doing some experiments today with the MINI and Moome EXT.
Either Jim will post here or I will relay what he finds (if anything).
| Back to top |
Link Posted: Fri Feb 04, 2011 3:57 am Post subject: |
I just got this from Moome after he applied Jim's fix:
| Moome wrote: |
Dear Jim:
Thanks for information, just did what you suggested, and the noise is gone...
Thanks for all help
So it looks like everything is going to be really good
| Back to top |
m2b
Link Posted: Fri Feb 04, 2011 4:24 am Post subject: |
Wow, that is fantastic news indeed!
I'll go ahead and send Lumagen an email to see if they can apply the fix to my MINI.
| Back to top |
Link Posted: Fri Feb 04, 2011 3:18 pm Post subject: |
And it's gone
| Back to top |
dturco
Link Posted: Fri Feb 04, 2011 3:25 pm Post subject: |
| CIR Engineering wrote: | | dturco wrote: | | Cool Craig, I printed out that timings page in case you have a change of heart, or come to your senses? |
And it's gone
craigr |
Bastage
| Back to top |
m2b
Link Posted: Wed Feb 23, 2011 12:38 am Post subject: |
Well, I just got my Mini back from Lumagen and it looks like the fix worked! The distortion/ noise is completely gone.
Kudos to Lumagen for addressing this problem so quickly!
| Back to top |
Joined: 06 Mar 2006 Posts: 12341 Location: Ottawa, Canada
Link Posted: Sun Sep 25, 2011 2:32 pm Post subject: |
Update: This only affects the RadianceMini with serial numbers ending 2000 to 2036. All others are not affected. Lumagen is pretty certain they have fixed this issue for everyone who might possibly be affected by it.
| Back to top |
Link Posted: Sun Sep 25, 2011 3:51 pm Post subject: |
Yeah Kal, I helped Jim with the fix way back months ago. It is absolutely 100% without doubt fixed. If you have one of the early affected serials you can send it back to Lumagen for a free fix. It had to do with jitter getting into the FPGA from the power supply due to the (at that time) new architecture of the MINI. Jim redesigned the power circuit and Patrick improved the firmware to create less jitter on the entire Radiance line.
| Back to top |
