shepardos
Link Posted: Thu Jan 13, 2011 3:31 pm Post subject: ChromaPur 2.0.3 and Radiance Testpattern? |
I use ChromaPur 2.0.3 to calibrate my JVC X3. The Radiance can be used as test pattern generator but unfortunately he picks up only the reference pattern and not the adjustable pattern.
How can tell ChromaPur that he should use the adjustable test pattern?
Shepardos
TomHuffman
Joined: 01 Jun 2010 Posts: 76 Location: Springfield, MO
shepardos
Link Posted: Fri Jan 14, 2011 9:11 am Post subject: |
Thanks Tom,
Does this release also include the Automatic-Calibration Feature or do you know when this will be released? It would also be fine if you can use 2 Meters (i1Pro & i1LT) simultaneous, rather than quit and always initials the meter again.
mechman
Link Posted: Sun Jan 16, 2011 4:10 pm Post subject: |
2.1 will be the pre-cursor to the auto calibration release. So no auto calibration with 2.1.
shepardos
Link Posted: Tue Feb 08, 2011 12:51 pm Post subject: |
Any news about the 2.1 release?
TomHuffman
TomHuffman
Link Posted: Sun Feb 27, 2011 10:12 pm Post subject: Re: ChromaPur 2.0.3 and Radiance Testpattern? |
shepardos wrote: | Hi,
Shepardos |
Shepardos:
I just tested this, and ChromaPure is generating adjustable test patterns. As you adjust the values on the grayscale/gamma or the CMS areas of the Radiance using the Radiance test patterns the readings change as expected.
What steps did you take that lead to believe that the patterns were not adjustable?
-TH
_________________ ChromaPure calibration software & meter packages at CurtPalme.com discounted prices!
