zaphod
Link Posted: Tue Jan 11, 2011 8:51 pm Post subject: screen width to seating distance ration |
THX has a 40degree recommendation or ratio of 1.37 - so for a seating distance of 8' (96") the screen width would be only 70"
that seems small, and i've been told here that it is small.
what is the screen width to seating distance ratio in your theater? if you have multiple rows, then what is it in your favourite seat?
cheerLance
Link Posted: Tue Jan 11, 2011 10:13 pm Post subject: |
Lance, the 40-degrees specification has to do with digital displays and seeing pixels. If the viewing angle gets much larger than 40-degrees, the chances of seeing pixels or screen door starts to shoot up for people with normal vision. At 50-degrees, a lot of people might see pixels even on a 1080p display.
For commercial cinema on the other hand, the 36-degree viewing angle is a minimum. In other words, the worst seat in the house should, at the minimum, have a 36-degree viewing angle.
If you think about it, many commercial cinemas' front rows are less than 20 feet from a 30-40-foot wide screen, so viewing angles approach or exceed 90 degrees, while the vast majority of the rest of the seats in the house all have viewing angles that far exceed 40-degrees!
I like a (visually) large screen and immersive image, so I sit 9-10 feet from my 8-foot wide screen (depending on whether I'm reclining or not), so 43-48 degree viewing angle for my seat. I LOVE IT. I love the immersion... I'm involved in the picture. That's what cinema, and by extension home theater, is all about, right? A big screen! The whole "tennis match" thing is totally over-rated, IMHO.
My back row is about six feet further back, or 15-16 feet, or about 28-30 degrees viewing angle. It still looks fine, but it's much less involving, and I would hate that kind of viewing angle for my main viewing position. You need a pretty big room and pretty big screen to start to accommodate THX specs for multiple rows in a home theater.
Cheers,
LOTREE
Joined: 19 Mar 2006 Posts: 401 Location: Paradise, Newfoundland
Link Posted: Wed Jan 12, 2011 2:23 am Post subject: |
In the theatre, aka livingroom, I sit at 10.5'/126" only because I'm limited by space, things can't physically get farther apart. As a result I'm throwing a 7'(84") wide/8'(96") diag image. I think it's perfect, I don't like being closer.
So, my ratio is 1.31-1.5 depending on the screen measurement you use.
Now, that being said my father's theatre with the 9500LC has an 8' wide screen and I personally like the picture WAY better sitting in the back raised row about 16' from the screen. I feel like I'm in a theatre, with a black tunnel and big screen in the end. I don't like the screen in my face, too much light, too much going on and hard to get it all in. The same reason I don't sit near the front in an actual theatre. Always, when I can, sit 3/4 way up dead center.
_________________ Zenith Pro 1200x | Electrohome ECP 4500 | Yamaha HTR-5740 | HTPC & Speaker build to follow
zaphod
Link Posted: Wed Jan 12, 2011 2:43 am Post subject: |
when i'm in a commercial theater, i usually sit so that the screen size is "pinky finger to pinky finger plus a palm" thumbs touching, fingers splayed at arms length. pretty consistent. that comes out biger that the THX. about 1.1:1 or so.
realizing (thanks SC) that the THX 1.40:1 is meant to be the *worst* that you'll have explains a lot. i bet that at the back of the theater that's what you get.
Link Posted: Wed Jan 12, 2011 3:45 am Post subject: |
zaphod wrote: | when i'm in a commercial theater, i usually sit so that the screen size is "pinky finger to pinky finger plus a palm" thumbs touching, fingers splayed at arms length. pretty consistent. that comes out biger that the THX. about 1.1:1 or so. |
I like to sit in that spot in the theater, too! That is PRECISELY how I figured out an eight-foot wide screen would work well for me in my room, and yes - it absolutely does work out to the 1.1-1.2x screen-widths ballpark.
zaphod
Link Posted: Wed Jan 12, 2011 3:55 am Post subject: |
my wife has figured out my "stretching" that i do whenever we sit down in a theater. and here i thought i was being subtle.
Link Posted: Wed Jan 12, 2011 4:32 am Post subject: |
Front row center!
Link Posted: Wed Jan 12, 2011 12:28 pm Post subject: |
I prefer to sit where the hell I want to in my theater. THX be damned. If it coincides, cool. If it doesn't, I'm not losing sleep over it. As long as I can personally determine the threshold at which I can see pixel structure then I know where I'll be comfortable at.
zaphod
Link Posted: Wed Jan 12, 2011 4:49 pm Post subject: |
well yeah, i'm going to where i want
i was just curious why the THX std seemed so small.
Link Posted: Wed Jan 12, 2011 8:06 pm Post subject: |
WanMan wrote: | I prefer to sit where the hell I want to in my theater. THX be damned. If it coincides, cool. If it doesn't, I'm not losing sleep over it. As long as I can personally determine the threshold at which I can see pixel structure then I know where I'll be comfortable at. |
So, what viewing angle have you found you like Wan?
Link Posted: Wed Jan 12, 2011 8:45 pm Post subject: |
Sitting 13' back. The 10' screen in 2.4 aspect (37.6º) and 7.4' screen in 1.78 (29.7º). It was funny when a friend of the wife revealed she has motion sickness issues and I happen to put in I, robot for the demo. Oops
dturco
Link Posted: Thu Jan 13, 2011 12:48 am Post subject: |
realizing (thanks SC) that the THX 1.40:1 is meant to be the *worst* that you'll have explains a lot. i bet that at the back of the theater that's what you get. |
Can I get a photoshop sketch of this pinky bit? It ain't registering.
Oh and I sit 128" from a 104" wide 1:78.1 screen.
http://www.hulu.com/firefly
zaphod
Link Posted: Thu Jan 13, 2011 3:30 am Post subject: |
[quote="dturco"] zaphod wrote: | when i'm in a commercial theater, i usually sit so that the screen size is "pinky finger to pinky finger plus a palm" thumbs touching, fingers splayed at arms length. pretty consistent. that comes out biger that the THX. about 1.1:1 or so.
sure, here's a fine example of my artists skills in MS-paint this ratio of spread fingers to screen is at arms length.
