Sim2 C3x 1080 ??
JayJayHache
PostLink    Posted: Tue Jan 11, 2011 8:45 pm    Post subject: Sim2 C3x 1080 ?? Reply with quote
Can anybody tell me if this interface would likely work with a Sim2 C3x 1080 DLP projector?
Many thanks!
JayJayHache
PostLink    Posted: Fri Jan 14, 2011 2:14 am    Post subject: Reply with quote
The following two are the pre-requisites for 3D-Gamer to work with a projector:
1- Must be a DLP projector
2- Must support 120Hz
Given these two requirements are met, 3D-Gamer should work. Note, we do provide 30-day money back guarantee.
JayJayHache
PostLink    Posted: Sun Jan 16, 2011 2:53 pm    Post subject: Reply with quote
I've checked everything I can find online but i've had no luck confirming the max refresh rate of the Sim2 - Its a DLP unit for sure, and quite modern - but I think i'll need to do a test run (perhaps I can persuade windows to pump out 120 Hz so that I can run the test....)
PostLink    Posted: Sun Jan 16, 2011 6:40 pm    Post subject: Reply with quote
Sure, a 720p/120 (or 720p/100) test would work. We also over a 30-day no-nonsense money back guarantee so if it doesn't work out, simply send it back. Odds are (as you said) since it's a late model projector it will likely work.
RSG
PostLink    Posted: Sun Feb 03, 2013 5:08 pm    Post subject: Reply with quote
Did you get the 3cx1080 projector to work
Rolls-Royce
PostLink    Posted: Sun Feb 03, 2013 6:01 pm    Post subject: Reply with quote
You probably won't get an answer. The OP only made 3 posts, all about this subject, all around the same time, two years ago. As Kal said, they ha(d)ve a 30-day money-back guarantee. Give it a try!
....Royce....
RSG
PostLink    Posted: Sun Feb 03, 2013 6:03 pm    Post subject: Reply with quote
I see that the plus unit has greater options for frequency choices. Would that insure that it works.
Rolls-Royce
PostLink    Posted: Sun Feb 03, 2013 6:21 pm    Post subject: Reply with quote
I do't think it would ensure that the combo would work, but it would give you a better chance of working. To make sure, I would recommend you verify what type of signals the PJ will accept and then cross-match it with the list of output frequencies and resolutions the Theater Plus will produce. The frequencies the Plus outputs are discrete in that they are selected by dipswitches on the unit and are not frequency ranges. For instance, 60/120 on the unit are "60 OR 120 Hz", not "60 TO 120 Hz".
....Royce....
