Joined: 06 Mar 2006 Posts: 16767 Location: Ottawa, Canada
Link Posted: Fri Dec 31, 2010 7:03 pm Post subject: FAQ: BM5.1 6-channel Bass Management Module |
Order today at an exclusive CurtPalme.com reduced price! GO »
We've worked out an exclusive deal for our members to bring you this product at a price lower than what everyone else pays anywhere on the internet!
The BM5.1 Bass Management Module is an active filter and is primarily intended for use together with DVD, DVD-Audio and SACD players, but has use in all 5.1 audio systems where there is no programmable crossover network between the sub-woofer and satellite speakers.
The crossover frequency can be set separately for the front left, right and center speakers and the surround left and right speakers, important when these sets of speakers don't have the same low-end extension. In addition to several different crossover frequencies there is also a flat setting in case a set of speakers can handle the full frequency range.
The type of filter used is a phase and time continuous filter with a 12dB/octave slope for the sub-woofer output. This means that the sum of the low-pass and high-pass filtered output is always flat and with no phase shift at the cross-over frequency. The filter type used in the BM5.1 is the only one with this property, all others have phase and amplitude irregularities around the cross-over frequency. Because of the long wavelength of low frequencies the summation of the wave fronts at the listening position will be perfect and no directional shift will be discernable.
The BM51 is hand built in the USA to exacting specifications.
Features
- Front left, right and center, surround left, right and LFE inputs
- Front left, right and center, surround left, right and sub-woofer outputs
- Separate crossover frequency controls for front left/right/center and surround left/right
- Crossover frequencies 40Hz, 50Hz, 60Hz, 80Hz, 100Hz 120Hz, 150Hz and flat
- 12dB/octave sub-woofer filter
- Phase Coherent filtering
- Low noise and low distortion
Brochure/Datasheet
BM5.1 6-channel Bass Management Module (PDF format)
Questions? Email us at crescendo-systems@curtpalme.com
