p42hdtv10a
rockhard
PostLink    Posted: Sat Dec 11, 2010 4:36 pm    Post subject: p42hdtv10a Reply with quote
hi i got a vizio plasma p42hdtv that was dead i replaced the z sustain board now it powers up new problem is that when it powers up on the screen it says rgb and then a few seconds later it says no signal in red and also when i try to turn off the tv the buttons menu- volume-etc dont function ... please help. thank you
rockhard
PostLink    Posted: Tue Dec 14, 2010 9:11 am    Post subject: Reply with quote
Bump Please help
PostLink    Posted: Tue Dec 14, 2010 11:17 am    Post subject: Reply with quote
Could the RGB be it thinks it is on some PC input? BTW, RGB as an input doesn't support audio.
rockhard
PostLink    Posted: Tue Dec 14, 2010 11:27 am    Post subject: Reply with quote
thanks for your input WanMan. i have tried connecting it to the hdmi port and same results it just cant find a signal. what else could be wrong with the tv? tuner board the whole main board or the t-con board any suggestion?
TV/Projector: JVC RS45
PostLink    Posted: Tue Dec 14, 2010 4:13 pm    Post subject: Reply with quote
If you've already checked that something didn't happen to the cable or connectors on the controls, then I'd suspect whatever board they connect to - probably the main (or CPU) board.
Curt says plasmas are pretty tough to work on because one board failing can take out another, so you have multiple failure modes... Tough to troubleshoot. Of course, the new sets are so damn cheap, and therefore used sets even cheaper, it's hard to justify spending even a little bit of money on replacement boards.
I'm working on one right now that I'm hoping one board will fix. I was hoping to troubleshoot the bad component so as not to have to replace the entire board, but in the little bit of diagnosis I've done, I haven't been able to track it down.
Good luck!
rockhard
PostLink    Posted: Tue Dec 14, 2010 5:31 pm    Post subject: Reply with quote
so i got it to show a picture now. it was just stuck on rgb once i connected it to my laptop i was able then to go into the menu and change settings. now i have this yellow-ish line on the right side of my screen please see attachment any suggestion?
PostLink    Posted: Tue Dec 14, 2010 5:45 pm    Post subject: Reply with quote
So, you were able to control the display from the computer, or you mean you just connected the computer to the input that the display happened to be stuck on?
I don't remember which board it is that connects to the panel with all the little ribbon connectors, but I assume you had to disturb those when you removed the z-sus board you repaired/replaced... So, one of the panel driver connectors is probably not completely connected at the panel or board... That strip is showing lack of blue in that area... Probably a single pin not making contact. Try re-seating a couple of the connectors on the top or bottom of the board/panel, and on that side of the set, then re-booting.
Nice shot of T.J. Hooker, btw. Wink
PostLink    Posted: Tue Dec 14, 2010 5:56 pm    Post subject: Reply with quote
Oh, and in case it isn't already painfully obvious - I'm not a tech. I've just been absorbing knowledge from Curt, Mac and a few other guys here, getting a little help from them here and there, doing lots of reading, and have now repaired one LCD, and am working on a plasma whenever I have a little time here and there.
Cheers,
rockhard
PostLink    Posted: Tue Dec 14, 2010 6:19 pm    Post subject: Reply with quote
yes it was stuck on rgb and basically didn't want to do anything until it got connected to a computer first... and what do you know that yellow-ish line went away i didn't do anything but i hope it doesn't come back see attach picture.. thanks and goodluck with your tv.
