deewaan1
Link Posted: Fri Nov 12, 2010 4:47 pm Post subject: Panasonic PT-61G54CA static when using Coaxial connection |
Hey all! Got an issue with this TV again. Getting static that turns into full snow on all channels eventually when using the coaxial connection for cable TV. Does go away at times to a nice clear picture. But usually gets progressivly worse and worse until you can't see anything on screen and even the audio gets static. Picture is perfect with RCA connections. But it did have a low hum and a faint horizontal bar running from bottom to top when using PS3. That seems to have gone but the static is much worse. I replaced the RG6 cable right from the house cable connection to the TV and no fix. I replaced the ground at the cable splitter and it improved a bit for a few days but then got worse. All other connections and TVs are perfect. Even another TV at this location with this cable hooked up. I'm guessing there is an issue with the coax connector on the TV. Can't see any visible signs of trouble at the connection point. Anyone?!
