betel
Joined: 20 Apr 2006 Posts: 448 Location: Maryville, Tennessee (Just South of Knoxville)
Link Posted: Sun Oct 31, 2010 1:03 am Post subject: Using Black Felt Behind Screen |
A couple of weeks ago I set up a fast fold screen outside. I was surprized how much light was emitted from the backside of the screen. I think is was more than the front actually. In my HT I use a Da-lite Permwall 1.3 gain screen that appears to be a similar material. It just occurred to me I'm probably getting light spill behind the screen that is reflecting onto the screen face, compromising the black level among other things. I intend to install some black felt behind my screen as soon as I can locate it. I'm sure this has been discussed before but the concept is new to me and I'm too lazy to search.
Anyone tried this and what were the results?
Link Posted: Sun Oct 31, 2010 3:02 pm Post subject: |
I never needed it, because my first screen was blackout material (which is specifically designed to block all light), which was recently replaced by Wilsonart Designer White (which is thoroughly opaque ).
But yes, if your screen material leaks light, then I would think a black backing is a good idea. Felt is probably overkill.
betel
Link Posted: Sun Oct 31, 2010 7:11 pm Post subject: |
I pulled the screen off the frame a bit and shined a flashlight on the face. The screen barely blocks the light. Definitely give it a try.
How's the Wilsonart matarial working out for you and what did you laminate it to?
Link Posted: Sun Oct 31, 2010 7:37 pm Post subject: |
It's working fine, though not as much of a dramatic step up from the BO cloth as I hoped.
I laminated it to some foil-backed foam stuff. Very light, but very rigid with the Wilsonart glued on.
jkruger
Link Posted: Mon Nov 01, 2010 4:55 am Post subject: |
Why not paint the back of the screen with some white or silver or aluminum colored paint? Seems like it would tend to make the light that reaches the backside of the screen material reflect back to the front and make it brighter. Better than having all that light scattering around behind the screen.
WTS
Link Posted: Mon Nov 01, 2010 1:01 pm Post subject: |
I discovered that about 5 years or so ago when I set up my Hurley screen, so I hung some royal velvet about 3" behind the screen and if I recall correctly it was a big improvement. I'm still using it. I do recall mentioning it either here or the other site.
Actually I think it's more like 1.5" behind the screen.
_________________ Thanks
Walter
Link Posted: Mon Nov 01, 2010 2:44 pm Post subject: |
If you are hanging something with color (something other than black or white) are you essentially tinting the otherwise white screen?
Link Posted: Mon Nov 01, 2010 2:45 pm Post subject: |
Makes perfect sense to me, jkruger, but if it was that simple you'd think Da-Lite would do it...
jarseneau
Link Posted: Mon Nov 01, 2010 3:49 pm Post subject: |
I have the same Da-lite permwall screen. Behind my screen I have 'landscape' fabric (the black vinyl plastic used to block weed growth around shrubs, etc). Really cheap and easier than painting.
_________________ Jerry
Link Posted: Mon Nov 01, 2010 7:00 pm Post subject: |
I would think it would help especially with ANSI cr.
WTS
Link Posted: Mon Nov 01, 2010 9:26 pm Post subject: |
Mine was black and yes I'm sure if you hung anything of colour behind your screen that it might take on a hue of that colour.
Walter
Link Posted: Mon Nov 01, 2010 10:05 pm Post subject: |
WTS wrote: | I discovered that about 5 years or so ago when I set up my Hurley screen, so I hung some royal velvet about 3" behind the screen and if I recall correctly it was a big improvement. I'm still using it. I do recall mentioning it either here or the other site. |
Yes you told me to do that when i ordered mine. never did but I might. What i want to do is test it first.
I want to take a measurement with the probe off the screen with no backing, my wall is dark blue Ralph lauren Suede paint that has a sandy texture. see what the 100% white field reads . then add the black backing on the wall and take another read. if there is a large difference I will have to take my screen down and do it over.
WTS
Link Posted: Tue Nov 02, 2010 1:43 am Post subject: |
I'm no expert but I would think if it's paint it will reflect alot more light regardless of colour or texture than it would if it was velvet, but give it a try and see what you think.
Walter
Ile
Joined: 09 Mar 2006 Posts: 1491 Location: Jyväskylä, Finland
Link Posted: Tue Nov 02, 2010 11:06 am Post subject: |
Seymour actually sells black acoustical fabric to place behind their screens if your walls are not dark.
Link Posted: Tue Nov 02, 2010 1:49 pm Post subject: |
Nash,
What is the distance between your screen and wall?
Cube
Link Posted: Tue Feb 22, 2011 10:34 pm Post subject: |
I've been wondering about this very thing recently. My old screen has tons of bleed-through and the walls are white, so during bright scenes it gets all blown out. ES CRTs have that bright halo defocus already so it's pretty annoying.
What's the cheapest solution for black backing? I checked out that Seymour backing and it's way too expensive. Can I just hang some of this generic landscape fabric behind the screen? I also thought of taping black construction paper to flattened cardboard boxes (just to make sure it's totally opaque).
Also, my 1272 doesn't have very high lumens, so would it be such a bad idea to hang something opaque and white right up against the back of the screen? If it's right there it seems like there wouldn't be so much diffusion and blow-out that way, and maybe it would just increase the brightness.
After I get this figured out I need something pitch-black but cosmetically acceptable to wrap my shiny faux-wood-finish speakers in.
