My new HT-room project
Goto page Previous  1, 2, 3
Ile
PostLink    Posted: Sun May 15, 2011 10:49 am    Post subject: Reply with quote
Ile wrote:
Next I should bear all those bricks and concrete blocks from cellar to somewhere. There's few cubic meters of that crap. Thumbs Down
It took few days and around 60 wheelbarrows to clear cellar to neighbors yard. Very Happy
Full bricks was not included those are now cleaned and piled up at my terrace.
Now I have started to brick up four pillars to support new concrete floor.
 Filesize:  116.77 KB
 Viewed:  4287 Time(s)
 Filesize:  150.82 KB
 Filesize:  156.28 KB
Tedd
PostLink    Posted: Sun May 15, 2011 12:39 pm    Post subject: Reply with quote
The PVC piping is for cable runs, or was venting for the cellar?
Ile
PostLink    Posted: Sun May 15, 2011 2:09 pm    Post subject: Reply with quote
It's new venting for cellar so I get it dry after winter or when vegetables are carried in at fall. Wink
Even cellar is made lower and used as a subwoofer enclosure, it still can be used as a potato cellar if needed.
Normally cellar vents would be closed during summer and winter, so temp will be around 5-10 C all the time.
There will be smaller tubing for AC for cellar lights and for subwoofer cables.
PostLink    Posted: Sun May 15, 2011 6:56 pm    Post subject: Reply with quote
Did you say A/C?
Ile
PostLink    Posted: Mon May 16, 2011 7:00 am    Post subject: Reply with quote
Spanky Ham wrote:
Did you say A/C?
No, I meant small tubing for mains (230V AC).
Ile
PostLink    Posted: Mon Jun 20, 2011 7:18 am    Post subject: Reply with quote
I bricked pillars and brushed stucco to pillars and cellar walls. Started to make concrete mold for subwoofer enclosures top surface (cellar ceiling).
 Filesize:  115.65 KB
 Viewed:  3999 Time(s)
 Filesize:  125.71 KB
Ile
PostLink    Posted: Sat Aug 06, 2011 9:32 am    Post subject: Reply with quote
Haven't updated this for while, summer have been quite busy time.
Got mold ready for floor and made molds for subwoofer elements. Then little steel reinforcement and concrete pouring.
Now it need to harden few days under plastic and then I can remove mold under it.
 Filesize:  69.22 KB
 Viewed:  3587 Time(s)
 Filesize:  121.75 KB
 Viewed:  3586 Time(s)
 Filesize:  191.16 KB
 Filesize:  150.95 KB
Ile
PostLink    Posted: Thu Aug 11, 2011 8:01 pm    Post subject: Reply with quote
Got mold removed. I was bit worried how element embeddings will come off, but those look good and there shouldn't be any problems with sealing.
 Filesize:  158.24 KB
 Viewed:  3474 Time(s)
Ile
PostLink    Posted: Tue Sep 27, 2011 12:25 pm    Post subject: Reply with quote
Treated element embeddings with polyester resin to prevent concrete chips going to element suspension during installation. It should also prevent moisture from cellar to theater.
Colored polyester with carbon black pigment (from my sauna stove) around elements. Very Happy
Made element clamps out of stainless steel tube and installed elements for first testing. Subwoofer sounds great and it seem to have enough capability for my smallish theater, even room size is going to be doubled soon. Amp power meter was flickering around 2.2 W with my normal listening level, so no need to worry about bottoming out those drivers. Very Happy
Room need acoustic treatments as expected from bare concrete floor and 3 brick/concrete walls.
Sound insulation agains rest of the house (bricked wall, no doors) seem to be pretty good, so no extra work in that area.
 Filesize:  115.56 KB
 Viewed:  3087 Time(s)
 Filesize:  145.97 KB
 Viewed:  3086 Time(s)
PostLink    Posted: Tue Sep 27, 2011 1:08 pm    Post subject: Reply with quote
Now you just need to test it with brown noise.
Ile
PostLink    Posted: Tue Sep 27, 2011 1:26 pm    Post subject: Reply with quote
I already found that classic South park episode for evening. Wink
http://www.southparkstudios.com/clips/151766/the-brown-noise
Page 3 of 3
