RTC2200 connection question.
zulu_warrior
PostLink    Posted: Thu Apr 29, 2010 12:01 am    Post subject: RTC2200 connection question. Reply with quote
Hello All, I bought one of the RTC2200 units and want to make sure that I have it connected correctly. I want to connect it to a Marquee 8500 and a standard dvd player for now. I have a bluejeans breakout cable - Bnc connectors for the pj. This is what I did:
RGB cable out of DVD to component in on RTC2200
Then I connected the vga end of the bluejeans breakout cable to the RGB out of the RTC2200 and BNC to Pj.
The pj only has very rough setup but I got a v sync out of range message. Oh yes I have the 5 bnc ends connected to pj.
Do I have this cnnected correctly and if so how do I correct the sync issue?
Embarassed
PostLink    Posted: Thu Apr 29, 2010 12:12 am    Post subject: Reply with quote
Try swapping the H and V cables on the RGBHV breakout cable at the projector.
zulu_warrior
PostLink    Posted: Thu Apr 29, 2010 12:32 am    Post subject: Reply with quote
Ok I'll try that as I wasn't sure about which was which, one white and one yellow. Don't want to do a lot of things and make it worse. I looked at the dvd setup menu but the controls are basic so no real adjustments here to be made.
