mr_ro_co
Link Posted: Sun Mar 28, 2010 4:51 pm Post subject: strange blue image issue with Moome HDMI 1.3 in 9500LC Ultra |
HDMI sources fed to my Madrigal MP9 via a Moome HDMI 1.3 card have developed a severe defect. The bottom 1/3 of the image has a pronounced green hue to it due to blue output dropping off dramatically over that portion of the image.
This is not due to the projector. Internal patterns are fine, as are RGB sources fed to Channel 1 on the VIM. This problem is definitely due to the Moome card. It is not the HDMI cable. I have swapped it. I have also fiddled with the gamma and it also does nothing to fix this. I have taken out the card and reseated it. I have fed it via a Tosh HD-XA2 and my PS3, over known good HDMI cables. The image defect is present for both.
Anyone ever seen this issue? What's my alternative to the Moome if I want to stay HDMI to the projector?
Thanks!
Steve
Link Posted: Sun Mar 28, 2010 5:08 pm Post subject: |
Wait for Moome to pop in here. Maybe it's fixable.
Link Posted: Sun Mar 28, 2010 6:51 pm Post subject: |
Are you sure you do nat have a problem with the Blue Zone Contrast from the CMM board. It does save its settings for each memory block separately I do believe. So that could be why you do not see it with every input.
Try removing the CMM board first. it is located above or below the CLM depending on ceiling or floor mount. You need to remove the narrow cover to get to it.
Not 100% sure but its an easy test.
The PJ works fine with out it.
mr_ro_co
Link Posted: Mon Mar 29, 2010 8:59 pm Post subject: |
Nashou66 wrote: | Are you sure you do nat have a problem with the Blue Zone Contrast from the CMM board. It does save its settings for each memory block separately I do believe. So that could be why you do not see it with every input.
Athanasios |
I have two recall memory blocks saved for HD-DVD and Blueray HDMI sources, both of which are fed through the MOOME card. Test patterns from either of these sources show the same blue drop-off issue.
I'm reluctant to suspect the CMM board. In addition to the drop off in blue towards the bottom of the blue image, there is also a faint vertical line visible on the right side of the image with multiple fainter lines to the left and none to the right of that main vertical line. None of this is visible on any color if I simply go to the internal patterns and look individually at each color. I don't think the CMM board could be responsible for these lines that only occur in the blue image.
But I can try pulling the CMM board. I will also try driving the pj on its RGB input with a PC and some test patterns to ensure the problem is isolated to the MOOME card.
The MOOME card goes through the Source 2 input on the VIM, correct? Could the VIM itself be damaged? That is, are the internal patterns downstream of the VIM circuitry? My VIM has the Mikron mod.
I will take some screen shots to illustrate these issues.
Thanks!
Steve
