OMG BRILLIANT!! I want this... Flat Screen Movie Posters
Goto page 1, 2, 3  Next
Brian Hampton
PostLink    Posted: Fri Feb 26, 2010 3:22 pm    Post subject: OMG BRILLIANT!! I want this... Flat Screen Movie Posters Reply with quote
Hey,
Maybe I really should put this in another section and feel free to move it or complain about it and I'll move it myself if it's an issue but I wanted people to see this.
Someone bought a LCD and hung it up sideways and uses it to display movie poster images. The effect is like a lighted movie poster but one that changes every few seconds.
It's flippin brilliant and I feel I need to do the very exacto same thing!!!
Check it...
http://forum.blu-ray.com/home-theater-general-discussion/134473-movie-poster-flatscreen.html#post2956138
-Brian
PostLink    Posted: Fri Feb 26, 2010 3:26 pm    Post subject: Reply with quote
It is kinda cool if you are into that sort of thing.
PostLink    Posted: Fri Feb 26, 2010 3:39 pm    Post subject: Reply with quote
Not a new idea obviously - "digital signage" as it's called has been used for years, including plasmas and LCDs turned vertically, but it's definitely the first time I've seen it in somebody's basement. Way cool. Hmmm... Gonna have to think about that for down the road when I get the basement finished. Very cool.
Oh, and I moved the thread to HT Accessories for you, Brian... Mostly so we could find it later.
PostLink    Posted: Fri Feb 26, 2010 3:47 pm    Post subject: Reply with quote
Cool, but would you want to pay for bulbs for a poster display?? I guess if you can afford an LCD just to show posters, the bulbs are a minor issue...
PostLink    Posted: Fri Feb 26, 2010 3:50 pm    Post subject: Reply with quote
Ummm... What bulbs, Gary? This is an LCD flat panel hanging on the wall... Think "living room LCD TV", just mounted vertically instead of horizontally.
It seems expensive, but if you've looked at nice backlight poster boxes, it's not bad. You have to run some sort of a device (SFF PC or photo viewer) to drive it, but I've seen decent-sized LCDs down in the $400 ballpark.
PostLink    Posted: Fri Feb 26, 2010 3:52 pm    Post subject: Reply with quote
Cool idea...It would have to be connected to your automation system so it would turn off during a movie. My theater is very bland in inside, just curtains running down both sides. I'm a bit ADD so any distraction IMO takes away from the movie. I have lights and my center channel speaker mounted above my screen, even those I find a little distracting. I'm actually thinking of covering the bottom of the soffit above the screen with velvet to soak up a little more light.
Note: This shot was taking before the installation of my masking Smile
Brian Hampton
PostLink    Posted: Fri Feb 26, 2010 3:54 pm    Post subject: Reply with quote
You don't buy bulbs for LCD screens.
So... since seeing this I looked into digital photo frames which is sort of the same idea to some extent and they are expensive.
I have an old PC that someone gave me compete with LCD screen. I may try to set it up to do non-stop slide show and mount the LCD near the HT door. (Outside the HT.)
I suppose it is expensive but it's freakin cool that's all I know.
-Brian
PostLink    Posted: Fri Feb 26, 2010 4:00 pm    Post subject: Reply with quote
BTW there is a great source for movie imagery... Check out themovedb.org
Here is an example.
http://www.themoviedb.org/movie/18785/cast
They have a database with xml feeds with links to all their images avalable too. Make a great iPhone app to control your poster screen with. "Hint Hint SC" Smile
I was looking into including some links to it in my mkv app some time.
drice1234
PostLink    Posted: Fri Feb 26, 2010 4:08 pm    Post subject: Reply with quote
I read somewhere that Bill Gates has this sort of setup in his house where he has flat screens all around and uses them to display pictures of art. I have thought about doing this type of thing and making it a touch screen that could switch to a home automation software screen to control the house as well.
Dan
dturco
PostLink    Posted: Fri Feb 26, 2010 4:10 pm    Post subject: Reply with quote
Seems like a great idea. It also seems to be a cheaper way to go ,to a point, because you can keep changing the photos with out having to keep buying new posters, and the initial cost for a cheap lcd isn't really that bad .
A backlit poster box cost 2 times as much> http://www.htmarket.com/chasrefbacli.html
and the posters can cost quite a bit too.> http://www.htmarket.com/movie-posters-and-movie-poster-frames-movie-posters-0-to-9-movie-posters.html
http://www.hulu.com/firefly
PostLink    Posted: Fri Feb 26, 2010 4:17 pm    Post subject: Reply with quote
I have one of these cheepy 28" LCD I use for my secondary monitor, It's not that great, but for movie poster it would look great, its $290. "IF" your paying someone to mount a poster in a frame that is not cheap by any means.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4938558&CatId=3774
Maybe a cool open source project.
PostLink    Posted: Fri Feb 26, 2010 4:18 pm    Post subject: Reply with quote
I haven't paid much attention to flat-panel tech. I know at least some DLPs were rear-pro setups with a bulb, but I suppose those wouldn't qualify for "flat-panel hang-on-the-wall" status. I guess these LCDs must have EL backlighting? A quick Google turns up lifespan estimates around 60k hours. So I guess it's not a big problem. Smile
dturco
PostLink    Posted: Fri Feb 26, 2010 4:22 pm    Post subject: Reply with quote
Pay someone to mount a poster ? Man, thats what thumb-tacks are for. Laughing
PostLink    Posted: Fri Feb 26, 2010 4:25 pm    Post subject: Reply with quote
Costco has a 32" Vizio for $360 or a 24" Sceptre for $199. The only thing you might have to do with some of these displays, is to make a cover so the bezel isn't bigger on one side or the other.
Might be a fun winter project for me next winter!
PostLink    Posted: Fri Feb 26, 2010 4:27 pm    Post subject: Reply with quote
I have a couple of poster dry mounted in my living room....The poster was like 10 bucks by the time I left the shop I think the total bill with the frame was like $200... Pissed me off actually I felt kind of ripped off, live and learn.
PostLink    Posted: Fri Feb 26, 2010 4:28 pm    Post subject: Reply with quote
Gary, LCD flat panels are just like the one you probably sit in front of on your computer... The backlighting is either fluorescent or on some newer, higher-end displays, LED.
So, no - lifespan isn't an issue. Besides, I wouldn't leave on 24/7, anyway... Just when I was in the basement, had people over, etc. You could even automate it.
PostLink    Posted: Fri Feb 26, 2010 4:32 pm    Post subject: Reply with quote
32" would be the perfect size, probably 720p. Costco has these VGA wireless gizmos...Would be crappy for video, for posters it might work.
http://www.costco.com/Browse/Product.aspx?Prodid=11515142&search=Cables%20unlimited&topnav=&Mo=0&cm_re=1_en-_-Top_Left_Nav-_-Top_search&lang=en-US&Nr=P_CatalogName:BC&N=5000043&whse=BC&Dx=mode%20match
Adds to the cost though.
Brian Hampton
PostLink    Posted: Fri Feb 26, 2010 4:34 pm    Post subject: Reply with quote
Hey,
I don't know how far I'll go to replicate this idea. Thinking it over... It would be wasted energy most of the time. The sad truth is I don't have guests very often.
Still... the person in the link I posted got his images at Internet Movie Poster Awards dot com. I've been on there taking the images for now. I'll put them as a playlist on my PS3 and be able to have that set to music. It will make a nice thing to have on while people get "ready" for a movie.
I think I'll enjoy just watching it from time to time too.
I have a small LCD screen and spare outdated PC. I may try to set something up just for fun.
-Brian
Brian Hampton
PostLink    Posted: Fri Feb 26, 2010 4:58 pm    Post subject: Reply with quote
Well,
I've already started getting this setup. I have an old PC that someone gave me which I run the free open source Ununtu Linux. Just put the images in the "pictures" folder and tell the screensaver to use that as the screensaver and you're done from a software perspective.
I have a 19" Dell LCD monitor that came with it and it's wall mount-able.
For the moment ... the wiring will be a little ugly perhaps but I'm going to move forward with this because I think it's so very dern cool.
-Brian
akajester
PostLink    Posted: Fri Feb 26, 2010 8:37 pm    Post subject: Reply with quote
now to figure out how to do this cheaper... the OP posted links to the files now, so you can grab them easily without having to pick through the original source site.
Page 1 of 3
