Link Posted: Sat Nov 07, 2009 1:54 pm Post subject: Paging MAC. Mitsubishi VS-50803 |
Hi Mac,
do you happen to have any experience with this particular TV? I have a guy trying to utilize the RGBHV input and I was wondering if there's a menu setting to enable that?
Link Posted: Sat Nov 07, 2009 11:49 pm Post subject: |
Mac, do you know anything about the 15 pin control connection next to the RGBHV inputs on these? Wasn't that just for the Mitsubishi Promise Module?
Jeremy
Link Posted: Sun Nov 08, 2009 2:38 am Post subject: |
I believe you have to go into the service menu and set the DTV port to HD.
Try menu, 1370. Then select DTV and change it from auto to HD. It should then receive a 1080i signal.
Link Posted: Sun Nov 08, 2009 2:55 am Post subject: |
Cool thanks, I'll pass this along and let you know how it goes.
Jeremy
Link Posted: Sun Nov 08, 2009 10:43 am Post subject: |
On the Mits you do have to go through the menu and activate the input. The 5xRCA connectors (that were on mine) need to also be set to RGBhv vs Component.
Link Posted: Sun Nov 08, 2009 1:51 pm Post subject: |
WanMan wrote: | On the Mits you do have to go through the menu and activate the input. The 5xRCA connectors (that were on mine) need to also be set to RGBhv vs Component. |
Thanks Wan. What model Mitsu did/do you own?
Link Posted: Sun Nov 08, 2009 1:54 pm Post subject: |
WS-65907, which I gave away to friends.
Link Posted: Sun Nov 08, 2009 4:51 pm Post subject: |
Thanks Mac, that did the trick.
Now he needs the internals cleaned and a beam alignment touch up done. I've posted that in the Calibrations forum here: http://www.curtpalme.com/forum/viewtopic.php?p=217489#217489
Link Posted: Mon Nov 09, 2009 12:40 am Post subject: |
Your very welcome....
