Sealing HV boot with silicone...
Francesco
PostLink    Posted: Tue Dec 21, 2010 12:03 pm    Post subject: Sealing HV boot with silicone... Reply with quote
Hi all, I'm trying to seal my HV boots with silicone, like in this image
but I cannot completely fill the boot with silicone, I've been able to fill it only for an inch or less. Is it ok or do I have to completely fill it?
PostLink    Posted: Tue Dec 21, 2010 4:38 pm    Post subject: Re: Sealing HV boot with silicone... Reply with quote
the loose fitting sleeve is only about an inch long but the further in you get it the better. If you can't get it all the way back then that will have to be good enough. The main idea here is to block the leak-path for high voltage. Otherwise it tends to follow the black carbon deposits that build up on the outside of the wire.
cleaning the wire throughly with Alchohol is just as important as the Silicone.
Francesco
PostLink    Posted: Mon Jan 03, 2011 3:04 pm    Post subject: Reply with quote
Here's what I've done:
Hope it's ok...
PostLink    Posted: Mon Jan 03, 2011 6:03 pm    Post subject: Reply with quote
looks good, that's what I do too.
