FAQ: High Performance Bellows for Marquees and clones
Sparky015
PostLink    Posted: Fri Mar 19, 2010 3:08 pm    Post subject: Reply with quote
Hey guys, just curious. Because of the change in material, and the new bellow's ability to keep outside moisture out, I would think that the expansion inside the chamber is less than a stock bellow. If that is the case, would you recemmend putting in more glycol after the change, or still the same amount?
~Paul
PostLink    Posted: Fri Mar 19, 2010 4:35 pm    Post subject: Reply with quote
I have had no problems with the proper amount of Glycol. The Expansion some people see is not because of the glycol expanding with heat, it is because of the absorption of moisture. The Older bellows , like the sweating one pictured on the sales page, expand like that when cold too.
Sparky015
PostLink    Posted: Fri Mar 19, 2010 4:42 pm    Post subject: Reply with quote
Ok, thanks. I would imagine this would keep the glycol from getting contaminated over time as well, as it would keep the bacteria and all of that out as well. Thanks!
~Paul
PostLink    Posted: Sat May 22, 2010 1:09 am    Post subject: Reply with quote
I just ordered a set for myself. Athan reports that his second order of them is in stock.
The list of things I'll be doing to my Marquee during this refurbishment period is considerable. Redoing the bellows (the tubes are still VERY minty!) due to leakage and some glycol contamination is a top priority. And there's so much more to do.
CJ
PostLink    Posted: Thu May 27, 2010 12:44 am    Post subject: Reply with quote
I just got my set. I'm very familiar with the originals and have an unused example of them lying around for comparison.
The new ones actually seem to be even more precisely made than the originals. Good job!
CJ
PostLink    Posted: Thu May 27, 2010 3:25 am    Post subject: Reply with quote
CJ
Thanks Chris but Dale is the one who reversed engineered it and the machinist who made the mould deserve the credit.
I asked Dale if there was anything he could improve on the design so we would not need to use RTV so the bellow might be able to be removed with out cutting it up. He said he'll test the compression of the existing ridges , he said he thinks he could improve on it and he did. No RTV is needed on either the face plate side or the C-element side. And the material has a vapor
transmission 7 times better than the original.
PostLink    Posted: Thu May 27, 2010 3:52 am    Post subject: Reply with quote
I do have a question for you.
These obviously have a mold release chemical on them. What is the recommended cleaning agent for completely cleaning them prior to installation?
When I put mine on, I truly want to try to approach "clean room" conditions as much as I can. Which includes making the new bellow
as squeaky clean and free of any dust, dirt, or contaminants as possible, just like the LC chamber and CRT face and C element.
CJ
dturco
PostLink    Posted: Thu May 27, 2010 11:56 am    Post subject: Reply with quote
When I installed mine last year I rinsed them in the sink, then I used bottled spring water for a final rinse. I also did not use any silicone on the bellow or C-element,and have had zero problems.
http://www.hulu.com/firefly
mycatisretarded
PostLink    Posted: Tue Dec 28, 2010 5:14 pm    Post subject: Reply with quote
I'm about to order a set of three, is price and availabity still as as advertised? ("Special Christmas price?", he asked hopefully) Smile
PostLink    Posted: Tue Dec 28, 2010 5:17 pm    Post subject: Reply with quote
Price and availability remain unchanged.
No specials , sorry.
PostLink    Posted: Mon Jan 03, 2011 11:38 pm    Post subject: Reply with quote
I recomend Aviaane over Perriere Laughing
Moderator
PostLink    Posted: Tue Jan 04, 2011 7:32 am    Post subject: Reply with quote
Go with the non carbonated to avoid bubbles Laughing
