Synch problem with RTC2000
jcoles
PostLink    Posted: Tue Jul 21, 2009 3:30 pm    Post subject: Synch problem with RTC2000 Reply with quote
I recently installed an HDFury2 in my system. When I connect the HDMI cable from either the BD player or the HD satellite receiver into the Fury and then directly to my projector, I get a good picture. When I connect the Fury into the RGB input of the 2000, my pictures is a bit out of synch. I'm outputting thru an RGB cable directly. It's like the old B/W TV's where you had to make an adjustment in the vertical or horizontal holds. I'm inputting into a Marquee 9500 projector.
Thanks for you suggestions
beun
PostLink    Posted: Thu Jul 23, 2009 12:11 am    Post subject: Reply with quote
Sorry for the late reply, I missed this in the new posts section.
Can you describe "a bit out of sync" a bit more in detail. if the picture is not quite stable than the following may help:
Open the case by removing the four screws at the bottom and move the jumper from JP5 to JP6, when it is what I think it is that should clean up the picture, if needed you can turn potmeter P3 a bit to clean it up some more.
Kim
jcoles
PostLink    Posted: Thu Jul 23, 2009 12:25 pm    Post subject: Reply with quote
Sorry, all that did was move the picture to the left. I think the problem is with the Marquee.
