Another EAC3to GUI Plus Updated 5-31-2010
Goto page Previous  1, 2, 3, ... 24, 25, 26  Next
Stryker412
PostLink    Posted: Thu Sep 10, 2009 3:20 am    Post subject: Reply with quote
Awesome work Mike. Resize to 720p option coming? Wink
www.shatteredplanet.org
Community Multiplayer Gaming
Mark_A_W
PostLink    Posted: Thu Sep 10, 2009 3:41 am    Post subject: Reply with quote
Sweet Mike, I'll give it a go.
I had a few issues with the earlier version, where it would process for ages, and then the files disappeared at the end. Have you had that happen to you?
Mark_A_W
PostLink    Posted: Thu Sep 10, 2009 3:43 am    Post subject: Reply with quote
Why?
The whole point of Bluray is it's 1080p.
Hard Drives are cheap.
PostLink    Posted: Thu Sep 10, 2009 3:44 am    Post subject: Reply with quote
Not sure...I haven't see a good way to do it and I’ve heard horror stories of re-encoding taking days to run. I'm open to any ideas….if anyone knows of a good command line re-encoder it could included it. Writing one is way beyond me.
PostLink    Posted: Thu Sep 10, 2009 3:58 am    Post subject: Reply with quote
Yes and its fixed, when using the command line button. You may also turn off file deletion in the options dialog "Delete work files after MKVMerge".
I have tested forced subtitle detection on the following movies Gran Torino, The Eye, Defiance, Vantage Point, The Day the Earth Stood Still, Youth Without Youth and Underworld - Rise of the Lycans all were detected correctly.
I've been ripping directly off the Blu-ray and have a fully remuxed movie in 45 minutes to an hour and half.
BTW the latest version creates logs in the folder c:\program files\ACD\AnotherEAC3ToGUI\Logs\GUI if you have Vista UAC disable...If it's enabled is still is written somewhere ...but god and only Bill Gates knows where.
See Below:
Analyzing .....started at 00:45:25
Analyzing complete...Starting EAC3To.exe
EAC3to complete
Looking for forced subtitles...
No flagged forced subtitles found, looking for other types of forced subtitles...
Likely forced subtitle not found...
MKVMerge Started!...
MKVMerge Done!...
Deleting work files...
Deleting g:\HD Movies\I am Legend - 4 TrueHD.flac
g:\HD Movies\I am Legend - 4 TrueHD.flac deleted.
Deleting g:\HD Movies\I am Legend - 7 English Subtitle.sup
g:\HD Movies\I am Legend - 7 English Subtitle.sup deleted.
Deleting g:\HD Movies\I am Legend - Chapters.txt
g:\HD Movies\I am Legend - Chapters.txt deleted.
Deleting g:\HD Movies\I am Legend 1080p VC-1.mkv
g:\HD Movies\I am Legend 1080p VC-1.mkv deleted.
All work files deleted
Total time 00:43:48
It also makes a copy of the eac3to log in c:\program files\ACD\AnotherEAC3ToGUI\Logs\eac3to
eac3to v3.16
command line: "C:\eac3to\eac3to.exe" "f:\BDMV\STREAM" 2) 1: "g:\HD Movies\I am Legend - Chapters.txt" 2: "g:\HD Movies\I am Legend 1080p VC-1.mkv" 4: "g:\HD Movies\I am Legend - 4 TrueHD.flac" 7: "g:\HD Movies\I am Legend - 7 English Subtitle.sup" -log="g:\HD Movies\I am Legend - Log.txt"
M2TS, 1 video track, 4 audio tracks, 5 subtitle tracks, 1:40:32, 24p /1.001
1: Chapters, 27 chapters
2: VC-1, 1080p24 /1.001 (16:9)
3: AC3, English, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
4: TrueHD/AC3, English, 5.1 channels, 48khz, dialnorm: -27dB
(embedded: AC3, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB)
5: AC3, French, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB
6: AC3, Spanish, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB
7: Subtitle (PGS), English
8: Subtitle (PGS), French
9: Subtitle (PGS), Spanish
10: Subtitle (PGS), French
11: Subtitle (PGS), Spanish
Creating file "g:\HD Movies\I am Legend - Chapters.txt"...
[v02] Extracting video track number 2...
[a04] Extracting audio track number 4...
[s07] Extracting subtitle track number 7...
[v02] Muxing video to Matroska...
[a04] Extracting TrueHD stream...
[a04] Removing TrueHD dialog normalization...
[a04] Decoding with libav/ffmpeg...
[a04] Encoding FLAC with libFlac...
[a04] Creating file "g:\HD Movies\I am Legend - 4 TrueHD.flac"...
[s07] Creating file "g:\HD Movies\I am Legend - 7 English Subtitle.sup"...
[a04] [libav] Lossless check failed - expected 0, calculated d1 <WARNING>
[a04] The original audio track has a constant bit depth of 16 bits.
[a04] Superfluous zero bytes detected, will be stripped in 2nd pass.
[a04] Starting 2nd pass...
[a04] Decoding FLAC...
[a04] Reducing depth from 24 to 16 bits...
[a04] The processed audio track has a constant bit depth of 16 bits.
Added fps value to MKV header.
Video track 2 contains 144615 frames.
Subtitle track 7 contains 747 captions.
eac3to processing took 34 minutes, 11 seconds.
Done.
EDIT: With UAC enabled it writes the logs to:
C:\Users\%youruser%\AppData\Local\VirtualStore\Program Files\ACD\Another EAC3to GUI\Logs\GUI
or
C:\Users\%youruser%\AppData\Local\VirtualStore\Program Files\ACD\Another EAC3to GUI\Logs\EAC3to
There is an issue with the multiline Results listbox sometimes not painting to the screen correctly after ripping...That's next on the list and GUI access to the logs.
Mark_A_W
PostLink    Posted: Thu Sep 10, 2009 11:50 pm    Post subject: Reply with quote
This version seems to work Mike (except I ran out of harddrive space on my scratch disc...my fault).
But the MKVmerge stage seems to take 5x as long as running the MKVmerge Gui. Have you noticed a difference?
Also, my PC goes into standby when running MKVmerge, both the gui and the command line version.
I realise it's not your issue, but is there anything your program could do to prevent that? Or, once the batch run is started, has your program "finished" it's job completely, and is no longer active?
PostLink    Posted: Fri Sep 11, 2009 2:00 am    Post subject: Reply with quote
Thanks for testing Mark...Can you post the MKV Merge command line that you use if you have a chance...I find the MKV Merge (command line) documentation very confusing....I can then compare it to what I generate. I will look into overriding sleep mode while the program is running a batch job.
Mark_A_W
PostLink    Posted: Fri Sep 11, 2009 2:23 am    Post subject: Reply with quote
Oo...err...
Can you get the command line "out" when you set it up using the mkvmerge gui?
I've never done it via the command line - running your program was the first time I've ever seen it via command line.
PostLink    Posted: Fri Sep 11, 2009 2:34 am    Post subject: Reply with quote
Mark_A_W wrote:
Oo...err...
Yes at the bottom of the MKVMerge GUI there is a button labled Copy to clipboard...
The powersaver code looks easy...I have it in already in the app...Now I just need to test it and see if it works.
I have a question with regular subtitles (non-forced)...I add them to MKVMerge GUI they allways default to on in MPC-HC...Can you do something in MKVMerge to prevent that?
Mark_A_W
PostLink    Posted: Fri Sep 11, 2009 2:35 am    Post subject: Reply with quote
Make sure you disable the powesaver code after the batch runs have finished!
Or my PC will stay on all night..
I'll get you that command line tonight.
Mark
PostLink    Posted: Fri Sep 11, 2009 2:37 am    Post subject: Reply with quote
Mark
Oh yea...for sure.
Mark_A_W
PostLink    Posted: Fri Sep 11, 2009 2:55 am    Post subject: Reply with quote
I don't know.
I only ever add the subtitle file to mkvmerge if it's needed.
And I have Zoomplayer set to play any subtitle that is in the file. So I'd have the same issue I guess.
PostLink    Posted: Fri Sep 11, 2009 3:13 am    Post subject: Reply with quote
Mark_A_W wrote:
I don't know.
Ok...I'm going to put non-forced subs on the back burner at this time it bugs me to have to turn them off...
I'm also adding to the log all the command line args for eac3to, bdsubtosub and mkvmerge so we can see what's going on.
Mark_A_W
PostLink    Posted: Fri Sep 11, 2009 9:10 am    Post subject: Reply with quote
"C:\Program Files\MKVtoolnix\mkvmerge.exe" -o "F:\\The Bank Job.mkv" "--forced-track" "1:no" "--display-dimensions" "1:1920x1080" "-d" "1" "-A" "-S" "-T" "--no-global-tags" "--no-chapters" "F:\\Bank Job\\The Bank Job 1080p h264.mkv" "--forced-track" "0:no" "-a" "0" "-D" "-S" "-T" "--no-global-tags" "--no-chapters" "F:\\Bank Job\\The Bank Job - 3 DTS Master.flac" "--track-order" "0:1,1:0" "--chapters" "F:\\Bank Job\\The Bank Job - Chapters.txt"
Mark_A_W
PostLink    Posted: Fri Sep 11, 2009 10:33 am    Post subject: Reply with quote
Oh, Mike, I've realised why the mkvmerge part might be taking longer than normal.
Normally I write the files to one drive with eac3to, them mkvmerge to the final destination drive - a different drive.
The way your gui works, it reads and writes to the same drive.
It would be nice if we could set the destination for the output file to be different to the working directory (unless I'm missing a setting).
Also, a divide by zero error happens in ZP when Reclock can't connect. Something is wrong with your filter settings. Maybe try with Default Directsound or Waveout to figure it out.
When someone asks what player to use, I tell them MPC-HC. But ZP is for me. It's far more configurable, and has a much better GUI (including a media navigator frontend which is usable).
Mark
PostLink    Posted: Fri Sep 11, 2009 12:10 pm    Post subject: Reply with quote
Mark
Too funny...I just ripped my "The Bank Job" disk last night too....No the drive it is not configurable yet...I could make an option to do so...I might make it an advanced option. Call it scratch location. That would make sense why it would be faster the head on the drive would not be dancing all over the place reading and writing. I have one of those 10K RPM SATA drives...That would be perfect for the scratch drive.
ron spencer
PostLink    Posted: Sat Sep 12, 2009 2:54 am    Post subject: Reply with quote
thanks for this cool proggy....does not work for me though. I have ALL things installed and preview works
When I goto add batch all is ok, but when I click Run All I get the error:
Length cannot be less than zero
Parameter name: length
PostLink    Posted: Sat Sep 12, 2009 3:23 am    Post subject: Reply with quote
Sorry your having problems, could you attach a screen capture after you press the Analize button?
or in the folder "c:\Program Files\ACD\Another EAC3to GUI" you should have a file called errorlog.txt if you could attach it that would be great too.
If you have Vista UAC enabled the file will be located in the folder:
C:\Users\%Your User Name%\AppData\Local\VirtualStore\Program Files\ACD\Another EAC3to GUI
ron spencer
PostLink    Posted: Sat Sep 12, 2009 11:53 am    Post subject: Reply with quote
I am mounting BluRay ISOs I made with eac3To.....
eac3to can read the ISOs fine when I use its CLI, as can MakeMKV. For some reason your program seems to balk at them
attached is pic...dunno who to embed.
here is errorlog:
Date/Time: 9/12/2009 7:49:31 AM
Error Source: mscorlib
ErrorMessage: Length cannot be less than zero.
Stack Trace: at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy)
at AnotherEAC3toGUI.FrmCommandLine.BuildCommandLine()
at AnotherEAC3toGUI.FrmCommandLine..ctor(String streamsFolder, String selectedTrackList, String outputFile, Boolean hide)
at AnotherEAC3toGUI.frmMain.gbtnRunBatches_Click(Object sender, EventArgs e)
Also, can you add an option to convert any audio input to AC3 640 for blu ray to ensure maximum NMT if user does not want to use coax or toslink?
 Filesize:  94.15 KB
 Viewed:  6106 Time(s)
PostLink    Posted: Sat Sep 12, 2009 6:38 pm    Post subject: Reply with quote
here is errorlog:
The application is failing when it tries to evaluate the results from running "eac3to.exe 1)". It does not like what eac3to is returning. I've never tired it from an ISO, when you created the ISO did you make it from AnyDVD-HD and include all tracks? I've never made an ISO before so excuse my ignorance, if it's not possible to remove tracks. I've just never seen a disk structure like that. Have you tried ripping directly off a blu-ray...Does it work then?
I would guess it also fails when you use the command line button. Do this:
Select tracklist 1) in the results list then press the "Command Line" button. You should get the same error. Without doing anything else post the contends the file called "log.txt" in AnotherEAC3to GUI folder, not "errorlog.txt". The file "log.txt" is the output of eac3to the GUI analizes, it should hold the key to the problem.
Yes...I can probably do that...I will look into it.
Page 2 of 26
