Barco Graphics 808 AC ---> LC
Decibel
PostLink    Posted: Thu Apr 30, 2009 1:02 pm    Post subject: Barco Graphics 808 AC ---> LC Reply with quote
I've purchase a set of P16 LC tubes from Curt and the tubes are here now Very Happy
A question for scheimpflug system, see this photo.
Green tube have four springs (understand?), two upper and two down.
Blue and red tubes have two down only.
Why?
I want to change glycol for all tubes because into green tube there is a little impurity in suspension.
Suggestions?
I hope that you understood Very Happy
Domenico (Barco fan!)
Runco DTV-1100 "The Black Beast"
Barco Graphics 808 - AC-->LC
Decibel
PostLink    Posted: Tue May 19, 2009 12:12 pm    Post subject: Reply with quote
However the conversion is continuing.
Today I have changed the c-element
The new P16 tubes with new c-element (from G70)
Go out the old incompatible
Install new Smile
Ok!!! color corrected Thumbs Up
Mark_A_W
PostLink    Posted: Tue May 19, 2009 1:40 pm    Post subject: Reply with quote
I'm glad you did that.
Now you can use lenses designed for forward projection, as well as filtered for better colours.
Decibel
PostLink    Posted: Tue May 19, 2009 1:50 pm    Post subject: Reply with quote
Yes yes Very Happy
I' have a set of nice HD18
A my dear friend making the adapters for tubes and lenses Wink
Decibel
PostLink    Posted: Tue May 26, 2009 10:16 am    Post subject: Reply with quote
My dear friend "effecci" has prepared for me the tube and chassis adapters Thumbs Up
Thank you effecci Wink
Drew Packard
PostLink    Posted: Wed May 27, 2009 6:53 am    Post subject: Reply with quote
WOW! What a great friend you have there.... Smile
That is gorgeous workmanship!!
Drew
Decibel
PostLink    Posted: Fri May 29, 2009 8:31 am    Post subject: Reply with quote
New adapter and lens.
The new adapters are in place!!!
Adapter+tube+lens
Drew Packard
PostLink    Posted: Fri May 29, 2009 2:48 pm    Post subject: Reply with quote
That is awesome work!! Thumbs Up
Ile
PostLink    Posted: Fri May 29, 2009 6:48 pm    Post subject: Reply with quote
Good looking adapters!
Is there going to be enough center focus adjustment range with adapters?
zGman
PostLink    Posted: Fri May 29, 2009 6:50 pm    Post subject: Reply with quote
Possibly, if he uses a small screen...
G
Decibel
PostLink    Posted: Sat May 30, 2009 12:02 am    Post subject: Reply with quote
I think yes ... unfortunately I haven't plate of the G70 Rolling Eyes
Decibel
PostLink    Posted: Sat May 30, 2009 12:11 am    Post subject: Reply with quote
Why?
zGman
PostLink    Posted: Sat May 30, 2009 1:45 am    Post subject: HD-18 lens conversion Reply with quote
Good Question!
The base of the HD-18 lens needs to be on the same plane as the recess
in the original lens mounting plate that was on the Barco LC housing.
Looks like you will be about 5mm further out, and since the focus point
moves inward as the screen width increases - you will likely be limited
in screen width.
Your friend did a beautiful job on the machine work, no doubt - I love to see it!
G
Decibel
PostLink    Posted: Tue Jun 02, 2009 2:28 pm    Post subject: Reply with quote
Go out old 180dvb22
Replace with P16 LC
coooooooooolllllll
Thank you Curt Thumbs Up
Thank you effecci Very Happy
zGman
PostLink    Posted: Tue Jun 02, 2009 3:20 pm    Post subject: Reply with quote
Looks Great!
You are really going to love the new tubes with HD-18 lenses.
G
Decibel
PostLink    Posted: Wed Jun 03, 2009 3:22 pm    Post subject: Reply with quote
I have a problem with electric focus Embarassed
In according with service manual I have set at 57 focus of all tubes.
I do not succeed to having a good focus because I do not have more margin than movement in ahead.
Focus yokes are in contact with deflection yokes, I don't have more margin!
Suggestions?
Ile
PostLink    Posted: Wed Jun 03, 2009 5:38 pm    Post subject: Reply with quote
Usually electronic focus is needed to tweak after yokes mechanic adjustment.
Do you get good focus with electronic mid point adjustment?
If no, you might need to cut those deflection yoke plastic clamps off and use rtv to lock yokes to level. Two small blob between yoke and tube bell should be enough.
PostLink    Posted: Wed Jun 03, 2009 8:30 pm    Post subject: Reply with quote
or cut the focus coils screw threads on the deflection coil side off, this way you still have one clam on the neck side of the tube to lok focus coil into place.
Also you might get better focus away from tube face so remove the cpc mags and move coll up and down tube face to find best location, if you can do this with no electronic focus connected first , then do it that way. Its how i find best static focus of the coil before any electronic focus is going through it.
zGman
PostLink    Posted: Thu Jun 04, 2009 12:03 am    Post subject: Reply with quote
I have done several of these conversions on BG808S - you should be able
to pull in perfect electronic focus. Look in the lens (with reduced contrast &
on an off angle) and have a look at the grid lines while ramping the focus
control. Also bear in mind you can't really make serious progress on focus
until astig (cpc magnets) is dialed in very accurately. Also - it is a lot easier
to work on focus (and astig) with external patterns, IMHO...
G
Decibel
PostLink    Posted: Thu Jun 04, 2009 12:17 am    Post subject: Reply with quote
The vpr is a BG808 non "s" I'have swapped 180dvb22 AC to P16 LC.
However I must to setup flare and astigmatism .... ok, thank you Wink
