Frank D
Link Posted: Thu Apr 09, 2009 4:14 am Post subject: IFB-FULLHD SONY HDMI 1.3 CARD QUESTIONS |
Couple of questions:
1. What is the little black SW button near the center of the face plate for?
2. To ensure that the contrast adjustment pot is at 0.7 v should I turn the adjustment multi-turn pot screw counter-clock wise about 30 turns? Is there a way to check the contrast trim pot setting value?
moome
Link Posted: Fri Apr 10, 2009 3:09 am Post subject: Re: IFB-FULLHD SONY HDMI 1.3 CARD QUESTIONS |
Frank D wrote: | Couple of questions:
Thanks |
1.for switch the input between HDMI0 and HDMI1
2.need professional and special kit to calibrate the 0.7V
Frank D
Link Posted: Fri Apr 10, 2009 4:47 am Post subject: Re: IFB-FULLHD SONY HDMI 1.3 CARD QUESTIONS |
moome wrote: |
2.need professional and special kit to calibrate the 0.7V |
Ok but we want it to be left at 0.7 volts correct?
So to make sure contrast screw is set at 0.7 volts should we turn the contrast screw counter-clockwise about 30 turns?
LexaDstyle
Link Posted: Sun Apr 12, 2009 3:15 pm Post subject: |
thank you!!
________________
Если назрела ссора с любимой - доставка цветов Москва , это решение проблемы.
moome
Link Posted: Mon Apr 13, 2009 2:12 pm Post subject: |
please clockwise at least 25turn until hear tiny click noise on the pot. then unclockwise the pot 4 turn~
thanks
WTS
Link Posted: Mon Apr 13, 2009 6:24 pm Post subject: |
As you adjust the gamma the output level will change. SO it is best to adjust the gamma then go back and check the output level and adjust it back to .7vpp. It does take some going back and forth but you need to do it to ensure you have .7vpp output at 100ire.
_________________ Thanks
Walter
Frank D
Link Posted: Tue Apr 14, 2009 4:17 am Post subject: |
WTS wrote: | As you adjust the gamma the output level will change. SO it is best to adjust the gamma then go back and check the output level and adjust it back to .7vpp. It does take some going back and forth but you need to do it to ensure you have .7vpp output at 100ire. |
OK. But how do you ensure .7vpp output on 100 ire?
