WESTW
Link Posted: Tue Apr 07, 2009 9:03 pm Post subject: RTC 2200 added to 1272 & Crystalimage 4.0 Any advantage? |
I have a Sony 1272 to which I have recently added a Crystalimage VS 4.0. Once I added the Crystalimage, which I am running at 720P, I never dreamed the picture could look as good as it does. From what I read the it seems it would make a real difference, but I thought I would defer to more experienced hands. If it will make a significant difference then where should I run it; in between the DVD and the Crystalimage or between the Crystalimage and the pj. I await your words of wisdom.
Bill[/b]
beun
Joined: 06 Mar 2006 Posts: 16752 Location: Ottawa, Canada
Link Posted: Wed Apr 08, 2009 12:46 am Post subject: |
Bill,
What are you using the CrystalImage scaler for? That's a pretty old beast and the built-in scalers found in cheap Blu-ray and DVD players today does as good or even a better job than that scaler.
If you want to add Gamma boost I'd suggest something like this:
Source device -> HDMI cable -> HDfury2 (or HDFury1 if you're on a budget) -> RTC2200 -> RGBHV cable -> Sony 1272
That's exactly what I do (RTC2200 and all). The Blu-ray player (PS3) feeds the HDfury2 for Blu-ray and DVD playback, and the HD-PVR goes into the RTC2200 component inputs for HDTV/regular TV.
RTC2200 give both a nice (much needed) gamma boost and does the switching between the two, plus lets you set the sync, drives the long RGBHV cable nicely, etc!
I did this exact same setup (HDfury1 instead of HDfury2) on my Barco 800 - a projector that is identical in specs/performance to your 1252. I was very happy with the setup. Kim makes a great little box (which the entire reason we started promoting it here).
If you're wondering how far off your gamma is, try measuring it. I give instructions and examples using my CRT projector in m 'Greyscale & Colour Calibration for Dummies' guide here: http://www.curtpalme.com/forum/viewtopic.php?t=10457
Now if you need to run older sources like VHS or laser disk then keep the CrystalImage. Otherwise I suggest you simplify and try and sell it for a few bucks.
Other Links:
Hdfury1: www.curtpalme.com/Hdfury1.shtm
Hdfury2: www.curtpalme.com/Hdfury2.shtm
RTC2200: www.curtpalme.com/RTC2200.shtm
WESTW
Link Posted: Wed Apr 08, 2009 8:32 pm Post subject: This is all I need? |
Kal,
I used to have a 1042Q and it died a while ago. I just got the 1272Q after not having one for a while.
I have a Sony 875P 300+1 changer with a progressive output which I ran to the Pj. It looked great compared to what I was use to before. Then I got the Crystalimage off ebay for $100.00. It has turned out to be a real improvement. After getting all the levels balanced between the Pj and the CI I honestly think it looks as good as or better than my TV on a 8 ft diagonal. Now let me apologize for my ignorance. So what your saying is that with the RTC 2200 I will get a better picture with the added benefit of updated electronics and the Gamma boost. I'm all for anything that will give me a better picture, but I'm not rich either. I could do the RTC 2200. Let me know and thanks again for your help.
BILL
Link Posted: Wed Apr 08, 2009 9:14 pm Post subject: Re: This is all I need? |
WESTW wrote: | Kal,
I have a Sony 875P 300+1 changer with a progressive output which I ran to the Pj. It looked great compared to what I was use to before. |
Ok, so that progressive player will give you 480p into the projector. Scanlines will be seen so you'll need to scale them.
Quote: | Then I got the Crystalimage off ebay for $100.00. It has turned out to be a real improvement. |
Sure. You've probably got the scaler set to 720p output? That would be better than 720 and hide the scanlines you were getting before.
Quote: | Now let me apologize for my ignorance. So what your saying is that with the RTC 2200 I will get a better picture with the added benefit of updated electronics and the Gamma boost. I'm all for anything that will give me a better picture, but I'm not rich either. I could do the RTC 2200. Let me know and thanks again for your help. |
The RTC2200 will give you that gamma boost you probably need (I've yet to a see a CRT projector that didn't benefit from it).
You probably don't have a calibration meter, but if you can borrow one or decide to buy one, you can find out far off your gamma is by using my 'Greyscale & Colour Calibration for Dummies' guide here: http://www.curtpalme.com/forum/viewtopic.php?t=10457
