BUF 2000 & Marquee 8500 & 1920x1080p & No Sync?
gravymaker
PostLink    Posted: Thu Feb 12, 2009 2:55 pm    Post subject: BUF 2000 & Marquee 8500 & 1920x1080p & No Sync? Reply with quote
Hi Guys,
I just received my BUF 2000 and was hoping to use it on my HTPC video chain to control gamma. However, the Marquee doesn't seem to want to lock onto a 1920x1080p signal that I'm feeding from the HTPC when the BUF2000 is inserted into the chain - I get scrolling diagonal lines. The Marquee syncs to that resolution fine without it.
Chain:
HTPC Vid Card -> DVI to VGA Adapter -> M-M VGA Cable -> in-BUF200-out -> FF VGA Gender changer -> RGBHV Breakout Cable -> Marquee Input
I haven't tried any other dip switch settings, as I thought the Marquee liked negative sync on H & V?
Any thoughts? I tried a search but couldn't find any threads with similar problems - I'm sure I'm doing something incorrect.
Cheers!
S
-Scott
beun
PostLink    Posted: Thu Feb 12, 2009 3:31 pm    Post subject: Reply with quote
Scott,
The are a few possibilities, the Marquee may not like the negative going sync but as you mentioned that is unlikely. The other possibility is that the H-sync is not wide enough. To fix that you have to open the case and turn the small potmeter on the bottom of the PCB clockwise. The best solution since it works without the BUF2000 may be to put it in native (pass-through) H-sync. Again you have to open the case and set SW5 to off and SW8 to on, this will still retain the negative V-sync. The manual that is now available on the http://www.crescendo-systems.com/video_buf.html website explains all the sync options in more detail.
Kim
gravymaker
PostLink    Posted: Fri Feb 13, 2009 12:32 am    Post subject: Reply with quote
beun wrote:
Scott,
Kim
Bang-on, Kim. I changed to PassThru Hsync and the Marquee syncs just fine now. Many thanks - time to play with gamma!
-Scott
gravymaker
PostLink    Posted: Sun Feb 15, 2009 4:17 pm    Post subject: Reply with quote
Interesting development (By the way, the gamma increase has created just a fantastic picture Kim!! I actually could turn down the Marquee's brightness and contrast quite a few notches.)
If I fire up a calibration tool like Nokia Screen test, and select one of the very detailed focus screens, the Marquee loses sync again and I get a flashing screen, which temporarily syncs but then goes black, continuously cycling until I click away from that test screen.
It only happens on the very detailed focus test screens? I've tried increasing pulse width pot fully clockwise, but this doesn't seem to have any impact on the flashing symptom.
Is it possible that 1920x1080@70hz is too much for the BUF2000's buffer??
S
-Scott
beun
PostLink    Posted: Sun Feb 15, 2009 11:16 pm    Post subject: Reply with quote
Scott,
That Nokia Screen test, is that is PC application? From a bandwidth point of view that resolution should not be an issue but there could be something else going on inside. I will see if I can generate something like that and test the BUF2000 some more.
Kim
beun
PostLink    Posted: Sun Feb 15, 2009 11:30 pm    Post subject: Reply with quote
I think I found the Nokia tool, can you point me to the exact screen where it goes wrong? Also does it lose sync even in the H-sync native mode (the width potmeter is not functional in native mode)? What if you do not use the BUF2000, does it work then?
Kim
gravymaker
PostLink    Posted: Mon Feb 16, 2009 6:47 pm    Post subject: Reply with quote
Red arrow points at the test screen that won't sync:
Correct - in H-Sync native it loses sync on the nokia test screen. (I should have realized the pot won't do anything in native mode - thx)
I took the BUF2000 out of the chain and I can display the test screen successfully.
-Scott
beun
PostLink    Posted: Mon Feb 16, 2009 8:43 pm    Post subject: Reply with quote
Ok,
I will do some serious testing and figure out what is going on, this is weird.
Kim
gravymaker
PostLink    Posted: Mon Feb 16, 2009 9:47 pm    Post subject: Reply with quote
OK thanks Kim.
Interesting - if I open up Windows File Explorer on the big screen, and gradually increase the size of the window by dragging a corner, I'll reach a size that will cause the marquee to lose sync. Once the window fills about 80% of the screen, the image will flash on and off, or roll horizontally.
-Scott
beun
PostLink    Posted: Mon Feb 16, 2009 10:40 pm    Post subject: Reply with quote
Scott,
As I remember, the Nokia resolution screen has a large white background and so does the the windows file explorer, I am starting to wonder if that has anything to do with it. If that is the case I will be able to test that relatively easy and find a solution to that problem. I will keep you informed. If you have the case open can you check the values of the two big blue capacitors on the bottom board for me?
Kim
beun
PostLink    Posted: Tue Feb 17, 2009 2:31 am    Post subject: Reply with quote
Scott,
I am still investigating the exact cause but if it is what I think it is, can you change to positive sync or sync on green if the Marquee accepts that? If I am correct that that will temporarily solve your issue. When I have the permanent fix I will send you a new unit.
Kim
gravymaker
PostLink    Posted: Wed Feb 18, 2009 2:13 am    Post subject: Reply with quote
beun wrote:
Scott,
Kim
Thanks Kim: Here's the results:
1. Capacitor Values: Both are 25v 100uF (85 degrees C)
2. Positive H & V test: You were correct - positive Sync on H&V works fine on all-white fields. All tests in Nokia work fine now.
-Scott
beun
PostLink    Posted: Wed Feb 18, 2009 2:35 am    Post subject: Reply with quote
I am testing this right now and I am very very sure what the problem is, I will send you a new one when I received some parts. Please PM me with your address.
Kim
gravymaker
PostLink    Posted: Wed Feb 18, 2009 3:05 am    Post subject: Reply with quote
pm sent. thx!
-Scott
gravymaker
PostLink    Posted: Sun Mar 08, 2009 7:28 pm    Post subject: Reply with quote
Kim - your fix works great. Thanks again.
-Scott
PostLink    Posted: Sun Mar 08, 2009 8:05 pm    Post subject: Reply with quote
What was the fix Kim?
beun
PostLink    Posted: Sun Mar 08, 2009 11:47 pm    Post subject: Reply with quote
The first few I made had power supply caps that were a bit to small causing ripple on the supply at maximum current draw (peak white and negative going syncs). This ripple is no problem for the video opamps but causes most projectors to see false syncs. I fixed it by sending a new BUF2000 with bigger caps. Choosing sync on green or posive going sync will also fix this issue.
Kim
