g70 set up
bigleechild
PostLink    Posted: Thu Feb 05, 2009 10:09 pm    Post subject: g70 set up Reply with quote
I have a g70 with a moome hdmi card, a sony ps3. I have the projector converged for 1080i, but need help in setting up a new memory block for 720p. Can anyone help me in how to do this. I have a game for the ps3 that is only 720p and it is my favorite game but the projector shows it in a unconverged picture. I would really appreciate any help in how to correct this. Thanks for all the help
BLC
PostLink    Posted: Fri Feb 06, 2009 12:02 am    Post subject: Reply with quote
The G70 is just dropping into a memory block you haven't set up, yet. You just need to go ahead to do geometry and convergence with the 720p signal, and save it to only that memory block (short save).
Did you setup the G70 yourself, or did somebody do it for you?
bigleechild
PostLink    Posted: Fri Feb 06, 2009 4:10 pm    Post subject: Reply with quote
The guy I bought it from did. Are you saying to converge it with the game on? I've tried that route but when I have the cross hair screen come up, I can't move the blue hair even close to green and yellow before I hit the min setting. I'm afraid to turn the lenses because I would think that would f up the 1080i setting. Just need a little help, I'm pretty sure I can do it if given instruction. Thanks again for any help you can give.
PostLink    Posted: Fri Feb 06, 2009 4:28 pm    Post subject: Reply with quote
Yes, converge it with the game on. Basically, when you set up the projector, the general process is to do a base setup with no source inputs. That sets geometry and convergence at 480p (by default, anyway). You then save those settings to all memory locations (resolutions). That gives you a starting point for each separate resolution you plan to use, and you then configure and save each one separately from there.
You were probably using RGB shift, when you really needed to be using CENT (or zone 0). The CENT or center control moves the rasters themselves on the tube face, whereas the RGB SHIFT command you were using is moving the active image area around within the raster.
Here's the deal: I could tell you what to do, but I'd highly recommend before you tear into it, you should really read over the install manual and familiarize yourself with the controls and setup process. You can download the install manual here:
http://www.curtpalme.com/SonyG70_Downloads.shtm
Also, do some searching on the forum - there are lots of people who went through the same learning process as you in setting up their machine. The G70 is a hell of a projector, and it deserves to be setup up properly. The more you learn, the better the image can be.
Oh, and you're correct - don't touch the lenses. That's focus and toe-in and it should all be set correctly already if the guy knew what he was doing... and it will most definitely affect your setups.
Do some reading, then come back and ask away!
rabies_70
TV/Projector: Sony G70Q
PostLink    Posted: Fri Feb 06, 2009 4:53 pm    Post subject: Reply with quote
From your thread on the A
I really am not trying to sound like or even be a jerk here, but the best thing to do is search the forum here and the other site for any and all info you can find on the topic of g70 memory management issues. It is such a deep convoluted subject there is no way a simple answer in a single post will get you there let alone leave you with a lasting knowledge of how to set it up. There are tons of posts here in the forums, in the archives and over there that will get you up to speed. I personally found that after spending a few hundred hours searching and reading all the posts I could possibly find on G70 memory and just G70 stuff in general answered ALL of my questions. Sorry bro your setup is toast, which is no big deal because I am sure if you are asking these questions, you're not setup properly in the first place. That is NOT a dig, just a very real possibility. It wasn't until my fourth setup of my G70 (my first D50 I set up 4 times too) it wasn't until then that I finally got a pretty firm grip on this crazy great little machine. Do like afryia said and set up to the oscillators first. I personally only setup to P2 and then copy and paste the setup to 0-9 then feed a signal and re converge to that. Start with a good mechanical setup, do the focus, get the astig right (LOADS of fun there) then basic convergence to P2 and so on. It is the ONLY way to set these things up properly.
So short answer, there is no short answer. Start reading everything you can find, it'll take up a bunch of hours but it is so worth it in the end.
Have fun dude you're going to love it when you get it all setup right!
Let go worrying about the "setup" you have now bro. Start from scratch, do it right and be happy. You will never regret it. Good luck friend.
Ray
I am an iconoclast
