Ohmess
Link Posted: Sat Jan 24, 2009 9:53 pm Post subject: Parts Help Needed -- Terminal Block |
Hi All -- I found a Furman PS-8R power sequencer on thebay for $25, but the circuit that sequences the powered outlets needs to be repaired. I think the transformer that powers the circuitry is shot and that it will be simple enough to fix, but I have another issue.
The sequencer can be initiated with a 12v signal, and I plan to use this, but the small block that plugs into the back of the unit did not come with it. Does anyone know where I might find one of these? Here's a picture of the item I'm seeking. Its the green block protruding from the back of the unit between the outlets:
fuzzybee
Link Posted: Sun Jan 25, 2009 10:29 am Post subject: |
ygpm
fuzzybee
Link Posted: Thu Feb 05, 2009 4:32 am Post subject: |
Did either of those phoenix blocks I sent you work?
Ohmess
Link Posted: Thu Feb 05, 2009 1:52 pm Post subject: |
Yes, problem solved.
Thanks a ton.
fuzzybee
Link Posted: Fri Feb 06, 2009 1:27 pm Post subject: |
Cool. Glad it worked for you.
dadude712
Link Posted: Sun Mar 27, 2011 11:03 pm Post subject: |
Hey Fuzzybee,
I am also in need of a few of the green connectors, (Phoenix connectors) for my PS-PRO IIs.
I saw you were able to help the OP, and was wondering if you had a way or any information on getting these.
Thanks for all you help,
-Dustin
Link Posted: Mon Mar 28, 2011 12:35 am Post subject: |
They are all over the place. It's the new de facto standard for pro audio equipment. Try the links that I posted above.
dadude712
