Aspect Ratio Controller for HTPC’s Updated 1-26-09
PostLink    Posted: Sun Jan 18, 2009 4:10 am    Post subject: Aspect Ratio Controller for HTPC’s Updated 1-26-09 Reply with quote
Main Screen
Was bored on this cold weekend and decided to put together a little application to control aspect ratios for software based DVD & Blu-ray players. It’s pretty basic right now but does seem to work. I still need to add support for hotkeys but I wasn’t sure what would be the best way to implement, so any feedback would be appreciated.
Setup a custom resolution like 1920X800p then stretch the player to fill the screen.
Requirements: DOT.NET framework version 2.0
For PowerDVD make sure you have "Stretch to Fit the Screen" checked under Aspect Ratios on the PowerDVD context menu.
Create a new Aspect Ratio Press "New" button select the application to control. Name your new aspect and press OK.
New Aspect Ratio
Assign a hotkey press "Hotkey" button then select the function to assign to the hotkey.
Assign Hotkey
To view assigned hotkey press the "?" button next to close box on the main screen.
Hotkey Help
Download and unzip from this link.
Edit: New version uploaded 1/26/09
Support for dual monitors, when the application is moved past 60% on the second monitor the blanking then moves to the second monitor. Only works on side by side monitor setups.
Customizable hotkey support for over 35 functions.
Global checkbox options now have persistence.
Thanks!
PostLink    Posted: Sun Jan 18, 2009 4:24 am    Post subject: Reply with quote
WOW
Very nice, I'll try it out and let you know how it works for me. Smile
PostLink    Posted: Sun Jan 18, 2009 7:52 am    Post subject: Reply with quote
Awwww how nice! You named it after me! I didn't even know I needed controling. Wink
Laughing
PostLink    Posted: Sun Jan 18, 2009 1:50 pm    Post subject: Reply with quote
You need controlling in the worse way. Someone mentioned your name on that plane causing it to ditch in the Hudson River. Mike is just trying to make it safer for folks around you. Razz
PostLink    Posted: Mon Jan 19, 2009 4:49 am    Post subject: Reply with quote
Hey Mike, all kidding aside. I really like this!
So you get our first official sticky thread in the HTPC forum. Keep us updated.
~AR~
jask
PostLink    Posted: Mon Jan 19, 2009 9:16 pm    Post subject: Reply with quote
Thanks Mike, I will give this a try tonight.
PostLink    Posted: Mon Jan 19, 2009 11:56 pm    Post subject: Reply with quote
I should have the hotkey stuff real soon. So you can with just keystrokes.
PostLink    Posted: Tue Jan 20, 2009 12:25 am    Post subject: Reply with quote
Mike,
Is this able to work on a secondary monitor?
PostLink    Posted: Tue Jan 20, 2009 2:00 pm    Post subject: Reply with quote
Zebu Fellenz wrote:
Mike,
I just tested with PDVD, the player will move to the second screen but the blanking stays on the primary screen. It should not be a hard thing to fix.
PostLink    Posted: Tue Jan 27, 2009 4:53 am    Post subject: Reply with quote
Updated 1/26/09.
PostLink    Posted: Tue Jan 27, 2009 5:11 am    Post subject: Reply with quote
Hey Mike,
how about a formal change log at the bottom of your first post? I know you have one there, but, add the date the feature is released?
It's always fun reading those a few years latter to see the progression of an idea.
PostLink    Posted: Tue Jan 27, 2009 5:19 am    Post subject: Reply with quote
Hey Mike,
Good idea!
New version uploaded 1-26-09
Version 1.0.0.1
Several bug fixes.
Mark_A_W
PostLink    Posted: Fri Oct 30, 2009 1:44 am    Post subject: Reply with quote
I have to say Mike, I don't understand what whis application is for (?).
I think you need to explain it...
PostLink    Posted: Fri Oct 30, 2009 3:45 am    Post subject: Reply with quote
LOL...No need, not much value unless your masochist and insist on using PowerDVD. Better free players like Zoom player and MPC-HC have the features built in. It was kind of a modern update to YXY.
Mark_A_W
PostLink    Posted: Fri Oct 30, 2009 4:17 am    Post subject: Reply with quote
Yes, ZoomPlayer has a bewildering array of Aspect Ratio and Blanking controls/presets.
I think I had to create a custom aspect ratio when I tried 804p at 72hz.
PostLink    Posted: Fri Oct 30, 2009 4:41 am    Post subject: Reply with quote
yeah...That's what I had in mind too...Problem was 804p really didn't look that much better than 1080p, it was really a hassel too, some of the guys over at AVS with A-lens use it, or at least did at one time. It's a nice interface isn't it?, it was more or less a copy or attempt to copy of how TheaterTek's AR control worked.
Mark_A_W
PostLink    Posted: Fri Oct 30, 2009 4:58 am    Post subject: Reply with quote
Yes...I wondered about all the fuss, and went back to 1080i 96hz.
