What is your longest speaker cable/wire run?
Less than 10' (3m)
11%
 11%  [ 2 ]
10'-20' (3-6.1m)
11%
 11%  [ 2 ]
20'-30' (6.1-9.1m)
33%
 33%  [ 6 ]
30-40' (9.1-12.2m)
22%
 22%  [ 4 ]
More than 40' (12.2m)
22%
 22%  [ 4 ]
Total Votes : 18
PostLink    Posted: Sun Jan 11, 2009 3:16 pm    Post subject: What is your longest speaker cable/wire run? Reply with quote
What is your longest speaker cable/wire run? This is from the point the signal is amplified to the drivers themselves.
PostLink    Posted: Sun Jan 11, 2009 3:30 pm    Post subject: Reply with quote
All 5 of my speakers are 50' from the amp(s). I use 2 parallel runs of 12 ga home depot in-wall rated CL2 wiring to bi-wire.
PostLink    Posted: Sun Jan 11, 2009 3:43 pm    Post subject: Reply with quote
Kal, did you coil a bunch of wire up somewhere to make the runs all equal length? I resisted the urge to do that, since I could find nothing of any reliable sort that indicated there was any good reason whatsoever to make all the speaker wire lengths equal. My right-front main is probably a 35-foot piece, while my left-rear surround which is only 5 feet from the rack is probably only 15-feet. Then, there's everything in-between.
It's all Blue Jeans Twelve White (Belden 5000UE) in-wall.
http://www.bluejeanscable.com/store/speaker/index.htm
PostLink    Posted: Mon Jan 12, 2009 6:28 pm    Post subject: Reply with quote
Not really/sort of. (How's that for an answer). Smile
My 3 fronts have all sets of wires coming down right in the middle and behind the screen the L and R speakers are the same length. The center speaker has an extra couple of feet at the speaker and at the amp so it's the same length as the L and R.
As it turns out my rears are also pretty much the same length as the fronts.
I do have a little bit coiled up for most of the speakers back at the amps (probably 4-5') just because I didn't want to cut the wire in case I ever wanted to move the speakers around a bit - especially the surrounds as I was experimenting for the longest time on placement. If I ever go 7.1 too I want the extra length to make sure I dont' have to go and buy new wiring.
So in most cases it's 50' to each speaker but there's up to 5-6 feet 'extra' for each.
PostLink    Posted: Fri Jan 16, 2009 11:53 am    Post subject: Reply with quote
Well, I found a 1000' reel for $364, but I do not need 1000'. Since the 5000UE product is actually Belden and not BJC I am looking for a better price. Time to hit up the local suppliers. Smile
PostLink    Posted: Fri Jan 16, 2009 5:32 pm    Post subject: Reply with quote
How much do you need? Can't you just pay a little extra and buy it from BJC? Their price really isn't bad at .57/ft. I mean... the price you found is only 36 cents/ft, but add in the $50 for ground shipping and you're up to $.41/ft.
Markertek has a 500-ft spool for $195... That would probably bring you in for under $.50/ft.
http://tinyurl.com/77l69m
But... even for .57/ft from BJC... What do you need... maybe 150-200 ft? You're talking $85-115... I understand wanting to save a few bucks, but how much are willing to spend to save a few bucks? Even if you need 200 feet, you're talking about a difference of $15-30. Are you really going to spend an hour on the phone calling wholesalers, and an hour driving across town and back to save $14? BJC will send the box to your doorstep in a few days! Wink
Every time I start looking for local suppliers of commercial stuff, I realize how great the prices are from internet sellers.
PostLink    Posted: Fri Jan 16, 2009 9:20 pm    Post subject: Reply with quote
I thought BJC's price was $0.61/foot.
PostLink    Posted: Fri Jan 16, 2009 10:16 pm    Post subject: Reply with quote
The .61 price is their "especially made for BJC" white-jacketed version - hence the "BJC Twelve White" moniker. The standard off-the-shelf Belden 5000UE in a gray jacket is .57, and is the same as what you'd get from Markertek or off the other spool you were looking at.
Some people think the gray looks a little "utilitarian", while the white looks a little more "audio". I agree - especially for .04/ft. I think I bought 150' or so, so about $6.00 worth.
If were all going in the wall, I wouldn't care, but mine goes right into my rack...
Looking at it here, my rack is pretty utilitarian, anyway - gray probably would have looked just as good. Damn. $6 down the tubes. Wink
WTS
PostLink    Posted: Sat Jan 17, 2009 1:31 am    Post subject: Reply with quote
I think my longest run is about 3 feet.
Walter
PostLink    Posted: Sat Jan 17, 2009 2:52 pm    Post subject: Reply with quote
SC, what kind of Crown amps are you using? I actually paid the electrician to install outlets on a dedicated circuit to each speak location. I wanted to cover myself in case I went with per-channel amplification at the speaker location. That may prove to be overkill, or just expensive. Very Happy
PostLink    Posted: Sat Jan 17, 2009 3:30 pm    Post subject: Reply with quote
~40' here for my three across the front.
PostLink    Posted: Sat Jan 17, 2009 4:19 pm    Post subject: Reply with quote
Wow, you wired it for active speakers? Did you really do a dedicated circuit to EACH speaker location - i.e. each on its own breaker? Or, do you mean a dedicated circuit for all the speakers?
My Crowns are XLS-202D's. I thought about going to 402's, since it seems like a lot more guys use them... But, price jumps $100, so about $1200 for the three amps instead of $900. The 202's are already at 300wpc into my 4-ohm M&K's (I was upgrading from 120wpc AVR!). That gives me enough clean power to run to about 105dB - in the back row! I haven't even tested it from my listening location, but I know it's louder. The 402's are 450w into 4-ohms, and I just didn't need that for my room size or speakers. Larger room or bigger room, and the 402's would be great, though.
PostLink    Posted: Sat Jan 17, 2009 5:24 pm    Post subject: Reply with quote
Nah, I wired one circuit specific for all speakers with outlets at each location. I thought to install amps up front, in back, and a couple of small amps for the surrounds. But this was only if resources were available otherwise I'd run cables for AVR amplification only.
Gary M.
PostLink    Posted: Sun Jan 18, 2009 1:31 pm    Post subject: Reply with quote
shielded speaker cable is one of the best things I ever did for my theater
at the amplifier end I took the ground/drain wires from all the runs and bundled them up and drained it to a ground on one of my outlets, the noise floor/hiss of my speakers vanished completely
I forget the Belden part # (something shielded in the 5000 series) for this stuff, but it is unreal
-Gary
PostLink    Posted: Sun Jan 18, 2009 1:58 pm    Post subject: Reply with quote
And in the next stage of speaker cabling questions ... how are you guys terminating your stiff? Several years ago I tried the banana plugs like the ones on BJC website. I noticed that after a handful of months the assembly needed repeat tightening. I didn't know if this was do to the flexing of the conductor material as it went through warming and cooling stages, or just that the terminators simply sucked.
kschmit2
PostLink    Posted: Sat Jan 24, 2009 2:25 pm    Post subject: Reply with quote
There are only shielded cabels in my theater:
I use the predecessor of this cable for my mains and center (Lapp Unitronic FD CP (TP) 5x2x1, 18 AWG)
Note that this is 10 cores of 18 AWG, i.e. 5 pairs of 2 twisted 18 AWG cables Smile
Mains are biwired.
Rears use the predecessor of this cable (Lapp Ölflex FD 850 CY, 7G 0.75, 20 AWG)
In this case it is 7 cores of 20 AWG wire, IIRC I used only 6 of them in 2x3 configuration.
Kai
