Will ray electrocute himself?
Goto page 1, 2, 3  Next
rabies_70
TV/Projector: Sony G70Q
PostLink    Posted: Fri Dec 26, 2008 8:18 am    Post subject: Will ray electrocute himself? Reply with quote
Anybody want to have some fun and see if they can keep me from electrocuting myself??? Ive got a couple of amps I would like to trouble shoot and see if I can repair, at the board level is I think the correct terminology?
Adcom GFA-555. Ive got the service manual, but is there an electrical theory I should read about first Any pointers other than the obvious, Ray shut up you cheap prick and pay a tech to repair them. I've got a multimeter and an O scope. Lemme guess, I need a signal generator. I'll shut up now...thanks o wise ones Twisted Evil
Ray
I am an iconoclast
PostLink    Posted: Fri Dec 26, 2008 3:12 pm    Post subject: Reply with quote
Can i have your G70 when your "finished" by.... i mean with your amp troubleshooting????
rabies_70
PostLink    Posted: Fri Dec 26, 2008 7:13 pm    Post subject: Reply with quote
You'll have to fight the wife for it...she's kinda scrappy. Twisted Evil I think she would actually miss the projector. Although the cool thing about her not being too technically savvy is that when I add in the new VP50 or the algolith mosquito or the new f/x1000 side channels or the 2 new to me GFA-555's I'm betting she won't even notice Twisted Evil
Ray
I am an iconoclast
rabies_70
PostLink    Posted: Fri Dec 26, 2008 7:48 pm    Post subject: Reply with quote
Uh oh, I found thishttp://sound.westhost.com/articles.htm
Now the fun begins
Ray
I am an iconoclast
rabies_70
PostLink    Posted: Fri Dec 26, 2008 9:05 pm    Post subject: Reply with quote
Before I give my money to some anonymous choad on the bay, anybody got the following for sale?
Variac
Audio oscillator
Dummy load
Ray
I am an iconoclast
PostLink    Posted: Fri Dec 26, 2008 9:33 pm    Post subject: Reply with quote
Ray. Before you buy a lot of worthless equipment that really wont help you trouble shoot your amp, what is wrong with it?
PostLink    Posted: Fri Dec 26, 2008 10:14 pm    Post subject: Reply with quote
Good place to start... Wink
rabies_70
PostLink    Posted: Fri Dec 26, 2008 10:45 pm    Post subject: Reply with quote
I've got two Adcom GFA 555 each with one channel not working. Fuses were all good on one unit, the other one had two fuses blown and a bad power switch. Replacing switch did not correct missing channel, neither did replacing 6A fuses with 20A
(just kidding I just wanted to give you a chuckle I replaced them with same type and amp rating. They did not blow upon powering up.
I've been reading around on the above link and on diyaudio.com. These are basically just parts amps so I don't mind too much tinkering on them especially if two things happen
1. I learn something
2. I don't electrocute myself in the process.
A working amp would of course be a bonus Twisted Evil
Also a bonus would be an excuse to buy some more tools.
So I need a variac, sound oscillator and a dummy load right Twisted Evil
Ray
I am an iconoclast
PostLink    Posted: Fri Dec 26, 2008 11:29 pm    Post subject: Reply with quote
Ray,
Not sure how you've tested the amps to this point, but just a word of caution... I had an Adcom 545 that I bought off fleabay in "as-is/working" condition. I get it, spend an hour cleaning every square inch of the case, button, front and rear panels, and cord of years of dirt, grime, fingerprints, etc. It had a few scratches, but was in really nice shape.
Anyway, I connect the speakers to the banana plugs, connect the pre-outs on my super-nice receiver to the pre-ins on the Adcom. I hit the power button on the Adcom, and hear this HORRIBLE WICKED-ASS LOUD POP come from one of my nice M&K speakers. The AVR immediately goes into "protect" mode. It takes me another 1/2 a second or so and I kill the power on the Adcom and AVR and disconnect everything, freaking out the whole time thinking I just destroyed input stage on the AVR and probably the speaker, too.
I go get a VOM and find out there's a bunch of DC voltage on one of the pre-ins. Like, 25 or 30 VOLTS, IIRC. There's a thread here where I asked for advice. Curt had an idea about where to start, I think.
Somehow the AVR and speaker both survived. I'm just saying - test with non-critical stuff - i.e. junk car speaker, junk signal generator or worthless source equipment so you don't kill something you'd hate to lose.
Oh, and don't electrocute yourself, mmmmkay?
EDIT - Found the old thread. Curt did have some ideas and I never even got around to thanking him. Rolling Eyes FYI, I sold it to somebody here to tinker with. If we can figure out who, and he's repaired, maybe he can give you some ideas on your 555.
http://www.curtpalme.com/forum/viewtopic.php?t=3228
PostLink    Posted: Sat Dec 27, 2008 12:05 am    Post subject: Reply with quote
If they both play fine on one channel then you have just eliminated 2/3 of the amp from the problem. Power supply section should be fine, and the channel that works should be fine. So now you just need to concentrate on the section of the channel that doesn't work. Probably blew some of the output transistor and maybe some connecting components. Just use the schematic for the section not working and your DMM and do some component testing. Thats all you need to find the bad parts. The only other tool you may need is a capacitor tester if you want to check them. Also look for any swollen caps but more then likely they maybe ok. Older caps were made to last longer, at least from stuff I've worked on.
PostLink    Posted: Sat Dec 27, 2008 12:08 am    Post subject: Reply with quote
Start with Q13 to Q20 on the channel thats not working.
It was F1 and F2 that was blown, correct?
PostLink    Posted: Sat Dec 27, 2008 12:15 am    Post subject: Reply with quote
If you give up on it , lemme give it a try..Smile WOn't charge you the going rate either, it's been a while since I've gotten into a transistor amp.
PostLink    Posted: Sat Dec 27, 2008 12:18 am    Post subject: Reply with quote
Just realized I'm discussing at component level. Sorry Curt. I'll stop.
rabies_70
PostLink    Posted: Sat Dec 27, 2008 12:40 am    Post subject: Reply with quote
Now were talking. Thanks guys.
I used to not know better and would just hook a preamp, amp & speakers and go for it. Then I read a story like yours mr crabb and I got a junk setup to test on now. It would SO suck to kill something that didn't need killing. I
You guys are definitely getting me going in the right direction. I surely appreciate it.
Curt, I would love to send this for you to fix, if I give up I will. Alternatively I am re-writing my will so if I get electrocuted I will have it shipped to you.
macgyver...thanks big time for the pointers. I am going to do a wee bit more reading then dig into these beasts. If y'all don't hear from me in a few days it just means Curt's getting a free killer amp Twisted Evil
Ray
I am an iconoclast
CRT_Ben
PostLink    Posted: Sat Dec 27, 2008 4:43 am    Post subject: Reply with quote
Two things -
SC, I bought that amp. I haven't fixed it yet, what is junk for besides taking up space Laughing In all seriousness though, I hope to fix that amp soon and use that along with my current 545 to biamp my mains.
Mac - Unfortunately for Ray, the Adcoms have separate power supplies for each channel, they're a bit more complex to troubleshoot.
PostLink    Posted: Sat Dec 27, 2008 2:23 pm    Post subject: Reply with quote
CRT_Ben wrote:
Two things -
Is page 2 what your referring to as a separate power supply? I dont have the entire manual.
Adcom_555.pdf
 Filename:  Adcom_555.pdf
 Filesize:  85.82 KB
 Downloaded:  584 Time(s)
CRT_Ben
PostLink    Posted: Sat Dec 27, 2008 3:18 pm    Post subject: Reply with quote
Hey Mac,
I'll confess that I'm not the EE of the family (my brother is), but when we opened up one of my 535s to take a look, there were two large power transformers and my brother remarked that it looked like each channel had its own power supply. When I get back in town, I can post pix of the inside of the busted 545 and we can take a look.
PostLink    Posted: Sat Dec 27, 2008 3:23 pm    Post subject: Reply with quote
CRT_Ben wrote:
Hey Mac,
Sounds good. I'd like to see a pic of the inside. I pulled a copy of the complete service manual and there is a little discrepancy from the schematics I posted above. Now I'm curious. Let me know. Smile
rabies_70
PostLink    Posted: Sat Dec 27, 2008 5:45 pm    Post subject: Reply with quote
Thanks again guys...when I get back in later I'll send some photos as well. I stayed up last night til like 3am reading all kinds of theory and practice on amp repair, Transistors, diodes, zener diodes, drain, capacitors, resistors, gate, npn, pnp, signal generators, audio oscillators, how to finally use the oscope I bought last year, diode testers, variacs.
Here's what I learned so far in a very condensed format. Wholly crap you electronic repair guys know a LOT. When I asked my simply ignorant blissful question about repairing an amp, a can of worms I didn't even see coming opened up all over the place. I really only wanted to save a few hundred bucks on fixing a couple amps I have collecting dust. Now there are more tools on the way, more testers and more reading than I truly expected.
Tools and equipment on the way is always good.
Ray
I am an iconoclast
PostLink    Posted: Sat Dec 27, 2008 7:51 pm    Post subject: Reply with quote
Ray. One more little hint. After looking over the diagrams I see there is a thermal switch in the input section. Its identified as T1. I would check it for continuity. It is designed to open if overheated. I also see a T2 at 1k which is a thermistor. Its in the output section.Check it also.
Page 1 of 3
