Clarence
Joined: 08 Mar 2006 Posts: 3793 Location: Smith Mtn Lake, VA
Link Posted: Mon Dec 15, 2008 8:41 pm Post subject: (SOLD) DVICO FusionHDTV OTA capture |
I'm cleaning out my equipment closet... I've probably got 100 things sitting around in there that someone might still find useful.
There have been a lot of discussions about this For Sale forum lately, so if anybody has any issues with any of the items listed here, or if the prices are undercutting Curt in any manner, please let me know and I'll delete the listings immediately.
Curt/Kal, please feel free to delete any of these listings. If it's too closely related to CRT, not related enough, too cheap, whatever... when in doubt, just delete it.
Of course, as always, Curt has free dibs over any of this stuff.
http://www.fusionhdtv.co.kr/eng/Products/HDTV5usb.aspx
◎ True HD Time-shifting
◎ Works with MCE & 3rd Party Applications
◎ Digital Cable (Clear QAM)-Supports up to 256QAM
◎ USB2.0 BUS Powered Ports
◎ Supports Unencrypted Digital Cable
◎ Supports all Notebooks and Desktop PCs
◎ Watch Analog and Digital TV Programs on Your PC
◎ Record TV Programs to Hard Drive as DVD Format
◎ Scheduled Recording from Hibernation/Suspend mode
◎ Low CPU Consumption with DxVA SW Decoder
◎ High-resolution Still Image Capture
◎ EPG (Electronic Program Guide)
◎ Full Function IR Remote Control
True HD Time-Shifting Function
Have you been interrupted with a phone call or the doorbell while watching live TV programs, inevitably missing out on a crucial scene? Never miss a beat with the true HD time-shifting function! Pause and replay live TV shows by simply pressing the Pause button and then pick up right where you left off. Just like the live TV mode, FusionHDTV5 USB Gold provides a slew of file playback functions such as pause, instant replay, time-shifting with the scroll bar, fast-forward, rewind and so on.
FusionHDTV5 USB Gold works with Microsoft Media Center Edition 2005 and many other 3rd party media center softwares, such as Show Shifter, Power Cinema and SnapStream Beyond TV. Take advantage of the user-friendly Media Center for watching digital TV while browsing through other multimedia files on your PC. FusionHDTV5 USB Gold allows you the options of watching and recording high definition TV within the MCE environment or using its own FusionHDTV software.
Digital Cable(Clear QAM)-Supports up to 256QAM
The moment you encounter FusionHDTV5 USB Gold, you will be able to enjoy unencrypted cable channels even without a separate digital set-top box. FusionHDTV5 USB Gold scans unencrypted digital channels (clear QAM) and supports up to 256QAM (both 64 and 256QAM).
Scheduled Recording with EPG (Electronic Program Guide)
Forget about manually setting a record time for your favourite TV program. The FusionHDTV EPG let’s you simply select the program you want to record from a program list with a click of the mouse. You can watch your TV program from the start while it is still in the process of recording. Once you have the FusionHDTV5 USB Gold you can schedule TV recordings, have instant replay or view and pause live TV programs.
Highly Portable
This sleekly designed compact device is highly portable and can be supported on all notebooks and desktop PCs. It is also compatible with USB2.0 Bus powered ports and does not require an external power adapter.
Supports DivX/DVD Format Conversion
The Fusion Converter tool allows you to convert recorded high definition digital TV and other video files into high quality DivX, DVD formats while keeping the file size to a minimum.
HDTV Recording & Time Shifting Function
Records digital HDTV directly to your hard drive just like a VCR
Real HD/SD time shifting function with FF/ REW/Positioning
Highly Portable
Supports all notebooks and desktop PCs
Bus-powered (No power adapter required)
Sleekly designed small form-factor which fits in your pocket
High Resolution, Unrivaled Crystal Clear Picture Quality
Provides ultimate picture quality on your PC
Crisp and clear picture quality even on LCD or low resolution monitors
Conversion to DVD/DivX Format
Supports the fastest DVD/Divx conversion for burning and archiving
Supports ultra fast native mode .MPG conversion
Bundles DVD authoring and burning software
Dvico's Proprietary HDTV SW Decoder
Dvico's own HDTV software decoders for both non-DxVA and DxVA VGAs
Provides the best VGA compatibility with non DxVA full software decoder
Provides low CPU consumption with DxVA SW decoder
Dvico's own AC3, AAC, MPEG1/2 audio decoder
Item Specifications
Input/Output TV antenna reception port
1 Composite(using dongle cable), 1 S-Video Video Input
Direct audio stream output to sound card(HDTV)
Compatibility (DVHS) Running on Windows XP or later only.
1394(Firewire) port
Drivers Conexant CX23882 drivers
Dvico's own tuner driver
Dvico's own full software HDTV decoder
Dvico's own DxVA software HDTV decoder
Application Software FusionHDTV
TV viewing and recording, simple cut editing
Fusion converter: Converts HD stream to DVD or DivX
Signal strengh checker
supported OS WindowsXP, Windows2000
Windows XP Media Center Edition(MCE)
Windows Vista 32 & 64bit
- XP ServicePack1 or above : Digital/ Analog
- XP: Digital only
- Windows 2000: Digital only
$50
SOLD.
114.47 KB |
6964 Time(s) |
Clarence
Link Posted: Mon Dec 15, 2008 9:36 pm Post subject: |
First PM received was from J.
I forgot to mention shipping, but for everything listed... if it fits in a Priority Mail envelope, that's $4.80. Flat Rate box is $9.80
Or if you want it slower/cheaper, let me know and I'll send it regular First Class parcel post and you can send me the actual lowest rate.
Non-US addresses: same deal... actual postage. Let me know if you want it express or slow/cheapest.
Clarence
Link Posted: Mon Dec 15, 2008 9:42 pm Post subject: |
J= John.
Sorry, I saw your PM and didn't know if it was a "private" secret. I just wanted to distinguish between others who PM'd.
Clarence
Link Posted: Mon Dec 15, 2008 9:53 pm Post subject: |
SOLD.
Paypal received. Thanks.
Link Posted: Mon Dec 15, 2008 10:25 pm Post subject: |
Hi Clarence, how well did this work for the OTA stuff? How was the software? I looked at one of those a while back but as always got bussy and forgot about it.
Clarence
Link Posted: Mon Dec 15, 2008 10:54 pm Post subject: |
I think these are great. I originally had the internal card, dvico v3 I think. Then I got HD cable with firewire out. But then I tried the USB version (looking for 5.1 on PBS)... USB was much better than the internal versions.
No drop outs on the recording. Great QAM, but I live too far out in the boonies to get OTA. You need to be ~25 miles from a broadcasting city.
Link Posted: Mon Dec 15, 2008 11:32 pm Post subject: |
Thanks for the info. Too bad there's no QAM here. BUT I do get 21 chanels OTA.
