incova
Link Posted: Sun Dec 14, 2008 2:25 am Post subject: could be |
A few pics to clarify:
side view of new tube, nothing to indicate what it is. |
107.88 KB |
7538 Time(s) |
new tube, it had sony elite written on the top of the lc chamber. It also has the rectangular piece stuck to the face of the tube covering the edges not stuck in the lc chamber. |
89.64 KB |
7538 Time(s) |
fungus lc chamber with no rectangular piece in it. This is for the new sony tube ( I think its a sony tube ) |
236.21 KB |
7538 Time(s) |
the third piece that is on the other tube but still stuck to the old lc chamber. |
152.49 KB |
7538 Time(s) |
84.65 KB |
7538 Time(s) |
84.1 KB |
7538 Time(s) |
_________________ The more I learn
the less I know.
incova
Link Posted: Sun Dec 14, 2008 2:30 am Post subject: start from the bottom with the pictures |
Start bottom up with the pic it may make more sense, sorry it uploaded in reverse order to what I expected. If you look at the new (fungus) lc chamber it has no rectangular piece in it, the piece is stuck to the frost of the tube, the old lc chamber does have this piece stuck the chamber and not the tube though so I am not sure wether its meant to be stuck to the tube or the chamber or both?
the less I know.
incova
Link Posted: Sun Dec 14, 2008 2:31 am Post subject: Neckcards |
I will check the neckcards asap, they do not look modified but may well be I have to check against the red, thanks for the suggestions gents.
the less I know.
VideoGrabber
Link Posted: Sun Dec 14, 2008 5:59 pm Post subject: |
No helpful comments, but that pict499 is really sad. Why didn't they just use a 7" tube in the first place? There oughta be a law.
_________________ - Tim
incova
Link Posted: Sun Dec 14, 2008 6:25 pm Post subject: I know! |
I noticed that, the raster is so small its just silly, however the raster on the new green is practically 1mm from each edge so whoever owned this pj seems to have caught up after running it a bit too close too the edge for my liking on the new tube though.
the less I know.
VideoGrabber
Link Posted: Sun Dec 14, 2008 6:58 pm Post subject: |
Yes, too close to the edge can make geometry difficult. And increase the possibility of a "fatal error".
incova
Link Posted: Sun Dec 14, 2008 7:59 pm Post subject: fatal error |
i cannot remember where I read this so do not quote me! if memory serves me correctly someone said that the sony tubes have a wider bell meaning that the raster can be pushed nearer the edge than Mec tubes, how true this is I cannot say.
the less I know.
incova
Link Posted: Wed Dec 17, 2008 11:43 pm Post subject: the other piece |
Lets hope this comes in the right order!
The piece I was wondering about. |
317.75 KB |
6566 Time(s) |
lc chamber with no perimeter piece for the tube to rest in. |
114.16 KB |
7470 Time(s) |
lc chamber with rectangular perimeter piece for the tube to rest in. |
103.57 KB |
7470 Time(s) |
this is the rectangular piece I was on about. |
152.49 KB |
7470 Time(s) |
thats the metal perimeter piece just resting next to the old mec tube. Its the black rectangular piece. |
101.08 KB |
7470 Time(s) |
mec tube with perimeter piece on, this piece seems to center the tubes face, this piece was on both lc chambers, actually one was stuck in the lc chamber and the other came out with the tube. Not sure if it should be on the tube or the lc chamber as a rul |
98.25 KB |
7470 Time(s) |
blue blue guns tube, still do not know what tube it is! |
129.86 KB |
6568 Time(s) |
the less I know.
incova
Link Posted: Thu Dec 18, 2008 12:18 am Post subject: thanks man |
hopefully thats what the tube is, I have silicone it all now, so now I just have to wait for it to cure and hope it takes. I looked at the neckboards all three look the same, by the way I liked the article you did on the bellows for the marquee, I never could figure out what those were!
the less I know.
incova
Link Posted: Sun Dec 28, 2008 6:12 pm Post subject: slight leaks in silicon |
hey again all, I waited about 10 days for the silicon to cure and then put the glycol and c element in, everything seemed fine but then I got leaks from one side but none of the other 3 sides, should I just cut the one side out and re silicon it or take all the silicon out and do it all again?
the less I know.
Link Posted: Sun Dec 28, 2008 10:44 pm Post subject: |
I'll be the bad guy and break the news to you. Do it all over again. You'll never get it to seal trying to patch it over.
Make sure no oily residue is on the mating surfaces when you re-glue. Sorry.
_________________ Chip
incova
Link Posted: Sun Dec 28, 2008 10:59 pm Post subject: thanks man |
thanks Chip, bit of a shame as only one side is actually leaking the other three have sealed, not sure why this happened, thanks again man.
the less I know.
amywoods
Link Posted: Mon Mar 05, 2018 11:29 am Post subject: Alternatives at Toolstation? |
zGman wrote: | OK, if you can't find the GE, then look for something that has a similar formulation -
most automotive and other earlier type 'silicone' sealants use an acetic acid based
hardening system (vinegar smell while curing) and these have been proven
unreliable for tubes and HV.
G |
Hi all, stumbled across this thread with a similar problem in UK. Nothing at screwfix but would any of these sealants work at Toolstation? https://www.toolstation.com/search?searchstr=silicone
