tchagui
Link Posted: Sat Nov 22, 2008 12:01 pm Post subject: NEC 6PG parts...how much ??? (point board inside) |
Hello
After a problem with my NEC PG6000 CRT (F8 error), i've decided to sell it for parts.
it worked very fine before this problem.
I tried to change the 2 STK392-040 on the C-board an a resistor but the problem is still on it. (shut down immediately when powered, with "F8" flashing on the rear panel.
If i unplug the CA connector, it stays powered. (i think that the problem comes from the deflection board...)
Are those prices good ?
RC6011 remote : 40 Euro
Point board (PWC3718 - 72137181) : 100 Euro
Set of RGB CRT : 330 euro
ask-me if you're looking for other parts.
I live in France, so if interested, you've to add shipping costs.
Tchagui.
lostmandan
Joined: 09 Jul 2008 Posts: 146 Location: Kitchener/Waterloo, Ontario, Canada
Link Posted: Sat Nov 22, 2008 3:25 pm Post subject: |
If you were in North America, I would definitely consider buying the set of minty tubes. I think shipping from France to Canada would be pretty expensive
If pulling the CA connector lets it run, I would recommend finding a good C-Drive PWB and getting that machine working properly again. It is one of the common boards, and really not that heavy or large. I am sure that Curt would have one and shipping would be expensive, but probably not terrible.
Dan
Link Posted: Sat Nov 22, 2008 3:49 pm Post subject: |
I agree. I've had lots of issues recently with the 3712 C boards. Put in a later 3857(?) board out of a + or Xtra. Shipping is cheap.
Link Posted: Sat Nov 22, 2008 5:00 pm Post subject: |
no kidding, why tear apart a machine with such excellent tubes just because it needs a cheap and easy to find C-board.
tchagui
Link Posted: Sat Nov 22, 2008 6:15 pm Post subject: |
Curt Palme wrote: | I agree. I've had lots of issues recently with the 3712 C boards. Put in a later 3857(?) board out of a + or Xtra. Shipping is cheap. |
Perhaps i could get a PWC-3857, but before puting it in my PG6000, you told me that i would have to change somethings on it.
And, i don't know what are the modifications needed on it.
Is it easy? only resistors to change ?
Is it possible to plug a deflection board from a PG9/6100 or PG9/6200 in a PG9/6000?
tchagui
Link Posted: Sat Nov 22, 2008 6:20 pm Post subject: |
draganm wrote: | no kidding, why tear apart a machine with such excellent tubes just because it needs a cheap and easy to find C-board. |
I didn't find the board anywhere (PWC-3712), and problem is that i'm not sure it's only the C-drive.
I'm afraid of changing the C-drive and still beeing with the PG out of order.
lostmandan
Link Posted: Sat Nov 22, 2008 6:51 pm Post subject: |
I guess there is no guarantee that replacing the board will fix your PJ, but given the reading I have done, it definitely seems like it should be the fix. Does the PJ appear to be working properly (aside from convergence issues) with the CA connector unplugged?
tchagui
Link Posted: Sun Nov 23, 2008 8:33 am Post subject: |
The PJ works nearly properly with CA connector unplugged.
I just noticed that there are some strange horizontal lines when the PJ is cold.
It's hard to explain (harder in my poor english language...) : There are 4 or 5 lines that flashes at the same time on the 3 tubes, but at different places. At first, i thought my RGB cable or HDfury had a problem, but the problem is still there without any source plugged.
And 5 or 10 minutes later, when the PJ becomes hot, this problem dissapears.
That's why i think the problem should come from the deflection board. (i'm very far for beeing electronical technician... )
kschmit2
Joined: 09 Mar 2006 Posts: 1141 Location: Heidelberg, Germany
Link Posted: Sun Nov 23, 2008 10:56 am Post subject: |
I have at least one of each board in a 9PG left here. All of the boards come out of a fully working and tested PJ (I let it run for 50 hours before I parted it out).
I'm located in Germany.
Kai
kschmit2
Link Posted: Mon Nov 24, 2008 3:24 pm Post subject: |
tchagui,
I just checked and the C-Drive I have here is a PWC-3857B, Part# 72138572, ink stamp 1E7-485EM.
It came out of a working NEC PG9000.
Kai
tchagui
Link Posted: Mon Nov 24, 2008 5:09 pm Post subject: |
kschmit2 wrote: | tchagui,
Kai |
Are you sure that i can plug a PWC-3857B instead of a PWC-3712B without any modifications ?
kschmit2
Link Posted: Mon Nov 24, 2008 6:23 pm Post subject: |
The 3857B C-Drive came out of a tested and fully working PG9000, and the F-Drive in that PJ was a 3712A.
I'm pretty sure that the 3857B will work just fine in your PG6000.
Anyone else think otherwise?
tchagui
Link Posted: Wed Nov 26, 2008 12:02 pm Post subject: |
Hello !
Can anyone give me the weight of a CRT with or without rings on?
With those informations, i can go to the post office and ask them shipping costs to USA or Canada or elsewhere.
I've bought another projector.
