FAQ: GammaX add-on accessory
Goto page Previous  1, 2, 3, 4, 5, 6
HKmod
PostLink    Posted: Fri Jun 26, 2009 7:21 pm    Post subject: Reply with quote
Yes it's possible. Before exchanging the unit, which you can do anytime through email, please try to answer one more question:
First If you can take a picture of how you have them mounted in your setup it may help.
But especially, do you have the HDF2 switch on rgbhv ?
HKmod.com - We ship worldwide
(Site under recalibration)
Murillo
PostLink    Posted: Sat Jun 27, 2009 2:55 pm    Post subject: Reply with quote
I don`t use HDF or HDF2. I connect the gammax directly to the vga out of my htpc, and from there i use a 2 m cable to my Barco 1209. There was a short (20 cm long) monitorcable that came with the gammax that I tried both with and without.
Best Regards.
PostLink    Posted: Sat Jun 27, 2009 3:22 pm    Post subject: Reply with quote
HI Murillo,
You have the GammaX backwards. It's designed to connect to the HDfury1/2 so what you think is the input plug is actually the output.
You'll need a couple of VGa gender changers like these in order to hook it up:
http://cgi.ebay.co.uk/VGA-SVGA-Gender-Changer-Female-to-Female-Adaptor-F-F_W0QQitemZ270406528798QQihZ017QQcategoryZ41993QQcmdZViewItem
AND
http://cgi.ebay.co.uk/VGA-SVGA-Gender-Changer-Adaptor-M-M-Male-to-Male-15-Pin_W0QQitemZ260364227282QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item3c9eead2d2&_trksid=p3286.c0.m14&_trkparms=65:12|66:2|39:1|72:1683|240:1318|301:1|293:1|294:50
You will need one male to male and one female to female to get things up and running.
Jeremy
HKmod
PostLink    Posted: Sat Jun 27, 2009 4:38 pm    Post subject: Reply with quote
Yup more likely, if no HDfury in use, then it might be the case.
HDfury have VGA MALE (SUB-D HD15), that connect to the VGA FEMALE INPUT of Gamma X
Output of GAMMA X is MALE VGA !!
Murillo
PostLink    Posted: Mon Jul 06, 2009 12:38 am    Post subject: Reply with quote
HI Murillo,
AND
Jeremy
I did like you said and it worked, many thanks for your support. I noticed that the colours looked a little washed out when using the unit, do I need to do a competly new color calibration with the gammax or is it just a matter of setting the gammax a bit lower?
PostLink    Posted: Mon Jul 06, 2009 5:32 am    Post subject: Reply with quote
Murillo wrote:
HI Murillo,
AND
Jeremy
You need to adjust for the best gamma then recalibrate. Glad you got it working.
Murillo
PostLink    Posted: Mon Jul 06, 2009 8:25 am    Post subject: Reply with quote
Murillo wrote:
HI Murillo,
AND
Jeremy
OK thanks again.....
Murillo
PostLink    Posted: Thu Aug 20, 2009 1:14 pm    Post subject: Reply with quote
johnsmith808 wrote:
Just as a note for anyone who gets a gamma boost add on, make sure to set your source to RGB Full, a.k.a. 0-255. I had my PS3 set up for RGB limited, and the gamma adjustment would raise the lowest black level as well. When I set it to RGB Full, the absolute black level would stay the same no matter how high I turned the gamma knob on the Box1020. I guess that's because the Box1020 gamma is designed to raise the brightness level of everything above 0ire.
Hope that made sense. It was probable already stated before, but it was new to me.
How does one set the full (0-255) on a ATI graficscard? I suspect that mine is set for limited (16-235) since the colors look a bit washed out. I am using pdvd9 and windvd9 to play dvds.
PostLink    Posted: Thu Aug 20, 2009 2:49 pm    Post subject: Reply with quote
If you don't get an answer here you may want to ask in our HTPC forum here as well (since it's really an HTPC question). Good luck!
Foe-hammer
PostLink    Posted: Fri Sep 11, 2009 9:24 am    Post subject: Reply with quote
I REALLY want the Gammax for my Sony fw900 monitor. I've been using Windas to revitalize the monitor through out the years, but its to the point that it needs more contrast (need more brightness without loosing black levels). The only thing keeping me from buy a Gammax now from you guys (since you have it in stock) is monoprice.com has it for only $56, but they don't have them in stock. Buy now and pay almost double, or wait for who knows how long. Decisions, decisions.....
HKmod
PostLink    Posted: Fri Sep 11, 2009 9:45 am    Post subject: Reply with quote
Gamma-X is not like HDfury which can operate without External PSU.
The PSU is mandatory when using Gamma-X (except if you have HDF2 powered in the chain)
Monoprice do not ship any PSU or USB+5v cable with it.
PostLink    Posted: Fri Sep 11, 2009 12:55 pm    Post subject: Reply with quote
Monoprice also does not include free shipping.
PostLink    Posted: Fri Sep 11, 2009 1:41 pm    Post subject: Reply with quote
So if you buy it from monoprice it will show up unusable. Without the power supply it's goes into paperweight mode...
Foe-hammer
PostLink    Posted: Fri Sep 11, 2009 11:07 pm    Post subject: Reply with quote
Good point about the power supply and shipping. Though they do offer the needed power supply (AC Power Adapter 5.0V/500mA plus usb cable) for $2, and shipping for both would be $3. So ya, it comes down to waiting for who knows how long and save roughly $40, or get it now with curtpalme.com. And i'm usually not that patient when there is no in stock fixed date.
Foe-hammer
PostLink    Posted: Fri Sep 18, 2009 11:49 pm    Post subject: Reply with quote
Well i just received a gammax and hooked to the 360 and to a fW900 sony crt monitor. So far i'm not impressed. I can get a more vibrant image without it then with it. As i turn up the dial on the gammax, it seems to just washout the picture, instead of boosting the contrast. But i have confirmed that the black levels stay consistent. It is an odd thing. I have the 360 set to expanded lvls (full) so that it is using the 0-255 range.
I also have the power supply and usb cable to go along with it, but it makes zero difference in picture quality if i use the power supply or not. The power supply does light up the blue led in the gammax when the gammax is not connected to the monitor. The blue led also lights up when the gammax is connected to the monitor and xbox without the power cable.
Sigh... and i was really hoping that i'd get improved picture quality. Could the gammax be defective?
PostLink    Posted: Sun Sep 20, 2009 1:52 pm    Post subject: Reply with quote
Just to be clear: The GammaX (as well as other gamma boost devices like the Box1020/21/40 series) boosts gamma at the low end of the signal. it does not boost contrast as you wrote.
The purpose of gamma boost is to have the signal "come out of black" faster to make up for the non-linear characteristic of some displays such as CRT displays. These displays need a little "bump" on the low end of the signal (0-30 IRE) to make sure image information isn't lost. I've always used some form of gamma boost on my CRT projector (a Barco Cine 8 Onyx) because without it the low end of the image was too dark and shadow/dark details were missing or muted.
Have you measured your gamma curve before adding the gammaX? I have a 'Greyscale & Colour Calibration for Dummies' guide here that walks you through it: http://www.curtpalme.com/forum/viewtopic.php?t=10457
After measuring the before results, you can turn up the gamma boost a bit and re-measure. Repeat until you get into the right gamma boost range (2.2 - 2.5).
A lot of people just eyeball it too. Just make sure not to use too much. The common mistake that people do is crank it up (more is better right?) Smile It may seem like a subtle change at first but once you've used it correctly for a while and then turn it off, it's mostly then that you'll really start to notice what you were missing before. I could never go back to *NOT* using gamma boost on my CRT display.
Maurice089
PostLink    Posted: Mon Apr 26, 2010 4:55 pm    Post subject: Reply with quote
GammaX yeeeah!"
PostLink    Posted: Mon Apr 26, 2010 11:44 pm    Post subject: Reply with quote
Maurice089 wrote:
GammaX yeeeah!"
You like yours do you?
Page 6 of 6
