Per 489
Joined: 09 Jun 2007 Posts: 31 Location: Aaland. Finland
Link Posted: Thu Oct 30, 2008 7:26 pm Post subject: Witch chanel? |
I just hooked up my WIM-HD card to my EM8500 but canīt get a picture. Witch channel do you find it on?
I run a HDMI cable direct from a Panasonic 686 DVD. All 3 lights are on. First I start the projector then the DVD, is that the right way to go?
Per
moome
Link Posted: Tue Nov 04, 2008 7:33 am Post subject: |
yes, but which DVD you use? if you use blueray, please turn off the 1080P 24Hz mode
Per 489
Link Posted: Fri Feb 12, 2010 11:24 am Post subject: |
Hi
I gave up trying to get a picture since i hade no DVD with HDMI out but now i have a PS3. I have turned of 24Hz but I still get a message "SYNC?" and "V scan out of range" and no picture. I have tried to run the signal to the scaler (HD Leeza) and from there to the card but no luck. I can see that all 3 lights turns on when I turn on the PS3 (two of them turns on when i turn on the projector).
I have tried to clean the contacts on both the Moome card and the bigger input-card but no luck so far.
Running component from PS3 doesnīt work. I switch to input 2 on my EM 8500LC.
Any suggestions?
Best regards Per
Link Posted: Fri Feb 12, 2010 12:42 pm Post subject: |
Channel
Ok Just kidding, the PJ should be on Source 02 . if no picture still select the correct input for either HDMI or Component on the Moome Card.
You have the version with one HDMI and the Component correct?
If you have the two HDMI is has no component, but there is still a select button on the card or use the remote pointed at the card, you need to look at the card to make sure the remote signal is being accepted by the card. I light will flash.
once you get the input set up save it as a new channel.
PS its Which Channel Just teasing you a little
moome
Link Posted: Tue Feb 16, 2010 7:21 am Post subject: |
Per 489 wrote: | Hi
Any suggestions?
Best regards Per |
what version of the card you have? can you tell the date on the card?
Per 489
Link Posted: Tue Feb 16, 2010 6:31 pm Post subject: |
Hi
This is what I can read on the card.
VIM HD V1.02
2007.06.13
PJI -HD INC.
It is supposed to be a new card, never installed before I got it. I did not buy it direct from you but I trust the guy I bought it from 100%
Best regards Per
moome
Link Posted: Thu Feb 18, 2010 5:06 am Post subject: |
Per 489 wrote: | Hi
VIM HD V1.02
2007.06.13
PJI -HD INC.
Best regards Per |
it is a old version, here is the VIM HDMI history:
VIM-HD
VIM-FULLHD
VIM-FULLHD V2
and if three led light up and no blinking, it should the edid problem or the dvd player setting,
did you try dvd's hdmi output with other display like LCDTV?
thanks
Per 489
Link Posted: Thu Feb 18, 2010 7:18 am Post subject: |
Hi
Yes, all three led light up when I send a signal from PS3 (one goes black if I turn PS3 of) and no blinking. HDMI from PS3 and DVI-D from scaler (HD LEEZA) works fine on other devices. I have also tryed to take a signal from a laptop but no luck. I have turned off 24Hz on PS3.
What is the edid problem?
Best regards Per.
Per 489
Link Posted: Mon Mar 01, 2010 7:40 pm Post subject: |
Hi
Still interersted in the edid problem. Can it be fixed or?
Per
moome
Link Posted: Tue Mar 09, 2010 1:43 am Post subject: |
sorry for late, yes, it can be repaired, just send back to us~
thanks
