dturco
Joined: 06 Feb 2009 Posts: 3774 Location: Eastern Shore Maryland
Link Posted: Mon Mar 14, 2011 4:22 am Post subject: RTI remote + 12v triggers? |
Ok so here is what I want to do. I want to move my rack and get all of my new stuff in order. I have a RTI T-2 remote, have had it for quite a while, that can do all sorts of nifty stuff, problem is the guy who sold it to me needs to reprogram it at a significant cost plus it wont do what I want it to do. I think.
Right now the Marquee is turned on by it's own remote. It has RS232.
The Arcam AV-9 turns on itself and 12v triggers the Bryston 4b or 4b & 6B depending on what input it sees. The Arcam has RS232.
The Integra DVD has a 12v trigger also and I think it gets turned on with that 12 volt trigger and turns on just the 4B when in stereo. It also turns the 4b & 6B on when in Dolby Digital. It also does this 4&6 for SACD even though it is just Direct 2ch for most of the time. The Integra also has RS232.
The new OPPO 95 has RS232 and a IR remote in. I think all of the equipment has IR in mini jacks.
Now for the programming bit I guess.
I would like to just turn on the 4b and whatever source am going to use, OPPO or Integra and the Arcam when doing C/D
D2Ch.
For SACD the OPPO, Arcam, and 4B when using D2Ch. When using surround then of course all of the preceding and the 6B.
For Blu-ray same as multi channel above and the Marquee.
It's not a very complicated system but there are only 3 12v triggers to go around and the the RTI has to go into macros but I can't do that without the "INSTALLERS" help. And it still does not address the Marquee.
So do I need a programmable 12v trigger box of some sort, or IR emitter sequencer box of some sort.
And lastly do I need a new remote to cut off the ties to the installer guy or if I get the RTI loader Program will that work?
I think I covered most of the issues I want to address.
http://www.hulu.com/firefly
