FAQ: Pronto TSU-501 / Boston A7RC remote - Only $39 shipped!
jask
PostLink    Posted: Sat May 02, 2009 4:14 pm    Post subject: Reply with quote
The Harmony 880 is the most popular remote in our house, it made it so much easier for my wife and kids. I have no information on the logos etc, try the harmony site or remotecentral.com
You may in fact be an honest HTPC users, that possibility exists (though your tone, attitude, etc suggests otherwise).
angryht
PostLink    Posted: Tue May 12, 2009 4:31 pm    Post subject: Reply with quote
Just to be clear: I assume I can't use my Universal MRF-100 RF base unit, right? I need to get a Marantz or Philips. Can anyone point me in the direction of a reasonably priced rf base unit?
TechToys
PostLink    Posted: Tue May 12, 2009 5:54 pm    Post subject: Reply with quote
Actually the MRF-100 base should work. You'll have to experiment with the channels though.
angryht
PostLink    Posted: Tue May 12, 2009 6:06 pm    Post subject: Reply with quote
Probably worth a try. Thanks, TechToys.
Dfried1
PostLink    Posted: Tue May 12, 2009 10:21 pm    Post subject: Reply with quote
Stay away from a the trek, it needs two units to do the job of one and need to be line of site.
The one made by Next Generation Home Products works well. Most of the time it is sold with the transmitter which you shouldn't need if you have a 501. I got two with out transmitters going direct to Next Generation.
Let me know if you can find the info and I can try and dig it out.
Make sure you get the correct version for the 501. the freq is in the back of the manual
hdtvluvr
PostLink    Posted: Sun May 17, 2009 1:19 pm    Post subject: Reply with quote
Can the power button be used as a macro? I need it turn on the TV, cable box, HTIB and set the input on a Sony TV.
Also, can one use any ProntoNeo files?
TechToys
PostLink    Posted: Sun May 17, 2009 7:10 pm    Post subject: Reply with quote
Yes, under device properties select Hard Buttons, select the power button, and then add as many "create links" as you need. You can pretty much use any neo file nut NEVER NEVER NEVERtry to update the firmware with the neo firmware updater.
hdtvluvr
PostLink    Posted: Sun May 17, 2009 7:19 pm    Post subject: Reply with quote
So, somewhere I read that there were 5 macro buttons. I assume doing this with the power button would be 1 of the 5. I've looked at some neo files and some custom programs appear to be activity based with "Watch TV", "Watch DVD" etc. soft buttons on a device page. Do these sort of macros also account for the 5 or are they in addition to them?
I'm used to the mx series of remotes and software from URC. However, for the price of these they seem to be a better fit for my in-laws than the button remote I got from Radio Shack.
The manual just doesn't seem very clear on all of the possibilities of the remote.
ralpharch
PostLink    Posted: Sun May 17, 2009 7:34 pm    Post subject: Reply with quote
Most of the hard buttons can be programmed except the scroll buttons, contrast, mode and device buttons. - so that leaves 15 hard buttons by my count.
And the macros are specific to the device hard button screen - so left power on my home screen turns everything on including reciever and tv an turns the tv volume down and tunes a channel. Right power button turns just the TV on in the home screen and turns to a channel. And then they both jump to appropriate devices.
But on those device pages the power macros are programmed to turn everything off (left power) or just the tv (right power) - and then they both jump to the start page device to be ready to start everything up.
So bottom line a lot of programming but very flexible
You can download my file that was posted above on March 7th and try it out in the emulator to see one way to program the power and othe buttons
hdtvluvr
PostLink    Posted: Sun May 17, 2009 9:27 pm    Post subject: Reply with quote
I downloaded the software from Remote Central and found your file there. Looks good. Now to go order.
97ss150
PostLink    Posted: Mon May 18, 2009 1:10 am    Post subject: Reply with quote
is this thing overly complicated or am i making a mistake starting from scratch? i have looked on the website and none of my gear is on there. i have a lexipro dc-1 preamp, and an nec pg?!? not too sure whats up.
TechToys
PostLink    Posted: Mon May 18, 2009 1:14 am    Post subject: Reply with quote
It isn't overly complicated but you do have to think out the desgin fairly well if your starting from scratch. I tend to download a file someone else has worked on and just modify it to suit my needs. If you have the original remotes you can teach it the commands that aren't available from the internal database or on remotecentral.
angryht
PostLink    Posted: Fri May 22, 2009 1:44 pm    Post subject: Reply with quote
You were correct, sir. I got mine yesterday and it worked like a charm on the first channel I tried. Thanks again, TechToys. Now I just need to learn a little bit more how to program this thing. Incredible value!
angryht
PostLink    Posted: Tue May 26, 2009 1:30 pm    Post subject: Reply with quote
I have noticed that sometimes when I activate the remote, the touch screen will freeze up and only show about half of the information. I can usually 'bring it back' by pushing a couple of buttons but I have had to remove the batteries to sort of reset it. Has anyone had a similar problem?
hdtvluvr
PostLink    Posted: Wed May 27, 2009 1:14 am    Post subject: Reply with quote
Has anyone be able to create a macro on the Power and TV power buttons?
TechToys
PostLink    Posted: Wed May 27, 2009 1:27 am    Post subject: Reply with quote
Did you try what I suggested earlier?
hdtvluvr
PostLink    Posted: Wed May 27, 2009 1:52 am    Post subject: Reply with quote
Yes, I did try that. After downloading the file to the remote, when I press the Power button I do not see the IR emitting icon in the upper right hand corner. The battery level displays. For the other hard buttons on the remote the battery icon changes to the IR emitting icon (curved lines). I am programming this for my in-laws and can't really test the results.
ralpharch
PostLink    Posted: Wed May 27, 2009 5:29 am    Post subject: Reply with quote
My power buttons are all configured as macros. When pressed, the IR symbol is displayed but very quickly replaced with the battery symbol. But even then on my Power button on quick lauch device (start page) which has some delays the IR symbol comes back later on. So I think if you don't see teh IR symbol at all something is off on your programming of the macros
Since you had already d/l my file you could just load that up and see if you still don't notice the IR on your power buttons
hdtvluvr
PostLink    Posted: Mon Jun 01, 2009 11:21 pm    Post subject: Reply with quote
Thanks for your response. I have built my macro similar to yours and I do not get an IR symbol. I'll keep trying on that. In the meantime, I have another issue. I have 4 channel icons that when pressed give a message:" In the next screen type a codeset identifier for the TV from the user manual and press OK"
I have 20 other channel icons that will give the IR symbol at the top right of the remote and appear to work correctly. I have deleted the 4 buttons, copied back from your file and pasted into mine (like I did some of the others) and re-established the programming. I still get the error on those 4 buttons. What did I do wrong?
hdtvluvr
PostLink    Posted: Tue Jun 02, 2009 1:20 am    Post subject: Reply with quote
OK, I fixed the 4 icons. I learned a single channel # to each and re-uploaded the file to the PC and then changed the learned IR code to the macro for the channel #'s, delays and enter.
I had the Power and TV Power macros working until I used NeoSync to set my startup page. The programming is on the keys (as seen on the PC) but they do not send an IR signal based on not getting the IR symbol on the upper right corner of the remote. I really need a custom startup page instead of a device page with a startup page. Any ideas?
Page 8 of 10
